Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > General Photography Talk
Reply
Thread Tools Display Modes
Old 17th of December 2005 (Sat)   #1
abrogard
Default Overexposure on Movie mode
I live in the tropics. Bright sunlight. Sometimes I take a movie with my Powershot 520 outdoors and it is fine - exposure correct for the job. That's especially true, I think, when I'm in the shade of trees or somesuch all the time.
Othertimes the camera doesn't seem to adjust and overexposes the whole thing.
For instance I can commence a movie indoors and walk out into the shaded verandah - which has bright sunlight all around it, like 'walls' of sunlight, but is itself shaded (and has the house wall on the fourth side, too, providing another shaded direction.) and the movie will go into overexposure immediately, even though I am not directing the camera at the sunlight but am photographing things within the shade - ie. my son on his tricycle.
Another time I can do this and I do NOT get immediate overexposure.
1. Have a got a camera fault?
2. Is there something I can do to force the camera to adopt the right exposure?
3. Any other hints?
regards,
ab
abrogard is offline   Reply With Quote
Old 17th of December 2005 (Sat)   #2
Robert_Lay
Robert_Lay's Avatar
Default Re: Overexposure on Movie mode
Dear ab,
My Powershot G5 has a footnote on the page in the users guide that explains shooting movies. I'll bet your camera has the same note. It says, basically, that whatever the Autofocus and Autoexposure controls see on the first frame of the move, that's what you're going to get for the duration of that movie.
So, the best way to set up a movie is to start the movie while set on an object that is at the median distance for your entire movie and and is at a nominal level of brightness for the entire movie - otherwise you will not have optimum focus and exposure.
Obviously, if there are to be portions of the movie in bright sunlight and other portions in deep shade or indoors, then it would make sense to break your movies into shorter clips, so that each clip is shot with a reasonably consistent set of distances and scene brightness for that segment.
Does that make sense?
Bob
Quality of Light, Photo Tool ver 2.0
Canon Rebel XTi; EF-S 10-22mm f/3.5-f/5.6 USM; EF-S 18-55 mm f/3.5-f/5.6; EF 28-135mm f/3.5-5.6 IS USM; EF 50mm f/1.4 USM; Canon Powershot G5; Canon AE1(2); Leica R4s; Battery Grip BG-E3; Pentax Digital Spotmeter with Zone VI Mod & Calibration.
Robert_Lay is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Rebel XT, TV mode, overexposure? The111 Canon EOS Digital Cameras 7 26th of May 2006 (Fri) 10:19
Overexposure in P Mode kcpopps Canon EOS Digital Cameras 0 29th of September 2005 (Thu) 23:30
300D. Overexposure in sports mode mcklemme Canon EOS Digital Cameras 14 30th of August 2005 (Tue) 02:26
A75 in movie mode vivace Small Compact Digitals by Canon 3 3rd of January 2005 (Mon) 17:55
movie mode msvadi Canon G-series Digital Cameras 4 26th of October 2003 (Sun) 21:22
