Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Transportation Talk
Reply
Thread Tools Display Modes
Old 15th of June 2012 (Fri)   #1
CobraGT40
CobraGT40's Avatar
Question Airshow Panning Tips, Please ?
Hey all
EAA AirVenture 2012 is next month and I finally ponied up and got a new camera. My DSC-H50 has done a decent job the past couple years but I've definitely outgrown it. I have just purchased a 600D and 70-300 stabilized lens.
I have tried panning with my old H50 and definitely wasn't so good at it...I didn't like the mechanized zoom. By the time you get it in the frame it's already too late...and you have to pause before zooming back out. Anyways, I know I should be setting a specific spot before taking the photos and keeping the same zoom setting, but there's just so much going on, I guess I don't want to miss anything lol
Could I get a few tips from those with panning experience ? I know practice is a huge factor...I'm actually going to go to the municipal airport today and try snapping a few.
Thanks !
Scott
CobraGT40 is offline   Reply With Quote
Old 15th of June 2012 (Fri)   #2
PhotosGuy
Moderator
PhotosGuy's Avatar
Default Re: Airshow Panning Tips, Please ?
First, I have to move this to "T. Talk".
Or you could try shooting some traffic to warm up.
This should help: First shoot with moving cars need advice.
Shooting airshows in Manual
www.FrankCizek.com
PhotosGuy is online now   Reply With Quote
Old 15th of June 2012 (Fri)   #3
CobraGT40
CobraGT40's Avatar
Thanks !
Sorry about posting in the wrong place...I'll try to keep on the ball !
Scott
Old 15th of June 2012 (Fri)   #4
DC Fan
DC Fan's Avatar
The main "tip" is to keep the subject in frame, of course. That is easier with a DSLR or with any camera that has a reflex optical viewfinder. Cameras such as the DSC-H50 suffer from viewfinder lag, regardless of how well the LCD is designed. By comparison, it's much easier to track a moving subject through an optical viewfinder and using a lens that does not have the delay of an electronic lens.
The other "tip," which involves a technique favored by many members of this forum, is to use a shutter speed that blurs the propellers of prop planes and rotors of helicopters. That's a skill that many photographers find requires some practice, especiallyfor helicopters. Examples:
Focal Length: 439.0mm
Aperture: f/20.0
Exposure Time: 0.020 s (1/50)
ISO equiv: 100
Exposure Bias: none
Metering Mode: Matrix
Exposure: shutter priority (semi-auto)
White Balance: Auto
Flash Fired: No (enforced)
Orientation: Normal
Color Space: sRGB
Focal Length: 370.0mm
Aperture: f/16.0
Exposure Time: 0.010 s (1/100)
ISO equiv: 100
Exposure Bias: none
White Balance: Auto
Orientation: Normal
Color Space: sRGB
It takes practice for many to work out the prop-blur technique because a shutter speed to balance the prop blur and properly expose the passing aircraft is needed, something that's not easy for the long focal lengths used at air shows. A stabilized lens can help.
Hey all
Thanks !
Scott
DC Fan is offline   Reply With Quote
Old 15th of June 2012 (Fri)   #5
CobraGT40
CobraGT40's Avatar
Excellent ! Thanks ! You are absolutely right about the H-50 viewfinder lag...I always found it easier to use the eyepiece to keep the subjects in frame...and the autofocus was a pain in the neck, almost as bad as the mechanical zoom. I've been taking photos...well, notable photos, for the past 7 years or so at airshows and they have been getting progressivley better. Well, better to the point that I have outgrown my camera. I look forward to using this 600D this year...It makes it worlds easier to change shutter speeds. Almost all of my older photos look like they're frozen in time...slowing the shutter speed down will give my photos a little more "life".
Oh, and I just got $200.00 for my DSC H-50 today...should help offset the cost of my new Canon.
Thanks again !
Scott
Aperture: f/20.0
ISO equiv: 100
Exposure Bias: none
White Balance: Auto
Orientation: Normal
Color Space: sRGB
Aperture: f/16.0
ISO equiv: 100
Exposure Bias: none
White Balance: Auto
Orientation: Normal
Color Space: sRGB
Old 15th of June 2012 (Fri)   #6
FlyingPhotog
Cream of the "Prop"
FlyingPhotog's Avatar
You'll find AirVenture images in the 2009, 2010 and 2011 galleries on my website:
http://crosswindimages.com/f844677569
EXIF is available by hovering your mouse over the upper right corner of each image.
Looking forward to AV2012 in just a few weeks!
FlyingPhotog is online now   Reply With Quote
Old 15th of June 2012 (Fri)   #7
rammsteinmatt
If you look at my pictures here, they're decent... I feel comfortable going down to 1/200" at 400mm, 1.5x crop body, 7lb lens. Every day is another day to practice. I take 30k-50k photos a year, aviation only, 6 years now.
you'll need to take more than a few and still probably mitigate your expectations.
there's numerous threads on this subject, just search. Breathing is important too...
The Shinny
Now with more elements in more groups!
Flickr
rammsteinmatt is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Need Panning Tips! jacktompson Motorsports Talk 1 25th of April 2010 (Sun) 10:03
Tips for panning dog shots in a park? JJD.Photography Pets Talk 7 11th of February 2009 (Wed) 10:24
1st Attempt at Panning tomorrow - any last tips/ advice? Big A Motorsports Talk 5 1st of February 2009 (Sun) 15:15
Airshow tips stp72 Canon EOS Digital Cameras 3 22nd of June 2008 (Sun) 10:01
Tips on panning with kit lens? sethmo Transportation 2 18th of September 2007 (Tue) 09:33
