#1 |
I have managed to get my self the canon 7d and a 85mm 1.8 lens, I have setup c1 using a settings guide I found on sportsshooter.com
Yesterday I took some shots of friends training kick boxing, one thing I noticed is that some of the punches turned out with motion blur Can anyone give me some pointers or advise which settings would be ideal to change to help capture a clean shot. If there's any more info you need please ask |
| sponsored links |
#2 |
post a sample picture with EXIF
For Sale: 1D Mk III, 1D, T1i, 800mm, 600mm 5D3, 1D4, 7D, 600/4L, 200/1.8L, Sigmonster 300-800mm, 80-200/2.8L MDP, 28-70/2.8L, 85/1.8, 50/1.4, 12-24mm, (4) 550EXs, (4) WL strobes, PW MiniTT1/FlexTT5s/AC3/AC9s LoCo-Photo.com, MaxPreps |
#3 |
Use strobes. |
| sponsored links |
#4 |
How did you shoot it? Full auto? Aperture priority?
Nikon D3s / D3 / D300 / 17-35 2.8 / 70-200 2.8 / 400 2.8 My Images with Getty My Sportsshooter Page My Website |
#5 |
Motion Blur = Shutter too slow
Dave Hoffmann |
#6 | |
Examples: ![]() Focal Length: 118.0mm Aperture: f/2.8 Exposure Time: 0.0013 s (1/800) ISO equiv: 3200 Exposure Bias: none Metering Mode: Matrix Exposure: shutter priority (semi-auto) White Balance: Auto Flash Fired: No (enforced) Orientation: Normal Color Space: sRGB ![]() Focal Length: 50.0mm Aperture: f/1.8 Exposure Time: 0.0005 s (1/2000) ISO equiv: 2500 Exposure Bias: none Metering Mode: Matrix Exposure: Manual Exposure Mode: Manual White Balance: Auto Flash Fired: No (enforced) Orientation: Normal Color Space: sRGB The combination of a Canon 7d and an 85mm 1.8 lens will be able to handle just about any low-light indoor situation (and nearly all indoor situations will be low light) with an effective shutter speed to stop motion, but finding that shutter speed won't come from using settings found on a web site. Rather, it will be necessary for consistent success to acquire and use a separate light meter, to measure the light at each event. These meters can be expensive, but fortunately there are a few reasonably priced units that are available. Using a light meter to take wht is called an incident reading, or a measurement of the light that falls on a subject, is a standard procedure when photographing an indoor event where you must use available light. Learning how to do this is just one of the many steps needed to become an effective photographer, even in situations you can not control. No, even a very good camera and lens will not be enough in some situations. What you experienced is one of the many circumstances where you'll need to learn how to use the light you have available with the equipment you have at hand. |
#7 |
Phil Zivnuska Gear List www.zivnuska.zenfolio.com "It's not tight until you see the color of the irides." |
#8 |
#9 |
I'm not an expert, but I shoot a lot of indoor volleyball, so maybe I can help you. Set your camera to manual (M). You have excellent shutter speed on that lens, so bump it all the way down to 1.8. For an indoor sport with motion blur you will need to be up around 1/600 or more if possible. You will also have to bump your ISO up to get the light you want. You will have to play with the aperature and ISO until you are happy with the results. Just make sure you get the most out of that lens.
If you are really new, set the camera to no flash. Take a picture and then go in and view the photo and it's details. If you pull the picture up on your camera you can get the ISO and aperature by pressing the info button. I hope this helps. If anyone find my information wrong please post, because I, too, can use all the help I can get. |
| Thread Tools | |
| Display Modes | |
| Shooting Indoor Sports With 85mm f1.2II | Photoman65 | Sports Talk | 19 | 3rd of February 2010 (Wed) 22:28 |
| First time shooting indoor sports... | TheReal7 | Sports | 5 | 12th of February 2008 (Tue) 08:33 |
| Shooting indoor sports under different lighting | glitterdog | Canon EOS Digital Cameras | 5 | 14th of March 2007 (Wed) 10:54 |
| I need indoor sports shooting help | donmash | Canon EOS Digital Cameras | 5 | 12th of January 2005 (Wed) 18:34 |
| Shooting indoor sports??? | mmaphotog | Canon EOS Digital Cameras | 5 | 21st of May 2003 (Wed) 19:42 |
