Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Nature & Landscapes Talk
Reply
Thread Tools Display Modes
Old 22nd of July 2012 (Sun)   #1
QUILLL
Default DSLR Panoramic shots
Just downloaded software to enable me to take these type of shots. It recommends that you use exactly the same camera settings for each overlapping image. Is there a simple idiot's way of achieving this? (Canon 5DII )
QUILLL is offline   Reply With Quote
Old 22nd of July 2012 (Sun)   #2
ickmcdon
Default Re: DSLR Panoramic shots
Use manual exposure, not auto. That's the only way.
ickmcdon is offline   Reply With Quote
Old 23rd of July 2012 (Mon)   #3
QUILLL
Thanks for that, my eyes aren't that good though!!!
Old 23rd of July 2012 (Mon)   #4
Littlejon Dsgn
If you do not use Manual there is no way to lock in the settings. You can use auto and see what the camera thinks the settings should be, switch to Manual and plug those in .... its a good starting point. Also pick a WB do not leave it on Auto either.
Littlejon Dsgn is offline   Reply With Quote
Old 23rd of July 2012 (Mon)   #5
WaltA
WaltA's Avatar
I was going to answer this way but it brought up more questions for me.
I understand the reason for saying you need the same exposure across all the shots. But how do you know that the same exposure is the right one?
For example, taking a picture of a landscape with 5 to 7 horizontal shots - how can you be sure the same exposure is required all across the landscape? Maybe theres more trees on one frame then the others - that frame will require a different exposure.
I've taken many panos using Av or Tv and they worked out pretty well.
Walt
Canon Xti and 5Dc
And bag full of stuff
WaltA is offline   Reply With Quote
Old 24th of July 2012 (Tue)   #6
MNUplander
They'll work fine in Av if your lighting is consistent in the spot the camera uses to meter the scene across each frame, which varies based on your metering mode. If that point happens to be in the sky in one shot and a shadowed mountain peak on the next, the camera will not meter the same exposure. Tv is unacceptable for panos or landscapes in general because allowing the camera to control your aperture to change the exposure will result in different focus/DOF for each shot.
You know the exposure is the right one by either using a light meter, taking a test shot and reviewing the histogram and adjusting as needed or reviewing the histogram in live view as you adjust the settings in M mode.
MNUplander is offline   Reply With Quote
Old 25th of July 2012 (Wed)   #7
IslandCrow
IslandCrow's Avatar
Eyes good or bad really shouldn't have anything to do with it. If you don't know how to read a histogram, it would be a really good idea to learn. A light meter is of course also a very useful tool. My own technique is to first decide whether I think the dynamic range of the lighting in the entire scene will fit within my camera's dynamic range. If it will, I'll "expose to the right" for the brightest area in the scene. That is to say, I'll take a test shot (often, but not always, using a light meter to get myself in the ballpark), and expose so that the histogram for the brightest area of the scene is on the far right of my histogram. If there's too much dynamic range in the scene, I must decide whether I want to a) sacrifice detail in either the shadows/highlights or b) use a graduated neutral density filter or multiple exposures across the scene. But in the end, you'll need one fixed aperture, focal length, shutter speed and ISO that's going to work across the entire scene. It's also a good idea to use a fixed white balance, though I'll generally shoot in raw and just copy the same white balance settings to each image in post processing. Lastly, you need to keep the same focal plane for all of the images. If you don't know about the concept of hyperfocal distance, it would be a really good deal to read up on it.
Personally, I use manual exposure for 99.9% of my landscape shots, so that part of the pano process comes pretty naturally. Basically, though, you want the exact same exposure, color balance, and depth of field across all of your images, or they won't blend together seemlessly.
IslandCrow is offline   Reply With Quote
Old 25th of July 2012 (Wed)   #8
WaltA
WaltA's Avatar
I think in this post the OP mis-read the preceding post that suggested he shoot in Manual. I think the suggestion was Manual Exposure but was taken by the OP to mean Manual Focus. Therefore the comment about bad eyes - which would be valid if talking about Manual Focus.
Walt
Canon Xti and 5Dc
Old 25th of July 2012 (Wed)   #9
IslandCrow
IslandCrow's Avatar
Ahh, that makes much more sense.
Old 26th of July 2012 (Thu)   #10
WaltA
WaltA's Avatar
BTW, thanks for your post. I've taken panos for years just using AV and spot metering and have many times ended up with difficulties in post processing because different frames had different exposures.
If you try to process each frame individually before stitching they don't always match. So I guess your method is what I need to try next.
What you described sounds like PETTR - or "Panoramic Expose to the Right" where you ETTR for the highest contrast frame in the pano. Thats something I need to get out and try on my next outing.
Walt
Canon Xti and 5Dc
Old 26th of July 2012 (Thu)   #11
IslandCrow
IslandCrow's Avatar
Yeah, I definitely try to avoid doing any real processing prior to stiching. You can do some editing in the Raw editor or in Lightroom if you want. You just need to copy those adjustments to the other images. I find it easier to skip all that until I have the Pano stitched, though.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
HDR Panoramic Shots ryanhnc10 Nature & Landscapes 9 17th of July 2012 (Tue) 23:42
G11 / G12 Panoramic shots the jimmy Canon G-series Digital Cameras 40 16th of May 2012 (Wed) 06:30
Best Panoramic Shots? The_Camera_Poser Canon EF and EF-S Lenses 24 17th of March 2008 (Mon) 13:50
3-Shots Panoramic from the top djharmonix Still Life, B/W & Experimental 2 5th of January 2008 (Sat) 07:18
Panoramic shots guitarboy Wildlife 0 4th of August 2007 (Sat) 22:48
