Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Transportation Talk
Reply
Thread Tools Display Modes
Old 7th of July 2012 (Sat)   #1
spitfire IX
spitfire IX's Avatar
Default AIRSHOW PHOTOGRAPHY
Hi , am new to the world of aviation photography and would welcome any tips or advice that you could share with me . Focus seems to be an issue for flying shots at airshows . Is it best to use Auto Focus or Manual . Also trying to master getting correct exposure of aircraft against bright skies and cloudy ,dark skies . Any advice would be very gratefully received . Thanks .
spitfire IX is offline   Reply With Quote
Old 7th of July 2012 (Sat)   #2
PhotosGuy
Moderator
PhotosGuy's Avatar
Default Re: AIRSHOW PHOTOGRAPHY
A few threads below yours is one titled, "Airshow Tips Needed"
www.FrankCizek.com
PhotosGuy is online now   Reply With Quote
Old 10th of July 2012 (Tue)   #3
Valencia Photography
Valencia Photography's Avatar
I think the hardest part is getting a good spot! If you can get there early and get a seat near the center of all the action, that can be better than all the other things you try.
- 5d MkII - 28mm f/1.8 - 50mm f/1.8 II - 85mm f/1.8 - Tele-Lentar 135mm f/3.5
- Canon S95 -
Valencia Photography is offline   Reply With Quote
Old 10th of July 2012 (Tue)   #4
jwol
jwol's Avatar
Getting to the show early and staking a claim to your chosen spot is not a bad idea. That said, the center may not be where you want to be. Consider your light source first before picking a spot. Think about the sun's path through out the day. Which part of the flight line will keep the sun at your back, as you shoot, for most of the show? I often find myself photographing from the far end of the flight line. There are apps, if you have a smart phone, that will show you the sun's path over a given location, on a given date. Other things to consider might be, being close to the hot ramp to catch action on the ground, or being near a taxi-way where you may catch planes taxing head-on towards you.
The other option is to move through out the day. The down side is that you'll more than likely be behind the crowd. Your choice of location will ultimately depend on the sun and what your photo goals are.
John Lackey
Fly By Photography
Blog
Radial engines don't actually leak oil, by the way. They just mark their territory!
jwol is offline   Reply With Quote
Old 10th of July 2012 (Tue)   #5
watt100
for the air shows I've attended getting the spot doesn't matter, the planes are high in the sky and almost any position on the ground will work
watt100 is offline   Reply With Quote
Old 11th of July 2012 (Wed)   #6
FlyingPhotog
Cream of the "Prop"
FlyingPhotog's Avatar
Um...
FlyingPhotog is offline   Reply With Quote
Old 12th of July 2012 (Thu)   #7
PhotosGuy
Moderator
PhotosGuy's Avatar
Originally Posted by FlyingPhotog View Post
Um...
www.FrankCizek.com
Old 12th of July 2012 (Thu)   #8
watt100
Um...
ummmm ...
Old 12th of July 2012 (Thu)   #9
jwol
jwol's Avatar
Yep, depends on what your photo goals are. Its nice to be able to go to an airshow on multiple days so you can shoot different subjects. Getting to the show early also means fewer people wondering around the static displays. Typically, when gates open most of the folks around the statics are fellow photogs. . .
but not always.
John Lackey
Fly By Photography
Blog
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
NY Airshow Photography Event Derf Transportation Talk 10 16th of April 2011 (Sat) 09:40
Airshow photography Skyraider3D Transportation 42 18th of September 2006 (Mon) 13:53
Airshow photography timstudholme Canon EOS Digital Cameras 5 10th of April 2006 (Mon) 23:47
Airshow Photography crazyfoo88 Canon EOS Digital Cameras 31 13th of December 2004 (Mon) 07:30
Airshow Photography Skids Canon EOS Digital Cameras 20 18th of July 2004 (Sun) 08:53
