Thread started 13 Jul 2012 (Friday) 18:34
Eyepiece Extender for 7D, 5D Mark III
tvphotog
Jul 13, 2012 18:34 |  #1
I found an excellent extender, after market, for the two cameras where there's a need to get your nose off the LCD screen. It's about time someone did this.
This one is available on Amazon (external link) and on eBay for about the same price of $15, which is very good compared to the OEM piece...if it existed. The advantage of the Amazon piece is that it comes with a microfiber cloth for use anywhere.
This one comes in two pieces, which in the picture are assembled. The outer piece is almost identical to the OEM Canon eyepiece. The inner one, next to the camera body, contains lenses that will distort and reduce your view. Combined, the two pieces are about 1 mm thicker than the Canon EP EX II and eyepiece combination which I have on my 5D2. The extender really takes your nose off the LCD on both the 7D and the 5D3.
I found the best way to use it is to slip the two pieces apart, and remove the two Philips screws that hold a shim which then holds in the lenses. Pop out the lenses, throw them out, and reassemble with the screws and re-slide the pieces together. You can easily still see all four corners of the screen without any size reduction or distortion.
I put two small pieces of gaffer tape between the two pieces of the extender, and on the back of the extender piece which touches the body. That really stops the movement of both on one another, and makes a really firm extender, that can still be removed from the body if you want. Use gaffer's tape, not duct tape. The latter has glue that will stick to whatever it's on when the tape is removed.
PHOTOBUCKET EMBEDDING IS DISABLED BY THIS MEMBER.
Photobucket sends ads instead of embedding photos from their free galleries.
Click the link (if available) below to see the image in a gallery page.
http://i17.photobucket​.com …b87/maxselma/IM​G_1959.jpg (external link)
http://i17.photobucket​.com …b87/maxselma/IM​G_1960.jpg (external link)
http://i17.photobucket​.com …b87/maxselma/IM​G_1961.jpg (external link)
Jay
Ireland in Word and Image (external link) Jay Ben Images (external link)5D IV | 5DS/R | Powershot S100 | 24-105L | 100-400 IIL | 16-35 f/2.8 IIL | 24 T/S f /3.5L II | 17 T/S f/4L | 50mm f/1.2L | 35mm f/1.4L | 70-200 f/2.8L II | 580 EX II | 600 EX-RT | Feisol 3441T/Markins Q3T lever QR | Gitzo 3542L Markins Qi20 BV-22 | Gitzo 5561T RRS MH-02
klr.b
Jul 14, 2012 00:59 |  #2
I bought one of these back in April. It was only $12 back then, so I took a shot. I would rate the quality as worse than the Canon extenders. If you look closely, you can tell that it doesn't quite match the camera body. The optics were lousy compared to Canon. Just for kicks, I tried cleaning the lenses. There was no difference. I would compare it to smudgy hand prints on a window. I saw this as a moot point since I (and most people) would remove them anyway. If you need the reducer lenses, I would think twice about purchasing. If just want to extend your eyepiece a bit, it's fine.
I was hoping to use this extender with my HoodEye, but they're not compatible out of the box. You have to cut a ridge and grind off a lot of material on the extender. It's a bit of work, buy you can get them to fit together.
gordon
Gear and Feedback
julius071
Joined Feb 2012
Jul 14, 2012 05:12 |  #3
Well I hope canon comes up with something because I hate to clean my LCD everytime I take a shot.
Capturing moments one snap at a time.
Andrew_WOT
Jul 14, 2012 11:51 as a reply to  @ julius071's post |  #4
HoodEye Eye cup
IMAGE: http://www.hoodmanusa.com/images/hoodeye1.jpg
tvphotog
Jul 14, 2012 12:38 |  #5
Andrew_WOT wrote in post #14715740 (external link)
HoodEye Eye cup
Blocks the LCD; must rotate and then miss the vertical shot. Good idea, poor execution, IMO.
Jay
Andrew_WOT
Jul 14, 2012 14:35 |  #6
tvphotog wrote in post #14715869 (external link)
Was that your experience?
I am quite surprised as I've never had to rotate if for vertical shots as rubber is very soft and just molds around eyebrow. You can twist it if you want to but I personally have never felt the need for it. Yes, at straight on angle of view it block tiny pinch of the LCD edge, again, never found it bothering me a tiny bit, shoot in Live View with it on all the times.
tvphotog
Jul 14, 2012 16:42 |  #7
klr.b wrote in post #14714319 (external link)
I wasn't concerned with whether it matches the contour of the camera exactly, but that it got my nose off the back of the camera. And it's only off in the upper left corner, otherwise it fits perfectly.
You should not even consider leaving the lenses in place.
Jay
KRUSH
Jul 15, 2012 16:09 |  #8
How difficult is it to get those phillip screws out of the EP-EX15 II?
I tried and found it to be very difficult. I imagine it would be the same for this piece.
The presence of the observer changes the nature of the observed...
Canon EOS 5D Mk II | Gear List & Feedback
For Sale: Canon S5 IS |
tvphotog
Jul 15, 2012 16:21 |  #9
KRUSH wrote in post #14720456 (external link)
Very easy, but I have a set of watchmater Phillips screwdrivers.
Jay
pbelarge
Joined Jun 2010
Jul 15, 2012 18:46 |  #10
The part blocking the LCD is not really necessary for the function, and can be trimmed slightly.
I do not rotate it when I shoot vertically, so far it has not been terribly inconvenient.
I like the Hoodman eyecup, it works very well for me (I wear glasses) and blocks the sun from interfering with my seeing the viewfinder properly. I liked it so much on the 7D, I bought one for the 5D3.
They are quite pliable as well.
One issue which I do not like about it though is when I use my top entrance shoulder bags - I wonder how long it will hold up to the putting it in/taking it out and rubbing against the zipper?
just a few of my thoughts...
Pierre
JakAHearts
Gallery: 6 photos
Jul 16, 2012 13:36 |  #11
Same here. I dont rotate mine and rather enjoy it. I might trim the bottom as sometimes its in the way a bit when trying to view the LCD but it hasnt been annoying enough to do so.
Shane
Andrew_WOT
Jul 16, 2012 15:17 |  #12
JakAHearts wrote in post #14724612 (external link)
The blocked part (the very edge of LCD) usually doesn't have anything critically important and if it does, simple angle of view adjustment let you see what's there. On portrait with landscape orientation, they could as well just made eye cup round, it would continue functioning the same, it's equally comfortable rotated or not.
JakAHearts
Gallery: 6 photos
Jul 16, 2012 15:36 |  #13
I agree. Sometimes if youre in sunlight, its not possible to tilt it, but ya know, nothing is perfect. :D
Shane
julius071
Joined Feb 2012
Jul 19, 2012 23:54 |  #14
This eye from OP is great! It was very tight once I put it on, shaved some plastic off and now it fits like a glove. No more nose smashing into my 5d Mark III!!!
Silverstonev8
Joined Jun 2011
Jul 20, 2012 18:14 |  #15
julius071 wrote in post #14742948 (external link)
Agreed. Mine was delivered yesterday...
Chris -- Gear List
10,000 views & 0 likes for this thread
Latest registered member is jainlemos
768 guests, 428 members online
