Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > General Photography Talk
Reply
Thread Tools Display Modes
Old 15th of December 2005 (Thu)   #1
Brandy327
Brandy327's Avatar
Question Using Channel Mixer for b&w?
Can anyone give me some tips on how to use Channel Mixer to make a photo b&w? Currently the only way I know how to make a pic b&w is to use the desaturate. Thanks!
Canon 20D with BG-E2 grip
Canon 28-135mm USM IS
Canon 18-55mm
Canon 75-300mm
Canon 420EX Speedlite Flash
Canon 50mm f/1.4 USM
Canon i9900
Brandy327 is offline   Reply With Quote
Old 15th of December 2005 (Thu)   #2
JonathanSQ
JonathanSQ's Avatar
Default Re: Using Channel Mixer for b&w?
From another forum I visit...
Originally Posted by slitherjef,Aug 9 2005, 05:06 PM
First, I don't remember if I posted these here before or not, maybe it was for something else!? :wacko: Anyway... I found this on another forum and thought I would pass the numbers off to you all if you where interested. I have not given them a try just yet...
Agfa 200X: 18,41,41
Agfapan 25: 25,39,36
Agfapan 100: 21,40,39
Agfapan 400: 20,41,39
Ilford Delta 100: 21,42,37
Ilford Delta 400: 22,42,36
Ilford Delta 400 Pro: 31,36,33
& 3200
Ilford FP4: 28,41,31
Ilford HP5: 23,37,40
Ilford Pan F: 33,36,31
Ilford SFX: 36,31,33
Ilford XP2 Super: 21,42,37
Kodak Tmax 100: 24,37,39
Kodak Tmax 400: 27,36,37
Kodak Tri-X: 25,35,40
And these basic ones:
Normal Contrast: 43,33,30
High Contrast: 40,34,60
FYI, in photoshop you need to open up the channel mixer, make sure monochrome is selected then enter the info, R,G,B I believe Enjoy
[snapback]78437[/snapback]
I use alot of those numbers. I also change layer blending modes and
stack multiable B&W mixer layers to make a interesting effect. Enjoy.
Note: You can edit my photo just tell me how you did it
Canon EOS 350D/OPTech Strap | Canon EF-S 18-55mm | Canon EF 50mm F/1.8 MkII
| Tamron 75-300mm
Bogen 679B Monopod |
Misc. CF cards, filters, bags, laptop, software, etc.
http://JWSquire.com - Home Page |
The desire to learn
JonathanSQ is offline   Reply With Quote
Old 16th of December 2005 (Fri)   #3
Brandy327
Brandy327's Avatar
Thanks!
Canon 18-55mm
Canon 75-300mm
Canon i9900
Old 16th of December 2005 (Fri)   #4
gmen
gmen's Avatar
All you need to know can be found here:
http://www.photography-on-the.net/fo...ad.php?t=87784
---- Gavin
gmen is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
I miss my channel mixer T Kubik RAW, Post Processing and Printing 7 11th of February 2007 (Sun) 13:54
First B/W Conversion with Channel Mixer bullet33912 People 2 15th of December 2006 (Fri) 01:20
Channel Mixer? photofinish RAW, Post Processing and Printing 2 15th of December 2005 (Thu) 07:17
Channel mixer - convert to b & w invitation arunchs RAW, Post Processing and Printing 7 17th of October 2005 (Mon) 13:03
B&W using Channel Mixer roanjohn Critique Corner 2 28th of February 2004 (Sat) 21:32
