Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Transportation Talk
Reply
Thread Tools Display Modes
Old 29th of July 2012 (Sun)   #1
wookiee2cu
Default 5D MIII air show settings
So this will be my first attempt with my 5D MIII shooting the Blue Angel's during Seafair and was wondering what settings are recommended. Equipment is 5D MIII, Canon 100-400, Canon 70-200 2.8 (should the 100-400 not be fast enough but I don't think it will be a problem). The weather is forecasted to be about 73, clear and sunny. For settings I plan on using TV mode and AI sevo and was thinking of using case 4. Currently AF is set at the 41 cross type but was wondering if zone would be better suited? There will be jets, prop planes and helicopters; for the prop planes and helicopters I'm going to start around 1/200 and for the jets will start around 1/1,000 and adjust as needed (starting around 100 ISO and will again adjust as needed). Does anyone have any other tips or recommendations? I did do a search but didn't find any results for the 5D MIII with the new case settings. Thanks in advance! Also anyone else going? I'm going Friday afternoon (weekend crowd is just too crazy plus I'll be out of town) and will be on the Mercer Island side.
wookiee2cu is offline   Reply With Quote
Old 29th of July 2012 (Sun)   #2
FlyingPhotog
Cream of the "Prop"
FlyingPhotog's Avatar
Default Re: 5D MIII air show settings
Don't know what the equivalent is on the 5D3 but I use center-point AF with surrounding helpers on my MkIVs and my MkIII.
You're shooting at distances where "critical focus" shouldnt be an issue and neither is DOF.
FlyingPhotog is online now   Reply With Quote
Old 29th of July 2012 (Sun)   #3
wookiee2cu
That sounds like the cross type af I normally have set up, thanks for sharing your style!
Old 30th of July 2012 (Mon)   #4
PhotosGuy
Moderator
PhotosGuy's Avatar
Links: Shooting airshows in Manual
www.FrankCizek.com
PhotosGuy is online now   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
7D : Settings for a fashion show dino666 Canon EOS Digital Cameras 3 19th of March 2010 (Fri) 13:12
Need settings help for a live show ChrisMc73 Performing Arts Talk 11 6th of July 2009 (Mon) 08:15
Settings for local show? THIEF Performing Arts Talk 9 20th of March 2009 (Fri) 12:02
Best settings for XSi/450d for Air Show? gregrocco General Photography Talk 2 13th of August 2008 (Wed) 14:27
