#1 |
To view pictures over the web the picture must be downloaded into the cache of the browser, that's clear.
But to have some protection I have found the following possibilities: 1. Slicing the pictures and encrypting the slice-code with java script, generated , for example, from HTML Guardian http://www.protware.com/ 2. Encrypting the pictures with PTCrypt from PanoTools. To display the pictures you must use the PTViewer java applet. This is possible with the panorama tag in EE. 3. The picture resides in a table as a background image with a transparent gif in front of the real picture. 4. Using htaccess to protect the image directory from direct downloads using www.yoursite.com as referer. |
| sponsored links |
#2 | ||||
El General Moderator
This signature signifies my significance significantly Photo Gallery ---------------------------- |
#3 |
Thank you for your answer, Pekka.
I know you can capture the screen, but with captured low resolution pictures it's not possible to print the picture, for example, in magazines. I have found another explanation and a snippet in php, this version works with transparent gif in a table, htaccess and a session variable for the picture to display: in german: http://www.drweb.de/programmierung/php_bilderklau.shtml copy and paste the link above to translate with Google |
| sponsored links |
#4 | ||
But it gave me some ideas and I actually coded today an additional security setting into EE: now you can choose to totally hide your size paths for the big photos. You see no path at all in source code. EE will fetch those images from selected size path with ftp (very fast), rename them randomly and display the renamed file from gallery/temp/ -folder. Every image viewed will create a new temp image so the cleanup needed is done from e.g. ratio based on list page counter or index page counter (haven't decided yet) so that temp folder does not grow too big. I try to set it so that last X photos are not deleted, even if a chance of a visitor getting an empty photo is simply minimal (image download time is a factor, though). This option is for those who care about hiding their big size folder names from public. If server is average speed and photos are in same server the ftp does not slow page loads at all.
#5 | |
#6 | |
What they have seems to be a javascript <script language="JavaScript" src="includes/js/multifile.js"></script> And the image is loaded by img.php I don't know anything about img.php, but it seems to determine if the image is requested at the same time as the page, and either sends the actual picture, or the dummy "can't display" Multifile.js: I am not even sure if this js file is the one that makes it work, but I don't see anything else. Or even if it is the same/real one (php script sends fake script just as img.php does images) function MultiSelector( list_target, max ){ this.list_target = list_target; this.count = 0; this.id = 0; if (max) { this.max = max; } else { this.max = -1; } this.addElement = function( element ) { if( element.tagName == 'INPUT' && element.type == 'file' ){ this.id++; element.name = "fle_upload[]"; element.multi_selector = this; element.size = "40"; element.onchange = function() { var new_element = document.createElement( 'input' ); new_element.type = "file"; //new_element.class = "file"; this.parentNode.insertBefore( new_element, this ); this.multi_selector.addElement( new_element ); this.multi_selector.addListRow( this ); this.style.position = 'absolute'; this.style.left = '-1000px'; }; if( this.max != -1 && this.count >= this.max ){ element.disabled = true; } this.count++; this.current_element = element; } else { alert( 'Error: not a file input element' ); } }; this.addListRow = function( element ){ var new_row = document.createElement( 'div' ); var new_row_text = document.createElement( 'input' ); var new_row_button = document.createElement( 'input' ); new_row_text.type = "text"; //new_row_text.class = "text"; new_row_text.size = "45"; new_row_text.readOnly = true; new_row_text.value = element.value; new_row_button.type = "button"; new_row_button.value = "Delete"; new_row.element = element; new_row_button.onclick = function() { this.parentNode.element.parentNode.removeChild( this.parentNode.element ); this.parentNode.parentNode.removeChild( this.parentNode ); this.parentNode.element.multi_selector.count--; this.parentNode.element.multi_selector.current_ele ment.disabled = false; return false; } //new_row.innerHTML = element.value; new_row.appendChild( new_row_text ); new_row.appendChild( new_row_button ); this.list_target.appendChild( new_row ); }; }; |
#7 |
A Pekka said, everything you see on the screen can be captured.
So protecting them of being saved is pretty much useless. I disable the right mouse click and the image toolbar for IE, but that keeps only the beginners from storing the pictures. Checking for valid referrers with .htaccess (I do that too), will prevent cross linking pictures from other sites and prevent downloads of single pictures by their direct URL with tools without the ability to pass referrers. You could block specific user agents too (wget, ...). BUT: My primary goal is to protect non public images from public viewers. With my strict file naming convention, it's simple to guess where to find the files on the server, and how the names are. A quick & dirty solution for the current EE could be a separate path for each group of images, proctected by browser authentication with .htaccess and .htpasswd. IMHO the only solution is to move all pictures to a place outside the web tree, and check the access rights of the current user before the delivery. Copy/rename to the temp folder is an interesting solution, but somehow i don't like it. But isn't that available in the current EE release too? In the recent discussion about moving to gallery2, I took a look at it too, and I noticed, it stores pictures outside the web root, and uses a separate function to return the pictures. At least for the thumbnail display, this has a negative impact on performance. So maybe the optimum solution would be to be able to configure how to return the pictures? On a filetype basis (microthumbs, thums, normal, ...) or on exhibition basis, ... Everybody could decide how important the protection from unathorized users was. looking forward to the next EE Martin |
#8 |
In EE 2.0 you have the 1.5's "ftp view". It is an effective way of hiding image path and name. Then you'll have "obfuscate http" switch which makes image links show.php links and fetches the image transparently using http protocol while checking privileges. Because all thumbs are printed with one function, it is very easy to make a separate obfuscate switch for larger images, thumbs and microthumbs - I'll add that to todo list.
Note that EE's Ftp view is the only method which can not be cracked without great effort (anything can be cracked!). An experienced cracker can set up http protocol sniffer and perhaps find the http-obfuscated url that way. Note that EE 2.0 lets you make size path "protected". When it is protected it appears in user editor and you must choose it to give user permission to view it. All others do not see that path at all.
#9 |
being involved with computers and security it's pretty clear that whatever you do someone can beat. The best you can do is only provide low res, low quality online via a save for web thing. That way the photos can't really be made any larger than the size you provide. Digital watermarking is also a good idea. Other than that, no matter how elaborate you get with the code it's nothing a screen capture can't fix.
Urban Photography at its creepiest www.UrbanEden.ws Weapons of choice: Canon 350D [Digital Rebel XT] Canon ultrasonic EF-S 10-22mm wide angle Canon ultrasonic EF-S 17-85mm general purpose Canon 580ex speedlight flash Sunpack QSX 7001DX tripod 2GB CF card 4D cell maglight [aka self-defense club] P100 asbestos respirator |
#10 |
Do NOT disable Right-Click: it can be bypassed.
One method that works very well is stamping the images with user's name on-the-fly before they are downloaded. This approach allows you to know who stole your image if you find a copy floating on the internet or a Peer-to-Peer network. So what's so great about knowing WHO STOLE your image? If you collected their CREDIT CARD numbers, you can charge them!!! You know where they live, etc!!! In practice, this is a strong enough deterrent that people don't steal images, since they are not "anonymous" anymore. Newer generation software can embed visibly and invisibly the user's name into the image. This stamp persists even after screen-capturing, cropping, etc. HTML protector and all the other software mentined in this thread will not prevent screen-capture on FireFox browsers. A company that does fingerprinting as a subscription service is: http://www.catchlock.com/ In addition to fingerprinting, they can also do the run-of-the mill right-click disabling and prevent "save-as" |
#11 | |
Really the best solution is like they said, only put low res images on the server. For me, that is about 1280x960. Maybe for others that is 1600x1200. But keep it low res and if a client or user wants a high res version for printing, you can send it to them via other means, mail, email, scp, sftp ftp, https, etc, etc.... No point wasting a lot of time trying to think of ways to completely protect publicly available content on your server. Now from what I have read here, is it true that EE (not installed on my server right now) is not setup to keep private pictures private? I would like non authenticated users to only be able to access public images, and authenticated users to only access their group of private images. Such as family pictures and client pictures. I have seen some gallery apps that appear to be secure because the app doesn't generate the url or page if you are not logged in. But I tested by bookmarking an image and logged out and I was able to go to another PC and view the page. So obviously it wasn't really protected by any authentication methods. But the ultimate point is, nothing is 100% secure on the internet. Though if someone would make a gallery use 128bit SSL authentication and session based, I think that would be sufficient. In the meantime, if you are really paranoid, then don't put the image online. Only put online what you are comfortable in being stolen. Such as low res images and pictures of family that you don't mind possibly being stolen. But please do take simple measures to prevent images being directly linked from your server, saves bandwidth. And please, slicing and disabling right-click are pathetic. |
#12 | |||
In EE, as I have said, the "ftp retrieve method" is the only way to hide paths completely from access. With it, you can place the image folders outside www root which means you can not open the images in those folders with browser. The ftp method gets the image you need to view in temp folder (with random filename) for a short time, which means if you store the URL it won't be there in few moments. Of course the drawback of this is that it is CPU hungry and bandwith hungry, on fast server you hardly notice it but on slower ones it will make a difference - luckily you can set that up for specific images if you like. Quote:
#13 |
@WarrenO: wrong thread? But your ideas are good!
#14 |
Something we can do, it is better than we do nothing.
#15 | |
If you want to protect the images stored on the server and in cache, consider using encrypted images that are displayed in a security applet. I'm surprised the option is not mentioned here because its been available since 1998. If you want to further protect images from screen capture and printscreen, that solution is also available. Of course there are workarounds to these solutions, but they have been the most secure solutions available since 1998 and it doesn't get better... no-one has comparable solutions despite their claims to the contrary. Banks and online surveys use these solutions and they are the best available! Want to know more? Romp on over to their demo site at www.artistscope.com |
| Thread Tools | |
| Display Modes | |
| Need some HELP & Hints! | jemmi00 | People | 1 | 27th of November 2006 (Mon) 18:46 |
| Manfrotto 3047/029 - ideas how to protect rubber grips? | DocFrankenstein | Accessories & Storage | 1 | 1st of April 2005 (Fri) 11:57 |
| Any Hints | russell2 | Critique Corner | 3 | 22nd of June 2003 (Sun) 20:19 |
| How to protect your lens while taking pictures in the rain? | ndee | Canon G-series Digital Cameras | 8 | 13th of June 2003 (Fri) 21:49 |
| How to protect yourself while taking pictures in the street | new girl on the bloc | Canon G-series Digital Cameras | 4 | 13th of June 2003 (Fri) 10:01 |
