Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > RAW, Post Processing and Printing
Reply
Thread Tools Display Modes
Old 11th of December 2005 (Sun)   #1
Neilyb
Neilyb's Avatar
Unhappy Pixma IP4200 driver probs?
Hi,
Just purchased the above printer for the Girlfriend as she has million of pictures but never prints them. First impressions are that the prints are the best I have seen from an inkjet BUT I am not impressed with the time it takes to get the print to the printer or the fact that prints never arrive....until I restart the computer, then they pop out when windows restarts.
I have tried both USB 1 port and USB 2 ports and the drivers are upto date!
To start with I was getting a Spooler Subsystem error message, so I re-installed SP2 (XP home)....now I get to print off a couple of images and then on the third nothing happens, I can't open the printer properties becasue of some error and I can't re-send the print as I am told there is no printer installed....
I have looked for an updated driver or fix ut there is not one on Canons site. I have mailed Canon support but wondered if anyone else has had thisprobelm?
Shame, as the prints come out looking stunning!
For sale: Kidney, half a lung and maybe an eye. Will consider trade for 200-400 IS L
http://natureimmortal.blogspot.com
http://www.travellinglight.de
Neilyb is offline   Reply With Quote
Old 17th of December 2005 (Sat)   #2
sidraj
Exclamation Re: Pixma IP4200 driver probs?
Hi.
i have just got myself a iP6600D. The prints are absolutely stunning and definitely do a better job than the local photo lab. However, i have a problem that i am not able to install the printer on my iBook G4 with Mac OS X 10.4.3. I am limited to printing images from the memory card as i can insert that in the built-in card reader on the printer.
Will appreciate if someone can guide me if they have faced similar installation problems on a mac. I am not able to get the printer in the "Add Printer" command in the "Printer Setup Utility" even after i have installed the drivers from the packaged CD and then re-installed the latest drivers from the Canon website.
Kind Regards
Sid
sidraj is offline   Reply With Quote
Old 20th of December 2005 (Tue)   #3
vjack
vjack's Avatar
Default Re: Pixma IP4200 driver probs?
I have not had this problem with my 4200. It is also worth noting that I found Canon's tech support extremely responsive in answering the question I had for them.
Canon 20D
Canon EF-S 10-22mm f/3.5-4.5 USM
Sigma 18-125mm f/3.5-5.6 DC
Tamron 28-75mm f/2.8 XR Di LD
Canon EF 50mm f/1.8 II
Canon EF 70-200mm f/4L
Canon EF 100-400mm f/4.5-5.6
L IS
Canon Speedlite 430EX
Manfrotto 3021BPRO; Kirk BH-1 ballhead
Canon Pixma 4200
< see my gallery >
vjack is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
CIS for ip4200 hecya RAW, Post Processing and Printing 0 3rd of February 2007 (Sat) 14:43
Canon Pixma iP4200 - magenta color cast and misalignment moonpanda RAW, Post Processing and Printing 1 30th of August 2006 (Wed) 15:02
Guidance on ip4200 hecya RAW, Post Processing and Printing 0 13th of February 2006 (Mon) 18:54
Canon PIXMA iP4200 - best paper and ink? Neilyb RAW, Post Processing and Printing 8 29th of November 2005 (Tue) 03:03
Thoughts on Canon IP4200 Glyyde RAW, Post Processing and Printing 6 1st of November 2005 (Tue) 12:47
