Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Macro Talk
Reply
Thread Tools Display Modes
Old 3rd of July 2012 (Tue)   #1
BasAndrews
BasAndrews's Avatar
Default MPE focus tests.
It seems I am not the only one who has had issues with the MPE and potentially soft focus.
To help those who also may be affected I suggest posting or a link to a set of standard shots to compare the lens with different settings. If those who do not suffer this issue have the time and inclination to post cropped images at 100%, it would be useful to compare, and much appreciated.
My attempts are in a set:
http://www.flickr.com/photos/basandr...7630406887062/
All the MP-E shots were taken on a crop sensor (600d).
There are examples of the same subject at 1x, 2x and 5x at F13 and F7.1. Each has been posted as a normal shot and also cropped at 100%. There is also a shot at approx 2x using the tamron lens and tubes. That is to compare the softness with the same settings between lenses.
100% crop at 1:1 F13
MPEx1F13-crop by BasAndrews, on Flickr
100% crop at 5x F7.1
MPEx5F7.1-crop by BasAndrews, on Flickr
Bas I'd give my right arm to be ambidextrous.
BasAndrews is offline   Reply With Quote
Old 3rd of July 2012 (Tue)   #2
Canon Bob
Default Re: MPE focus tests.
Having a shot library of a standard subject isn't a bad idea Bas, but I think going for a crop % (100% in your request) will be misleading. The relative pixel density of the different bodies will result in output magnification changes.
A full frame sensor will show a 7.2mm wide frame at maximum magnification. Cropping the image to 0.5x will frame 3.6mm and cropping APS-C to .75x will yeald the same (0.64x for APS-H bodies)
This way we'll see all images at the same final magnification irrespective of pixel count.
I hope that was clear and the reasons understood.
Bob
1Dx (2), 1D4, 5D2 (IR)>> EF600L, EF400L, EF300L, EF300L, EF200L, EF200LII, EF180L, EF135L, EF100L, EF85LII, EF50L, EF35L, EF24LII, EF24-70L, EF24-105L,
TS-E24LII, TS-E45, TS-E90, MP-E65, EF135SF, Zeiss 15/2.8, 21/2.8, 25/2, 28/2.8, 35/1.4, 35/2, 50/1.4, 50/2, 85/1.4, 100/2, T/C's, L-SC and a WIFE!
Canon Bob is offline   Reply With Quote
Old 3rd of July 2012 (Tue)   #3
alquimista
first of all thank you Bas for staring this tread, I will also do a series of pictures using the different magnification distance you have used on your images, however I'm interested on what Bob posted about the difference between crop and full sensors. Bob honestly I'm not great at doing the math; is there a way you can give us a number we should be saving our images at? Pixel count at x dpi so that all images equal out to the same percentage, is there a formula such as camera megapixel times or divided by x that will give us the ratio we should save the image at? Thank you in advance for your input
la costura de Dios
http://www.flickr.com/photos/andresmoline/
alquimista is offline   Reply With Quote
Old 4th of July 2012 (Wed)   #4
BasAndrews
BasAndrews's Avatar
Thanks Bob, but the main aim of this was to see the clarity of the subject, so we can compare how the detail of the image varies at different magnification. If it works out that images are clearer on a FF sensor then that is useful info.
My perception of the pictures above is that the shot at 5x does not give any individual area that is sharp focus, whereas the image at 1:1 is fine even at 100%. OK the D0F will play a large part, but there should be some part of the image that is crisp. If anyone else perceives that differently then please say so, part of the problem could simply be that what I see at 100% is what is expected.
Comparing the two lenses I use at similar mag:
Tamron at 2x
tamronx2f13-crop by BasAndrews, on Flickr
MP-E at 2x
MPEx2F13-crop by BasAndrews, on Flickr
OK the lighting is different, but the image from the Tamron lens looks slightly better to me. I will try a session using the same body and flash and change the lens to really see the difference.
Old 4th of July 2012 (Wed)   #5
Martin G.
Martin G.'s Avatar
Bas, did you use a tripod? What measures did you take to ensure there is absolutely no motion blur?
6D & 50D
EF 24-105 L, EF 100mm L IS, MP-E 65
Macro Twin Flash MT-24EX, 430 EX II & 270 EX
Martin G. is offline   Reply With Quote
Old 4th of July 2012 (Wed)   #6
Overread
Overread's Avatar
You might find this of interest:
http://www.flickr.com/photos/2453447...7623350445656/
On the far left is a full description of what I did for those tests. From what I can tell you're not so much testing focus as you are the ultimate possible sharpness of the lens itself. Remember this is a tricky thing, different MP cameras will show different views at 100% (typically the more MP the more enlarged a photo is at 100% view and thus the softer the results might appear to be, even though they are equally if not better when resized for normal use).
In addition I prefer test shots for sharpness to be akin to the kind I shot there; a rough 45 degree angle to a detailed flat surface. That means that you remove the problem of accidentally missing the focus, even if by a touch. You'll always get a proper clear band of in-focus coin in every single shot. Making it easy to perform the test and to see the sharpness.
My biggest test error would probably have been that I didn't have the flash fully fixed in position - a fixed light source, fixed coin and stable tripod for the camera would all help accuracy of the test (in short ensuring an even level of contrast in all photos).
edit -
http://www.flickr.com/photos/2453447...7623359678512/
a 1:1 test between the MPE - Sigma 70mm and 150mm macro lenses
Tools of the trade: Canon 400D, Canon 7D, Canon 70-200mm f2.8 IS L M2, Sigma 120-300mm f2.8 OS, Canon MPE 65mm f2.8 macro, Sigma 150mm f2.8 macro, Sigma 70mm f2.8 macro, Sigma 8-16mm f4.5-5.6, Raynox DCR 250, loads of teleconverters and a flashy thingy too
My flickr
The Wildlife Project
Overread is offline   Reply With Quote
Old 5th of July 2012 (Thu)   #7
BasAndrews
BasAndrews's Avatar
First, thank you all for the assistance and comments.
Martin, these were taken handheld (lens resting on a table with the subject on the same table). I originally tried a set with the tripod but it was taking forever to set up each shot.
As the percieved problem is ay higher mag, I will try the coin shots (if I have any left after buyng the lens ) using mirror lockup on a tripod.
Thanks overread, much appreciated.
Old 5th of July 2012 (Thu)   #8
alquimista
Wow this is getting good! I'm going to be setting up my gear tonight and do the test, will be posting results soon, will do the coin shot.
la costura de Dios
Old 6th of July 2012 (Fri)   #9
AbPho
AbPho's Avatar
Try to keep your effective aperture no smaller than f/22 or your going to get a hugh quality hit due to diffraction.
effective aperture = nominal aperture * (magnification + 1)
so, your 1:1 at f/13 = 13*(1+1) = f/26. Not bad
5:1 at f/7.1 = 7.1*(5+1) = f/43. Not so good.
At 5:1 on the MP-E use f/4. It's a lot sharper than at f/2.8 and you get a (very) little bit more DOF. Your DOF is going to be around 60µm. Not very much.
I'm from Canada. Isn't that weird!
Website
flickr
AbPho is offline   Reply With Quote
Old 8th of July 2012 (Sun)   #10
Lester Wareham
Moderator
Lester Wareham's Avatar
What apature are you shooting at Bas, I don't stop down any more that f/8 at 2:1 and above. At 4:1 or 5:1 I might open up to f/5.6.
All this is to avoid difraction, but of corse you are trading dof for peak sharpness.
My Photography Home Page RSS Feed
MP-E, EF 100mm, EF 180mm : The Macro Dark Unholy Trinity : Bow down before their darkness and despair!
Macrophotography by LordV
Lester Wareham is offline   Reply With Quote
Old 8th of July 2012 (Sun)   #11
Lester Wareham
Moderator
Also be aware diffent lenses will have different pupilary magnications. This means the effective apature at the same magnification will be different.
See http://www.zen20934.zen.co.uk/photog...ro_Photography
Old 8th of July 2012 (Sun)   #12
BasAndrews
BasAndrews's Avatar
Excellent information Lester and abpho, thank you. I was not aware of the different effective aperture at the same mag. It seems maths gets in the way of everything in photograhy
Bob from the the forum kindly sent me some shots taken at the same mag and aperture (but on a IDMKIV) and the shots were noticebaly clearer. That leaves the camera, lens or technique on my end as being a problem.
I do not believe the camera is an issue, so it is me or the lens. To be sure I may hire a lens and then I can put the blame squarely on my shoulders if there is no difference. BTW this does not stop me using the lens, most of the really naff shots are obviously me and I can get some pleasing results, so I am just attempting to get the best I can from the gear and also fix whatever it is that I do wrong when taking my shots.
Old 8th of July 2012 (Sun)   #13
alquimista
thanks for the Info Lester! and thank you Bas for starting this tread, I had family issues this week and was not able to do any shooting or testing all the information posted here is of great help and Im sure will help me improve my shooting
la costura de Dios
Old 8th of July 2012 (Sun)   #14
Lester Wareham
Moderator
No probs.
I did do some relative sharpness tests on various macro solutions using a bank note as a target. Of course getting the same bit of the note and ideal focus is very hard for getting criticle results.I used an angle finder C at the time because the body I was using did not have live view.
These are here but only include life size I think, but do include a range of set f-stop.
Old 8th of July 2012 (Sun)   #15
Canon Bob
....Of course getting the same bit of the note and ideal focus is very hard for getting criticle results......
For higher magnification tests, (5x-20x) I've used an Emery board (disposable nail file), and it becomes quite intuitive. Trying to keep it perpendicular is a challenge but any errors are obvious with a shift of the region in focus to one side or the other,
Bob
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Best performance/focus tests for 7d mulchie Canon EOS Digital Cameras 5 1st of March 2011 (Tue) 07:48
Focus Tests robertnzana Canon EOS Digital Cameras 5 19th of December 2010 (Sun) 06:21
Need help with my MK III Focus Tests morehtml Canon EOS Digital Cameras 27 5th of August 2007 (Sun) 17:53
Focus tests. Wrench Canon EF and EF-S Lenses 1 17th of December 2005 (Sat) 18:21
70-200 4 L Focus Tests yb98 Canon EOS Digital Cameras 3 13th of July 2004 (Tue) 19:28
