Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 30th of July 2012 (Mon)   #1
CliveyBoy
Default Yongnuo YN-622C Controller Trigger
This new device is on sale in China, and will be available internationally within a month. Like the Kings, it is designed to provide a radio communication for Canon DSLR cameras (2005 on) which have flash control menus. This enables remote control of off-camera Speedlites, removing the need to lower a softbox, peel back a diffuser, make adjustments on weird buttons, restore everything...
13 Oct 2012 - there is value in many posts in this thread, but it is scattered with peripheral chatter. My "The Other YN-622 User Guide" contains my summary from many souces and personal testing. I suggest you start with that.
https://docs.google.com/open?id=0B77...FpqNkpBYXBHajA
Clive
50D; 580EXII, 430EXII, 550EX, YN568EX; YN-622C controllers
TOYUG YN622 Guide https://docs.google.com/open?id=0B77...FpqNkpBYXBHajA
CliveyBoy is offline   Reply With Quote
Old 31st of July 2012 (Tue)   #2
btmlinedan
btmlinedan's Avatar
Default Re: Yongnuo YN-622C Controller Trigger
do they have pricing yet? see any real world testing?
i'd be nice to have a flash on camera, and still trigger the other in ETTL as well as change it to manual mode. we'll see if it supports it though.
Currently im running a cheap trigger system out the PC sync port as well as the flash on camera, but where's the fun in that!
btmlinedan is offline   Reply With Quote
Old 31st of July 2012 (Tue)   #3
CliveyBoy
The only listing I have seen was wholesale US$100 each in lots of 10.
Edited for clarity - A flash can be used on the transmitter on the camera, but the hotshoe is not actually a pass-through between camera and flash. It cannot be. How can the camera have two controlling masters? These are not dumb triggers - they are computer systems, They control the camera. Not some other device like a Speedlite. You cannot set a flash to Master and hope to use Canon's Wireless/IR protocols in parallel.
A Speedlite or YN flash can be used on the camera-mounted controller, as just another unit in Group A, complying with all Group A remote settings. The flash is part of the YN-622 system, and not an independent unit. Except...
There are two YN operating modes - Remote (like the Kings) and Mixed. Mixed mode works with all flashes in flash priority. The individual manual flash settings take precedence. Remote control may not be available: testing will determine the nature of the "mix".
Clive
Old 31st of July 2012 (Tue)   #4
talbot_sunbeam
talbot_sunbeam's Avatar
More details and the manual:
http://www.lightingrumours.com/featu...for-canon-2672
http://www.flickr.com/photos/lightingrumors/7663377064/
7D, 450D | 17-55, 10-22, 55-250, 50 1.8, 580EXII | YN622 | Magic Lantern | Jonesing for a 70-200 2.8...
talbot_sunbeam is offline   Reply With Quote
Old 31st of July 2012 (Tue)   #5
YARDBURNER
Will these things work with an SX1 and SX20 series cameras?
YARDBURNER is offline   Reply With Quote
Old 31st of July 2012 (Tue)   #6
CliveyBoy
They are designed as intelligent controllers to work with Canon EOS DSLRs with flash control menus.
They will work with a much reduced set of functions with other EOS DSLRs.
They may work with other cameras as simple dumb triggers, but why buy what you cannot use? One reason may be to have one set of triggers to work on both environments. I have yet to read any independent testing.
Clive
Old 5th of August 2012 (Sun)   #7
CliveyBoy
For the adventurous, the YN-622C is now listed on eBay at US$110 per pair, free std shipping from Shanghai, ship in 1 bus. day.
Apart from an English manual, there are no accessories. Expect to need non-shorting mini-feet or clamps or Frio clips, 4 alkaline batteries, screwlock PC-sync cables for strobes or dumb hotshoe flashes.
I have seen no reviews yet, so actual performance, manufacturing quality and compatibility are yet to be tested.
Some of the listed improvements over the Kings I like include remote control/mixed modes, zoom logic, maintaining previous session settings, test button facilities, on-transmitter flash, AF beam logic, E-TTL ratios and FEC, 550EX compatibility, auto-tx/rx (no tx backup unit required). And then there is the low cost...
Clive
Old 5th of August 2012 (Sun)   #8
biz64
so if Im understanding the way these work is that they trick your flash into thinking its mounted onto the camera, is this correct? If so, would any ETTl flash work even those that cannot do wireless ETTL?
T3i | 18-55mm kit | 50mm 1.8II | Metz 50 Af-1 | Canon 85mm 1.8 | Sigma 10-20mm f/4-5.6 | Canon 55-250mm II | Canon 15-85mm
biz64 is offline   Reply With Quote
Old 5th of August 2012 (Sun)   #9
Trailboy
Flash compatibility list here: http://www.lightingrumours.com/featu...for-canon-2672
Trailboy is offline   Reply With Quote
Old 5th of August 2012 (Sun)   #10
CliveyBoy
It is more like adding in another computer between the camera's cpu, and the flash's cpu, and the YN-622 computer controls the other two.
The Pixel King was the first in this category of triggers - triggers that interface with and implement Canon facilities. The Phottix Odin also interfaces, but substitutes its own control routines which enables it to do things that Canon has not implemented.
I like the Pixel/YN approach as it means that I can use Canon Wireless and the Pixel/YN controllers in precisely the same way - via Canon menus.
Almost any hotshoe flash can be used, but the range of capabilities depends on camera model and flash model.
Clive
Old 5th of August 2012 (Sun)   #11
warrick
Now available here and here
Warrick
5D III | 70-200L 4IS | 24-105L | Sigma 105mm Macro | Tamron SP AF 28-75mm 2.8 | Tamron SP AF17-35mm F/2.8-4| Canon 600EX-RT| Nissin MF18 | Sigma EF 500 | Kata Bumblebee 220P | Yongnuo 622
warrick is offline   Reply With Quote
Old 5th of August 2012 (Sun)   #12
cableguy619
Just ordered off of ebay..so lets see what a set does for me. Should have it next week.
5DIII | 24-105L - Flickr
cableguy619 is offline   Reply With Quote
Old 5th of August 2012 (Sun)   #13
btmlinedan
btmlinedan's Avatar
so what do you think clive, you going to order a set?
Old 5th of August 2012 (Sun)   #14
mrgooch
mrgooch's Avatar
One set is good for one off camera flash. Is that correct?
Canon 7D - 70-200 f4 - Fujifilm X-E1
mrgooch is offline   Reply With Quote
Old 5th of August 2012 (Sun)   #15
cableguy619
Yes
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Pixel King ETTL Trigger Controller CliveyBoy Small Flash and Studio Lighting 652 2 Weeks Ago 16:04
5DMKII with Yongnuo wireless Controller YN-126..can't work!! Canon7DDSLR Canon EOS Digital Cameras 3 26th of January 2010 (Tue) 16:56
