Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Macro Talk
Reply
Thread Tools Display Modes
Old 18th of July 2012 (Wed)   #1
DanThoman
DanThoman's Avatar
Default Lucas Macro Flash Bracket
Has anyone used a Lucas Macro Flash Bracket? What is your impression. I thought it looked pretty interesting but it's $200.
http://lucasstrobesystems.com/Produc...ketSystem.aspx
DanThoman is offline   Reply With Quote
Old 18th of July 2012 (Wed)   #2
racketman
racketman's Avatar
Default Re: Lucas Macro Flash Bracket
looks unwieldy to me.
Toby
Flickr collections
ipernity gallery
Gear
racketman is offline   Reply With Quote
Old 19th of July 2012 (Thu)   #3
BasAndrews
BasAndrews's Avatar
I purchased a dual version of that sort of design (not this manufacturer) and although it seemed like a good idea, it didn't really work out for my MT-24 flash heads.
It was not as easy to tweak the position of the heads for different zoom levels on the MP-E lens.
Bas Please feel free to tell me what is wrong with my pictures.
BasAndrews is offline   Reply With Quote
Old 19th of July 2012 (Thu)   #4
orionmystery
orionmystery's Avatar
I used Fotopro dual flexi arms before...quite similar to this....the arms will droop after a while.
You can use a lens hood or tripod collar/mount ring or Cokin filter holder/adapter as your flash bracket:
http://orionmystery.blogspot.com/201...acro-rigs.html
Kurt, 40D, MP-E65 & MT-24EX for full flash, Sigma 150 +1.4x TC for natural light.
My Macro Rig
orionmystery is offline   Reply With Quote
Old 19th of July 2012 (Thu)   #5
CyberManiaK
If you like that style... you could do it for less and maybe with more load capacity http://quiglag.com/2007/03/30/diy-fl...-flash-bracket
I will be trying to build one in a couple of weeks..
Carlos Perez.
60D
CyberManiaK is offline   Reply With Quote
Old 22nd of July 2012 (Sun)   #6
DanThoman
DanThoman's Avatar
Thanks for the information. The flex line didn't look like it would hold a large flash without drooping but Mark says he uses the 580's on them. Still
Old 24th of July 2012 (Tue)   #7
calypsob
calypsob's Avatar
sealife makes very sturdy brackets for flash and lighting but they are pretty expensive. http://www.sealife-cameras.com/accessories/lighting
also the intovva flex arm is made for big heavy underwater flashes so I would assume that they are a little more sturdy than the lucas brackets and much cheaper than the sealife product http://www.amazon.com/gp/product/B00...RVPTESV3YSVD7R
Wes
Gear: canon t3i / 600d, 18-55mm kit, tokina 11-16mm, pentax-A 28mm f/2.8, sigma APO 70-300, Sigma UC 70-210mm, Carl Zeiss 8x30b
calypsob is offline   Reply With Quote
Old 27th of July 2012 (Fri)   #8
gmillerf
Whether the Loc-Line will hold a flash depends on the size used. I have some 1" that is very solid for holding a flash, though a little tough to get in the right position. I've also tried 1/4", and it's useless for holding a flash.
gmillerf is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Flash bracket for macro dandai Small Flash and Studio Lighting 4 26th of June 2012 (Tue) 23:09
Flash Bracket for macro mortar Small Flash and Studio Lighting 3 26th of December 2009 (Sat) 12:15
Some flash advice - MT-24EX or Wimberley macro flash bracket? low-key Macro Talk 2 9th of July 2009 (Thu) 15:35
DIY- Macro Flash Bracket. Michael_Lambert Macro 13 20th of March 2008 (Thu) 08:40
