#1 |
Last night I tried some milky way shots, here's what I did
Iso 1600 17mm f/2.8 MLU 2 sec timer fired with wireless remotes All in camera NR turned off 15x30 sec exp 5x30 sec dark frames (cap on) 5x1/4000th offset? frames (cap on) I used live view 10x to focus on the brightest star I could find then framed up and fired away. Focus looks to be a problem as does a bit of light pollution. Any tips anyone can pass on regarding any of this and tips on PP to tease out the goodness that is obviously there. I used levels and curves to get out as much as I could. I noticed that there is a lot of blurring in the corners in them as well. I followed the tutorial here using DSS Anyways, here's the pics ![]() Milky way 2 by T_J_P, on Flickr ![]() Milky way 1 by T_J_P, on Flickr |
| sponsored links |
#2 |
Nice shots, looks like you have nice dark sky at hand.
I see you used Darks and bias but what about Flats ? Flat frames helps to remove vignetting from the frame. Make sure you disable peripheral illumination correction in camera, Cheers Sameer
Sameer Thakur www.sameerthakur.net & www.indussky.com Body : Canon EOS 7D, Canon EOS 1D Mark II N, Canon EOS 400D Lenses : Canon EF 70-200 F/4 L, Tamron 17-50 F/2.8, Canon EF-S 18-55 kit, Canon EF 75-300 USM III, Nikon 28-105, Kenko 1.5x, Kenko 2x |
#3 |
The top image would be better with the milky way not so close to the edge, or at least with a better crop imo.
| sponsored links |
| Thread Tools | |
| Display Modes | |
| Milky Way critique from Southern California | JoelSPE | Astronomy and Celestial Talk | 14 | 23rd of June 2011 (Thu) 01:34 |
| Need Milky Way tips (Sigma 10-20) | SamHunter | Astronomy and Celestial Talk | 3 | 15th of September 2010 (Wed) 11:17 |
| Maui, Haleakala - tips for Milky Way shots? | Silverpenguin | Astronomy and Celestial Talk | 6 | 30th of August 2010 (Mon) 17:10 |
| Any tips for photographing the Milky Way? | irishman | Nature & Landscapes Talk | 2 | 3rd of June 2010 (Thu) 17:28 |
