Reply
Thread Tools Display Modes
Old 11th of December 2005 (Sun)   #1
gcams
gcams's Avatar
Default 2nd copy of 17-40mm F4L, edge to edge inconsistency.
Hi folks,
Well this is my second copy of the 17-40mm F4L after returning the first one I had (thread http://photography-on-the.net/forum/...d.php?t=115418 refers). The new lens is much better than the last one I had and centre sharpness is excellent. In fact, so is edge sharpness, but only on one side. I did some tests this morning outdoors and started to notice that the right hand side of the frame is always softer than the left. This is particularly noticeable when shooting close up.
I did some newspaper tests under daylight and these are the results (all shot off tripod at F4 with mirror lockup, 100% crops):
Top Left:
Top Right:
I know the consistency of lighting across this shot is not ideal, but I have a number of other examples under different lighting conditions. Regardless of the situation, the results are the left is always sharp and the right is always soft.
My real question is, bearing in mind this is on a 1.6x crop factor camera (350d), is this inconsistency acceptible or should I be sending back my second copy and trying for a third??
I guess I'm a little hesitant to return this copy also, as at least it is sharper than the first, although the right hand edge of frame is getting quite soft. I'm not sure how it would look on a full frame camera which I hope to one day own.
Thoughts, comments?? Am I being too picky??
Graham
Visit my gallery at: www.scotlandscenery.com
Canon EOS-350D & BG-E3 Grip, Canon EF 17-40mm F4
L USM, 18-55mm kit lens, Manfrotto 055ProB +488RC2 Tripod, HiTech ND Grads, Canon A70
gcams is offline   Reply With Quote
Old 11th of December 2005 (Sun)   #2
gcams
gcams's Avatar
Default Re: 2nd copy of 17-40mm F4L, edge to edge inconsistency.
Here's another example at F4 with more consistent lighting across the whole page:
Left Hand:
Right Hand:
Graham
Old 11th of December 2005 (Sun)   #3
BoySpot
BoySpot's Avatar
You really sparked my interest with this post. I have been stitching some panos taken with my 17-40 at the 40mm end. Using PTAssembler, you get a direct comparison between the sides (and top and bottom) of the lens on the same subject when looking for the control points. I definitely notice it is sharper on one side than the other and I think it is the same way around as yours from memory. I was wondering whether the filter was a factor but now you have got me thinking.
BoySpot is offline   Reply With Quote
Old 11th of December 2005 (Sun)   #4
gcams
gcams's Avatar
Hi BoySpot,
It certainly could be that you're experiencing something similar. I noticed the consistency between the left and right edge of frame becomes much better once the lens is stopped down a bit. Here's an example at F5.6 for example:
Top Left Hand Side:
Top Right Hand Side:
Also this is at the 17mm end. Again at the 40mm end the effect was much less (if at all noticeable), however I could imagine doing pano stitches you would really notice it even if it was marginal.
I also came across this old thread about a guy who was having the same problem (although in his case it was the left that was soft and the right that was OK).
It's hard to know what to do. Do I sent this lens back and take the risk I will get another possible worse copy (at least this one is sharp where it is sharp), or live with the fact this one is soft on one side at F4/17mm. Maybe doing these lens tests is a bad idea!!
Graham
Old 11th of December 2005 (Sun)   #5
Jon
Moderator
Cocker Spaniel Mod
Jon's Avatar
First - are you absolutely positive you're set up with the camera square to the wall? Indoors and at wide apertures a slight angle can throw one edge outside the DoF.
Jon
EOS, Powershot and Domke - it doesn't get any better than this!
T90 and stuff | F-1n, New F-1, FTb and more stuff out on loan
Cocker Spaniels
DC Cherry Blossoms
Jon is online now   Reply With Quote
Old 11th of December 2005 (Sun)   #6
gcams
gcams's Avatar
Hi Jon,
Yes indeed, been down that road unfortunately. I have tested this in about 5 different scenarios now (both indoors and out), and have even tried deliberately skewing the camera from parallel in either direction to see if that makes any difference. Regardless, the right hand side of frame is always softer, no matter what I try.
The first time I noticed it, I thought it must be my setup, so I repeated the tests (again and again). In every case and scenario, it's always the RHS that shows up soft. If it was my test setup, I would expect it to switch sides and change in severity depending on the scenario but it's just too consistent, indoors/outdoors, lit from the left/right, etc, makes no difference. The only way I have found to get the RHS close to the LHS is by stopping down, as shown above.
Graham
Old 11th of December 2005 (Sun)   #7
Jon
Moderator
Cocker Spaniel Mod
Jon's Avatar
Have you tested the kit lens at the same time, just as a standard? Might be worth seeing if your camera might have something out of line. It does seem strange that it's happening on two random examples of the lens, which is why I'd try the other lens.
Jon
Cocker Spaniels
DC Cherry Blossoms
Old 11th of December 2005 (Sun)   #8
gcams
gcams's Avatar
Yes I did try the kit lens on several of the scenarios above. The kit lens was soft at both edges () but consistently soft at both edges, unlike the F4L. Below are samples from the kit lens, F4 at 18mm (100% crops as usual):
Kit Lens Top Left Hand:
Kit Lens Top right hand:
By the way, in case I didn't make this apparent, my first copy of this lens was just plain soft all round. This copy is much better but I'm just a tad concerned about the edge to edge consistency.
Graham
Old 12th of December 2005 (Mon)   #9
gcams
gcams's Avatar
Bump.. any other 17-40mm users wish to comment? Anybody else seen this with their lenses?
Graham
Old 12th of December 2005 (Mon)   #10
MDJAK
...the definition of a noob
MDJAK's Avatar
I own this lens and have been very happy with it, until reading this thread and taking a group shot this weekend. The right side of the photo was considerably softer than the left, though I chalked it up to not having the camera square to the group I was shooting. Now, I'm not so sure.
http://i.pbase.com/o4/12/533712/1/53440323._I1A5291.JPG
The little boy on the right is considerably softer than the others, though I know I wasn't square and it's possible he moved.
One more tidbit: My camera is FF so it shows corner softness more readily.
Should have gotten the 16-35 f2.8.
MDJAK is online now   Reply With Quote
Old 12th of December 2005 (Mon)   #11
Jon
Moderator
Cocker Spaniel Mod
Jon's Avatar
Wasn't that the lens that accompanied your 1Ds II on its jaunt on the Sidewalks of New York though?
Jon
Cocker Spaniels
DC Cherry Blossoms
Old 12th of December 2005 (Mon)   #12
MDJAK
MDJAK's Avatar
Shhhh. You don't have to tell the whole world, do you?
I may want to sell it one day.
Yes, in fact it was, but I truly don't believe it suffered in any way from the fall. May seem hard to believe, I know, but I see no difference in it from before. It was always a great lens.
BTW, I didn't even have the lens hood attached at the time of the fall.
Old 12th of December 2005 (Mon)   #13
Jon
Moderator
Cocker Spaniel Mod
Jon's Avatar
Then I'd be inclined to look at some earlier shots and see if they show the same thing, is all.
Jon
Cocker Spaniels
DC Cherry Blossoms
Old 12th of December 2005 (Mon)   #14
gcams
gcams's Avatar
Hi Mdjak,
I hope I don't end up being responsible for you becoming discontent with your 17-40mm F4L Your observations are interesting though. Have you tried the old newspaper test like I did above? It seems to be very good at showing up edge inconsistency. Just a thought!
Graham
Old 12th of December 2005 (Mon)   #15
pfogle
pfogle's Avatar
Just for the record, I tried a s/h 16-35/2.8L and returned it - same problem as described but much worse! Then the same thing with a second one. After that I got a 17-40/4L and it's absolutely fine - not as sharp as some samples I've seen wide open, but much better than the other two, and it is consistent.
From the samples, I'd say return it and keep going 'till you get a good one - they are out there!
___________________________________________
Phil Fogle
5D; 17-40/4L, 24/3.5L TSE, 28-70/2.8L, 50/1.4, Sigma 50/2.8 macro, 100/2.0, 135/2L.
pfogle is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
On The Edge cckarting People 5 24th of May 2007 (Thu) 11:20
White Border or Edge to Edge Printing? Sulis RAW, Post Processing and Printing 7 12th of March 2006 (Sun) 10:10
Dud copy of 17-40mm F4L?? gcams Canon EF and EF-S Lenses 34 15th of December 2005 (Thu) 13:01
