Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Astronomy and Celestial Talk
Reply
Thread Tools Display Modes
Old 12th of July 2012 (Thu)   #1
Alex.K
Alex.K's Avatar
Exclamation Wireless remote: Star Trail help!
Okay, so I'm really wanting to try my hand at shooting some star trails.
I own a canon 5D classic. I'm trying to find a wireless remote(I assume wireless is better?) but on this blog I saw they recommended also getting one that locks the shutter. Is that needed? What do y'all use?
I'm not going pro in it, so I don't want anything super $$$, but something that will be good and get the job done.
I really know nothing about this type of photography(going to try and do some research before I go out!) so just looking for some help here!
thanks all!
Alex
Alex.K is offline   Reply With Quote
Old 12th of July 2012 (Thu)   #2
cyberon
cyberon's Avatar
Default Re: Wireless remote: Star Trail help!
Wireless is not required. You want a timer release as it's better to take multiple shots then stack them to reduce background light especially if you live in a less than perfect light polluted area.
500D, Speedlite 430EX II, Lens : 15-85mm; 50mm F1.8 II; 100mm F2.8L IS Macro; 70-200mm F4L; Samyang 8mm F3.5
U/W : G11, OEM Housing, Inon S2000, Inon D4 Tray, Inon UCL-165 Close up lens
Astro : Modded 1100D, ES 80ED, Skywatcher HEQ5 Mount, Astrotrac TT320X-AG, Astronomik CLS Clip in filter
cyberon is offline   Reply With Quote
Old 12th of July 2012 (Thu)   #3
Alex.K
Alex.K's Avatar
Okay. Do most have a lock shutter ability? I was planning on shooting 30sec exposures(or so) and stack in photoshop, but I don't want to stand next to it and hold down the button for who knows how long.....
Old 12th of July 2012 (Thu)   #4
SteveInNZ
Even though I have numerous means of holding the shutter open, I tend to use the super cheapest cable release and lock the shutter button on 30 sec exposures. Don't forget to put the camera in repetitive shot mode.
If you want to be even cheaper, you can use a small wad of paper and a rubber band to hold it on the shutter button.
"Treat every photon with respect" - David Malin.
SteveInNZ is offline   Reply With Quote
Old 13th of July 2012 (Fri)   #5
Tschnitker
I bought a $45 timer from BH photo (their website is down otherwise I'd get the brand) that does everything I need it to. It's got a manual button with lock. It's backlit and I can adjust the following.
Exposure time.
Time between exposures.
# of exposures to take
Delay before first exposure
Personally I hate wireless, I had one on my old nikon that was IR only and it was a huge PITA.
My belief: More Photo, Less Photoshop.
http://ngm.nationalgeographic.com/yo...t/manipulation
Tschnitker is offline   Reply With Quote
Old 13th of July 2012 (Fri)   #6
cyberon
cyberon's Avatar
All generic ones with timer does that, you don't have to pay $45 most on ebay sells for around the $20+ mark!
Old 13th of July 2012 (Fri)   #7
Alex.K
Alex.K's Avatar
awesome! Thanks all! I got one off of ebay. Wired, works with the 5D locks the shutter...it was like $15 so if it doesn't work I didn't waste toooo much money. haha.
Now I'm off to do some more research on how best to shoot startrails....at a beach!
Old 13th of July 2012 (Fri)   #8
Tschnitker
If you mean ocean beach you might get some problems with mist in the air and ruining the shot, it can also coat your lens after a while too. Really depends on conditions but it's something to consider.
Old 14th of July 2012 (Sat)   #9
Alex.K
Alex.K's Avatar
Fresh water beach. I'm 6miles from Lake Michigan. Hopefully mist isn't bad. :-\
Old 17th of July 2012 (Tue)   #10
calypsob
calypsob's Avatar
I got a wireless vivitar for 6 bucks and its all you need.
Wes
Gear: canon t3i / 600d, 18-55mm kit, tokina 11-16mm, reversed: pentax-A 28mm, sigma APO 70-300, Sigma UC 70-210mm, Carl Zeiss 8x30b
calypsob is offline   Reply With Quote
Old 17th of July 2012 (Tue)   #11
Tschnitker
If the waves are crashing and you are shooting Michigan expect some mist, but if it's just an average lake you shouldn't run into any problems other than insects.
If you are shooting on the beach, make sure to dig down where the tripod feet will rest, then jam them into the sand well and re-bury them for stability. Don't be near the camera when you are taking pictures on a beach as the vibrations will travel a little ways. Afterwards just give your tripod a quick rinse in the lake or whatever your choice is to get the sand out. I've done this for years with a cheap tripod and saltwater with no ill effects yet.
Old 17th of July 2012 (Tue)   #12
Alex.K
Alex.K's Avatar
The lake has been very calm these past few weeks, so I expect a calm night, but well...Michigan can be a bit unpredictable. haha.
Thanks so much for the tips!
Old 17th of July 2012 (Tue)   #13
SteveInNZ
Not if you have a 5D.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
... b & w Star Trail ... liewwk Nature & Landscapes 2 11th of October 2011 (Tue) 19:38
Star Trail Hotsauce Astronomy and Celestial 4 2nd of August 2010 (Mon) 17:38
My First Star Trail Name Pending... Astronomy and Celestial 15 11th of April 2010 (Sun) 15:39
First Star Trail Pseudonym Astronomy and Celestial 13 28th of July 2009 (Tue) 20:12
Star trail Lawnboy Wildlife 9 13th of July 2008 (Sun) 14:37
