Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > People Talk
Reply
Thread Tools Display Modes
Old 18th of July 2012 (Wed)   #1
feral1
Default Umbrella type ??
I am new to Portrait or more so People, I have just found out that a good friend wants me to photograph his daughters Formal. I am thinking of getting 2 Umbrellas to help with lighting where needed, why 2, I have a 580 ex II and a 430 ex II flashes.
So I am wondering what may be better for outside shoots the translucent or the silver reflector ones, or 1 of each.
In 2 weeks I am heading out to where the shoot will take place, so i have an idea of the area at the winery. As this shoot is going to be around the 5 pm mark here in Oz it will be getting a bit dark for sunset, so hoping the light will e good for background, but may need the (or will) need the flash with the umbrella to soften the light.
Thanks in advance, shoot is just over a month away.
Peter
feral1 is offline   Reply With Quote
Old 18th of July 2012 (Wed)   #2
AlexB_Photo
AlexB_Photo's Avatar
Default Re: Umbrella type ??
Well a reflective could give you more overall height and broader lighting, where a shoot-through would give you softer light, but you would need more of it. I prefer shoot-through for individuals but I generally shoot in a semi-controlled environment. If you need to cover a large area, a large reflective may be better. Depending on the area you are trying to cover, you may need more than a single speedlight.
At wedding receptions, sometimes I set a wireless bare flash on the DJ table pointed at the ceiling. This way, no matter where I am I have overhead light that just looks like the DJ's lights. Obviously this has it's faults, someone stands too close or I venture too far, but ta light stand would quickly remedy that issue. Not sure if this helps.
alexb-photography.com
Facebook Page
20D, 450D, AE-1, A2 | 30mm f/1.4, 50mm f/1.8 II, 70-200mm f/4L
WTB: Canon 20mm f/2.8 or Sigma 20mm f/1.8 and Canon 40D
AlexB_Photo is offline   Reply With Quote
Old 18th of July 2012 (Wed)   #3
feral1
Thanks for your quick response, I am in the process in looking at what sizes I may need, seeing as I have 2 speedlites, I will have to see what may work better for the 2 different sizes.
I am hoping it will mainly be 1 person at a time, then 1 group shot, may mean looking at the group shot first due to lighting conditions.
thanks for your input.
Peter
Old 18th of July 2012 (Wed)   #4
AlexB_Photo
I shoot a Wescott 43" umbrella from Amazon that has a removable reflective cover and I LOVE it. I know I there are better options out there but it was the cheapest I could find and it was worth it.
For a sunny day, I have made out well with just a diffusion panel held in front of the sun for soft light. If you need the light, you can probably work with a reflector and a shoot-through. For the group I've used two reflective umbrellas, one on each side of the camera. I found out half way through the shoot that the left was not firing, but the pictures came out just fine anyway.
Facebook Page
Old 19th of July 2012 (Thu)   #5
Hardrock40
Hardrock40's Avatar
Good to hear, just ordered a Wescott 43 today.
Hardrock40 is offline   Reply With Quote
Old 24th of July 2012 (Tue)   #6
feral1
thanks for the responses all
Peter
Old 29th of July 2012 (Sun)   #7
feral1
I have bought the Umbrellas, a reflective and a translucent one, with tripod bracket and 2 stands, with a dual Young's to trigger flashes.
Just waiting for them to arrive, so hoping next w/e I can do tests with them.
Thanks all.
Peter
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Mounting RF602 to 'universal' or screw type umbrella mount CanonLearner Small Flash and Studio Lighting 4 22nd of May 2012 (Tue) 16:46
Recommendations for good umbrella bracket for heavier umbrella/flash setups ? JayStar86 Small Flash and Studio Lighting 12 22nd of September 2011 (Thu) 15:30
Calumet 45" Umbrella - Need Stand and Umbrella/HotShoe Adapter Suggestions! BenJohnson Small Flash and Studio Lighting 9 12th of February 2010 (Fri) 09:55
Umbrella size and type. Any tips? TMR Design Small Flash and Studio Lighting 10 22nd of November 2006 (Wed) 20:53
