#1 |
hi all , am still beginner in this type of photography , i saw many shots for the stars within the city or as landscape shots , i watched and read some tutorials to learn how to capture such shots , but still couldnt achieve it , whenever i use high iso , 3200 for example , f/3.5 and 30s shutter i still get white pic , without any details , so is there is any clear tutorial that i can learn from ?
does any one have a pic showing the stars before blending it with another shot ? thanks for helping
| sponsored links |
#2 | |
Wes ----------- Gear: canon t3i / 600d, 18-55mm kit, tokina 11-16mm, pentax-A 28mm f/2.8, sigma APO 70-300, Sigma UC 70-210mm, Carl Zeiss 8x30b |
#3 |
thank you so much for the reply
actually i tried that but still couldnt see the stars clearly , either i get just the foreground or an overexposed pic just an example to what i mean : http://www.abinali.com/abinali/pics/..._4J6J6822s.jpg http://a5.sphotos.ak.fbcdn.net/hphot...97064213_n.jpg
| sponsored links |
#4 |
Those two have probably cheated (the second one I'm 100% sure, the first one not so much). For that second photo, he took the sky separately and then photoshopped it back in. That kind of shot requires stacking a bunch of short exposures and is quite a bit of work. You won't get a picture like that with a single exposure.
Fuji X-E1, 18-55 zoom |
#5 |
Oh ok yea the second one is definitely multiple stacks, you cant see stars like that above a city because there is too much light pollution so that is complete photoshop trickery. In the first image if he is using a 5D3 he could pretty much shoot at ISO 12,800 without noise. I do see some star trails in the top left corner which tells me that he did a long exposure. Try these settings for a similar shot. ISO 100, aperture of f/5.6, shutter speed set to bulb exposure; you will need a remote to do this. Expose 1 shot for 50 seconds if under exposed then go to 70 seconds then 120 seconds until you overexpose again. Once you overexpose start to cut back 10 seconds until you have a good exposure. You will get some star trails but they will be small, similar to the first image you posted. If the city is still out of focus after all of this then try increasing the aperature to f/8. As you increase the aperture you will have to expose the image longer because the hole the aperture makes gets smaller and smaller letting in less light but allowing more DOF, depth of field, to come into focus. Hope this helps.
Wes ----------- Gear: canon t3i / 600d, 18-55mm kit, tokina 11-16mm, pentax-A 28mm f/2.8, sigma APO 70-300, Sigma UC 70-210mm, Carl Zeiss 8x30b Last edited by calypsob : 16th of July 2012 (Mon) at 18:04. |
#6 | |
| Thread Tools | |
| Display Modes | |
| Strange metering/overexposure problem 500D + 28-135IS | jolyon | Canon EOS Digital Cameras | 4 | 8th of June 2012 (Fri) 15:54 |
| Macro flash overexposure problem. | A.S.I.G.N. Observatory | Macro Talk | 8 | 4th of August 2010 (Wed) 08:40 |
| 350d overexposure problem ? | grig | Canon EOS Digital Cameras | 22 | 14th of April 2006 (Fri) 18:10 |
| Flash overexposure problem with G5 closeups | dch0jmh | Canon G-series Digital Cameras | 3 | 5th of December 2005 (Mon) 16:01 |
| Canon 420 Speedlite overexposure problem | Carol32 | Small Flash and Studio Lighting | 8 | 19th of June 2005 (Sun) 22:03 |
