Thread started 17 Jul 2012 (Tuesday) 06:48
Transfer to Photoshop greyed out - and fix
amorrison
Joined Jun 2003
Jul 17, 2012 06:48 |  #1
Well, I had this problem after upgrading to CS6 and removing CS4. Internet searches will find lots of threads on this but none worked until I tried this. Most registry edits deal with putting values that point to application paths. Mine were already there, and it still didn't work. Reinstalling DPP didn't work. Rebooting didn't work. However, the registry entry that "activates" this option in DPP is below:
HKEY_CLASSES_ROOT\CLSI​D\{6DECC242-87EF-11cf-86B4-444553540000}
apparently this is what DPP uses, and by adding the key "ProgID" and for CS6 the value "Photoshop.Application​.60" the transfer to photoshop option is activated (at least on my machine) and works. On mine, the CLSID entry was there, but no ProgID key.
Also, here is the URL I found the most helpful figuring this out:
http://digitol.free.fr​/forum/viewtopic.php?f​=2&t=22 (external link)
As always, with registry edits, proceed at your own risk.
Good luck!!
- Art
http://photos.atlantaf​alconscheerleaders.com (external link)
http://action4image.co​m (external link)
tonylong
...winded
Gallery: 60 photos
Jul 18, 2012 04:54 |  #2
I'd advise against using the DPP Transfer to Photoshop function because it creates a "tiff" file buried in your temp files and does not remove it. Do a Convert and Save, and open it in Bridge until Canon "fixes" this!
Tony
Lowner
"I'm the original idiot"
Jul 18, 2012 05:02 as a reply to  @ tonylong's post |  #3
Tony,
Again, many thanks for info I did not know!
However I religeously run CCleaner once a day and it cleans out all my temp files. I always do what you are suggesting the OP does not do, so if I did not tidy up behind me I can only imagine the mess there would be. Some days there is as much as 200 mb of junk.
Richard
René ­ Damkot
Jul 18, 2012 05:29 |  #4
Bigger problem (IMO) that the filename of the Raw file doesn't transfer, but instead becomes something random like "DPP07DC07120C1746.TIF​", which is pretty useless.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
Lowner
Jul 18, 2012 06:43 |  #5
Rene,
Mine does not. I get exactly the same file name in Photoshop that I did in DPP, which then becomes its standard record ident in my filing system.
Richard
amorrison
Joined Jun 2003
Jul 18, 2012 07:50 |  #6
Hmmm, I never thought about the temp files collecting. I just looked at my PStemp file directory and there is only one entry there from today. There must be some built-in automatic cleanup going on then because I don't run any cleaners. I use 64bit Win7. They are in Users\Art\AppData\Roam​ing\Canon\Genzo\PStemp on my machine. It is a pain to navigate to the directory I need from there when I "save-as" though.
René ­ Damkot
Jul 18, 2012 10:47 |  #7
Lowner wrote in post #14733702 (external link)
Rene,
Hmmm. Must be an OSX thing then…
Anyway, it's the reason I use (Batch) convert & save.
tonylong
...winded
Gallery: 60 photos
Jul 18, 2012 18:26 |  #8
René Damkot wrote in post #14733530 (external link)
Rene,
amorrison wrote in post #14733906 (external link)
I think the misunderstanding is about the "temp" file. If I recall correctly it does have an "odd" name. Also, it doesn't get stored in a "normal" temp directory, but I don't recall the specific spot where it gets placed.
I'd recommend searching your hard drive for ".tif" files after doing a "transfer to Photoshop" and you should find one that matches the time of your transfer. Delete it (DPP won't do it for you), and then don't use that function!
Hopefully Canon will fix that in a new version, but as far as I know it hasn't happened yet...
Tony
tonylong
...winded
Gallery: 60 photos
Jul 18, 2012 18:41 |  #9
OK, *DATA UPDATE*!!
I did the deed -- I used the Tranfer to Photoshop Tool, then did a search of my "system" drive for "*.tif". The "not temp" file did show up in a bizarre place.
For my Win7x64, the path is:
C:\Users\[your user name]\AppData\Roaming\​Canon\Genzo\PStemp\[So​me garbled folder name]\
That's the path, again for Win7x64. The actual file name matched the original "base" file name, just with the .tif extension.
If you have another OS, your results will vary, but I would definitely encourage you to check this out! Those tiffs can gobble up disk space!
Tony
amorrison
Joined Jun 2003
Jul 18, 2012 20:42 as a reply to  @ tonylong's post |  #10
When I looked through the PStemp directory in my system I did find one .psd file I had accidentally saved there several months ago but that was the only one that was not deleted by some automated cleanup process. Apparently (on my system anyway) it only deletes the .tif files created in the transfer process. I use that transfer function all the time for single file edits and have never deleted a .tif file in that temporary space.
tonylong
...winded
Gallery: 60 photos
Jul 18, 2012 22:48 |  #11
amorrison wrote in post #14737315 (external link)
Well, that's odd, because others who have checked have found the tif files. I don't know what you may have that differs...
What OS are you using?
Tony
amorrison
Joined Jun 2003
Jul 19, 2012 06:26 |  #12
I am using Windows 7 64bit. I went through a session and tracked what DPP did in the PStemp file. Every time I transferred a file to photoshop it created a directory with a long alpha name like a registry key. Each transfer temp file was put in its own ong named directory. I did not modify the temp files in any way - I always do a save-as and put the edited version somewhere else. I then exited PS, and exited DPP. The PStemp files were still there. I started another session of DPP, and looked at PStemp and they were gone. So, on my system DPP cleans up the temp files when it starts up.
Lowner
Jul 19, 2012 06:30 |  #13
amorrison wrote in post #14738867 (external link)
That sounds as though thats what my (Win7 - home) does. So its not my using CCleaner, its tidying up after itself! Good for DPP.
Richard
tonylong
...winded
Gallery: 60 photos
Jul 19, 2012 10:09 |  #14
So you have to close and re-start DPP to do the "cleanup"? OK, new info!
Tony
1,667 views & 0 likes for this thread
version 2.0 /
Latest registered member is CanucksFan
375 guests, 305 members online
