Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > The POTN Lounge
Reply
Thread Tools Display Modes
Old 10th of July 2012 (Tue)   #1
nekrosoft13
nekrosoft13's Avatar
Default Water Proof Camera
Can someone recommend a good water proof camera? doesn't have to be for deep see diving, 10meters or so is more then enough.
doesn't have to be made by Canon,
nekrosoft13 is offline   Reply With Quote
Old 11th of July 2012 (Wed)   #2
Keyan
Keyan's Avatar
Default Re: Water Proof Camera
There are a bunch out there. I have a Panasonic that used their 14 megapixel sensor and it is all kinds of soft and noisy, the new version went back to a 12 megapixel CMOS sensor which I think is much better. So far it hasn't leaked in over 2 years of use at least, so the seals are good.
Camera Kit: 60D, S100, 17-55 f/2.8 IS USM, 18-135 IS, 50 f/1.4 USM, 55-250 IS, 2x 430 EX II, 70-300L IS USM
Other Stuff: Luma Labs Cinch, Satechi RF Trigger, Stofen Omni-Bounce, Lowepro Fastpack 100 & 350
Keyan is offline   Reply With Quote
Old 11th of July 2012 (Wed)   #3
rick_reno
i've used a Panasonic TS3, it was orange and about 12mp from what i recall. Worked very well.
rick_reno is offline   Reply With Quote
Old 14th of July 2012 (Sat)   #4
Tpfer
Canon S95 and Canon WP-DC38 Waterproof Housing
Tpfer is offline   Reply With Quote
Old 16th of July 2012 (Mon)   #5
nekrosoft13
Didnt look into housings. Doesnt that make it really bulky?
Old 17th of July 2012 (Tue)   #6
Tpfer
It is just the right size. It has all the controls on the outside so you can change every setting. Even with the case it will be smaller than a DSLR.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Best water proof compact camera suggestions? selvage Small Compact Digitals by Canon 18 16th of November 2011 (Wed) 05:44
Water Proof Camera? jacobsen1 Canon EOS Digital Cameras 2 31st of July 2006 (Mon) 22:45
Water proof case with impact of water. cA70 Small Compact Digitals by Canon 8 19th of April 2004 (Mon) 18:50
