Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Macro Talk
Reply
Thread Tools Display Modes
Old 26th of July 2012 (Thu)   #1
calypsob
calypsob's Avatar
Default Tilting a Macro lens
I found a fascinating article on tilting a macro lens today that I wanted to share with everyone. I have been aware of tilt shift photography for a long time but I never really thought of a way to incorporate it into macro but guess what? this guy did! http://www.bobatkins.com/photography...t_adapter.html It is really rather impressive, the idea is to take that razor thin DOF that you get when working with 1:1+ macro work and tilt it so more of the subject falls within the DOF. This would mean less spending time building a focus stack and more time shooting pictures.
- Wes
Wes
Gear: canon t3i / 600d, 18-55mm kit, tokina 11-16mm, reversed: pentax-A 28mm, sigma APO 70-300, Sigma UC 70-210mm, Carl Zeiss 8x30b
calypsob is offline   Reply With Quote
Old 26th of July 2012 (Thu)   #2
Martin G.
Martin G.'s Avatar
Default Re: Tilting a Macro lens
interesting for sure, been considering a TS lens for macro, but since the magnification achieved is not so high, I never persued the idea. This might be worth trying, if anything just out of curiosity.
Martin
6D & 50D
EF 24-105 L, EF 100mm L IS, MP-E 65
Macro Twin Flash MT-24EX, 430 EX II & 270 EX
Martin G. is offline   Reply With Quote
Old 28th of July 2012 (Sat)   #3
alquimista
very interesting article, thanks for sharing
la costura de Dios
http://www.flickr.com/photos/andresmoline/
alquimista is offline   Reply With Quote
Old 29th of July 2012 (Sun)   #4
ceriltheblade
that is indeed cool. the price of the tilt adapter is also "interesting"! and it is a fixed tilt...
and no electronic controls of the aperture....
EOS 7d - Canon 100 macro USM, 10-22, 24-105, 70-200 f4IS, 55-250, 50 f1.8II - Tamron 28-75 f2.8 - Kenko extension tubes - 430 exii, 540ez - 055xprob/488rc2
ceriltheblade is offline   Reply With Quote
Old 30th of July 2012 (Mon)   #5
calypsob
calypsob's Avatar
Very true ceril, I suppose I forget sometimes that others have real macro lenses that use sophisticated electronics, HAHA! So all you manufacturers out there, the market needs a canon tilt adapter with canon contacts! As for me I would be happy to stick my reversed lens on the front of a tilt adapter, I dont think you would need the shift aspect for macro work unless you were using a tripod because that feature is generally used for building panoramas within architectural photography, however on a tripod a shift function would be sweet for building a panorama, but the again you could always use a focus rail for going side to side, but up and down would be the job of a tilt shift for sure.
Wes
Old 1st of August 2012 (Wed)   #6
Lester Wareham
Moderator
Lester Wareham's Avatar
Nikon actually sell a tilt macro lens and tilt bellows are available. The amount of focal plane tilt you can get in closeup is limited if you work through the maths.
Some use the TS-E 90mm on tubes.
Could be good for static subjects if you have the fiddle time.
My Photography Home Page RSS Feed
MP-E, EF 100mm, EF 180mm : The Macro Dark Unholy Trinity : Bow down before their darkness and despair!
Macrophotography by LordV
Lester Wareham is offline   Reply With Quote
Old 3rd of August 2012 (Fri)   #7
jjphoto
jjphoto's Avatar
There are various ways to incorporate tilt with macro.
Mamiya 120/4 A (macro lens) on a Canon 5D2 with a Mirex tilt/shift adapter;
Or just use a swing/shift bellows like the Nikon PB4;
PhotoCornucopia.com
jjphoto is offline   Reply With Quote
Old 9th of August 2012 (Thu)   #8
ZoneV
I have two tilt/shift bellows for such. A fixed tilt adapter is not that interessting for me.
But even with Scheimpflug stacking the depth of field is small. Only the plane of sharpness in tilted. But most objects are not plane.
DIY-Homepage - Image Gallery - Gear List
ZoneV is offline   Reply With Quote
Old 9th of August 2012 (Thu)   #9
jjphoto
jjphoto's Avatar
Using tilt/swing to increase depth of field is a futile pursuit as it only affects the plane of focus. Some times the plane of focus can be adjusted to suit a subject so that what ever depth of field is available can be used more effectively, but it still doesn't change the depth of field.
PhotoCornucopia.com
Old 9th of August 2012 (Thu)   #10
Nature Nut
Nature Nut's Avatar
For that cost I'll just hammer on my old Fotodoix manual tubes until theyre bent. Interesting concept and I bet you could use it for some unintended fun.
Adam - Upstate NY:
Nature Nut is offline   Reply With Quote
Old 9th of August 2012 (Thu)   #11
maverick75
Bob's site has a TON of useful information, bookmark worthy indeed!
- Alex Corona
Flickr YoutubeChannel
Streets of Riverside
Cameras for sale
maverick75 is offline   Reply With Quote
Old 19th of August 2012 (Sun)   #12
calypsob
calypsob's Avatar
This would be perfect in the case of a reverse lens due to the fixed focus, it would be nice to be able to think about focal plane and composition when doing handheld macro because the insects are always clinging onto objects in all different directions.
Wes
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
No tilting modifiers ? vadim_c Small Flash and Studio Lighting 4 16th of March 2009 (Mon) 17:38
Rattling noise in the lens while tilting it jutawan Canon EF and EF-S Lenses 2 14th of January 2009 (Wed) 23:39
Tilting or turning PS Brushes? cmvscrapper RAW, Post Processing and Printing 2 21st of June 2007 (Thu) 16:52
Experiment with tilting the camera Guineh Critique Corner 1 25th of August 2006 (Fri) 23:27
Tilting, what's the rule? Espie General Photography Talk 9 7th of August 2006 (Mon) 21:40
