Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Compact Digitals by Canon
Reply
Thread Tools Display Modes
Old 11th of June 2003 (Wed)   #1
Jong
Default S45 underexposure using flash
Is it just me or is almost every flash photo I take underexposed?
If I look at the histogram there is often nothing in the righthand 20%. I find myself manually adjusting with Photoshop. But this is not perfect of course.
A manual flash adjustment in program mode can fix but surely this shouldn't be necessary.
Is this normal or could my camera be faulty?
Thanks.
Jong is offline   Reply With Quote
Old 11th of June 2003 (Wed)   #2
Conk
Conk's Avatar
Default Re: S45 underexposure using flash
There are a couple variables as to why your photos come out too dark when you use your flash. What is your focal length set at? Shutter speed?
Conk is offline   Reply With Quote
Old 11th of June 2003 (Wed)   #3
Jong
Thanks for the reply. First, I should have made it clear I am talking about the S45 in Auto Mode.
Looking in the Exif info for one example: Focal length 12mm, shutter speed 1/60, aperture F/3.5.
If this happened with the odd photo I'd understand but almost all flash photos seem to need a nudge up of say 2/3rds of a stop.
Any ideas very welcome!
Old 12th of June 2003 (Thu)   #4
PeterS45
Depends on the distance. The built-in flash of a digital camera is not very powerful, and 10-12 feet is about the maximum distance it can reach. So when your subject is further away than that...................... bummer.
EOS 350D/Rebel XT, Sigma 18-125 & 55-200mm.
PeterS45 is offline   Reply With Quote
Old 12th of June 2003 (Thu)   #5
Jong
That I could understand. But this seems to happen even with subjects 4-5 feet away and it can be fixed by upping the flash intensity in program mode. The S45 flash seems to have headroom it is just choosing to set it a little too low.
Still, its interesting no one has noticed a similar problem, maybe I'm being picky!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Canon's flash underexposure help document Pekka Canon EOS Digital Cameras 4 24th of January 2009 (Sat) 15:56
flash underexposure lfaustino Small Flash and Studio Lighting 18 26th of June 2007 (Tue) 17:52
Mark II + 550EX Flash Underexposure scottbergerphoto Canon EOS Digital Cameras 5 14th of July 2004 (Wed) 14:09
flash 550 EX and D 60 underexposure Al Schlegel Canon EOS Digital Cameras 2 4th of July 2004 (Sun) 11:08
Underexposure using a 420EX flash on the 10D hhelmbold Small Flash and Studio Lighting 50 30th of April 2004 (Fri) 15:48
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
