Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Bird Talk
Reply
Thread Tools Display Modes
Old 16th of July 2012 (Mon)   #1
Keebert
Keebert's Avatar
Default Blown away by a scope
Yesterday, I was at a local nature center and we were looking out into jungle taking photos. I mentioned to the guide that I had not seen any parrots yet and he pulled out this Leica scope on a tripod and dialed it in. This is the first time I have looked through a scope like this and I was blown away.
Firstly, the level of detail and clarity of the scope was amazing - we were looking at a parrot that was probably half a mile away but I could see feathers and great detail.
Secondly, there was this almost 3d like quality to the picture which I have never seen looking through a camera lens.
So what's going on here? How come these scopes give such a good picture in a relatively economic package (compared to a long L)? Is my eye ISO gazillion which is why the scope doesn't have to catch so much light?
I tried to take a photo but it's pathetic in comparison to what was seen by the scope:
100%
5D3, 50/1.4, 40/2.8, 24-105L, 100L, 70-200L II, 400/5.6L, 600EX-RT, Zuiko 28/2.8, flickr
Keebert is offline   Reply With Quote
Old 16th of July 2012 (Mon)   #2
weeatmice
weeatmice's Avatar
Default Re: Blown away by a scope
They have smaller apertures compared to telephoto lenses - less glass. They are also fixed, no aperture blades. No autofocus. No idea how they compare optically but I'd guess those things explain the cost difference.
Twopixel.co.uk | 500px | flickr | Twitter | Pinterest
weeatmice is offline   Reply With Quote
Old 16th of July 2012 (Mon)   #3
yoss1138
The view through a 400mm lens feels like roughly 8x magnification. A Leica scope will have a 25-50x magnification eyepiece and probably shows excellent brightness and detail all the way to 40x. That's directly to your eye, no sensor, no cropping.
yoss1138 is offline   Reply With Quote
Old 16th of July 2012 (Mon)   #4
Joe Ravenstein
Wow! If not for your 100% crop image I'd never have seen the parrot or even know where to look.
Joe Ravenstein is offline   Reply With Quote
Old 16th of July 2012 (Mon)   #5
Keebert
Keebert's Avatar
Why can't they do this with camera lenses then? I'm trying to understand what the limitation is that stops us from having such reach.
Can you imagine - that was a shot with a 400mm so already enlarged. These guides have an incredible skill in picking out these birds from the vegetation.
Old 16th of July 2012 (Mon)   #6
Foggiest
The f number is worked out by focal length divided by aperture ......
So 400mm with a 100mm front element is f4 ...... now as nothing is perfect , you tend to end up with a slightly larger front element to compensate for real life losses in the system .
IE the 400mm F5.6 has front element of around 77mm .
So if a 400mm gives 8 mag and you want 25 mag ... then ... 1250 mm focal length .
If you want maximum aperture of F4 then the front element will have to be over 312mm (probably over 500mm).
This is where you start to get to the limits of cost and production problems .
IE mega money for huge ass lenses
Foggiest is offline   Reply With Quote
Old 16th of July 2012 (Mon)   #7
Keebert
Keebert's Avatar
OK, so say the scope is 1250mm f/11 or something that gives you a sane front element - why doesn't anyone make lenses like this? Clearly people are making the scopes with this capability, why not put a sensor behind it?
Old 16th of July 2012 (Mon)   #8
Hot Bob
The exit pupil of a high magnification scope is very, very small, around 4-6mm. In order to replicate that view in a lens, the exit pupil would need to be hundreds of times larger to completely cover a sensor. Now multiply the size of the scope you were looking through by several hundred and you will see why it is not practical.
Bob
Hot Bob is offline   Reply With Quote
Old 16th of July 2012 (Mon)   #9
monty28428
monty28428's Avatar
Look up digiscoping -- lot's of folks use scope to take photos - some better than others.
monty28428 is offline   Reply With Quote
Old 16th of July 2012 (Mon)   #10
Keebert
Keebert's Avatar
Bob
Eeek... f/250? That explains a lot...
Old 3rd of August 2012 (Fri)   #11
mhrok
Heh.. technically there is no limit as to the size of your lens. However, for us mortals there is. BUT, if you are a sheikh in Qatar, you get personal assistants and special treatment even at Zeiss.
This is old news, but here is the 1700mm f/4 with image coverage for a medium format Hasselblad:
http://www.dpreview.com/news/2006/10/1/zeiss1700f4
And think that people here call Sigma 200-500 f/2.8 a monster..
The petrodollar-filled Qatari wanted it for "bird photography" with "the best possible image quality".. so got this ridiculous lens that weights 256 kg. However, I highly doubt it will ever be used for taking bird photos -- like the car collection of Sultan of Brunei probably is never taken to a race track, just sits there for show.
mhrok is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
40D to scope clippo Astronomy and Celestial 8 16th of December 2009 (Wed) 04:08
$400 APO scope txcwboy Astronomy and Celestial Talk 5 30th of November 2008 (Sun) 23:53
First Scope, First Try renderwerks Astronomy and Celestial 3 4th of November 2008 (Tue) 22:27
Scope these out. Tom K. People 15 30th of November 2007 (Fri) 16:55
A blown blown engine. PAD116 Motorsports 42 15th of July 2006 (Sat) 09:21
