Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Compact Digitals by Canon
Reply
Thread Tools Display Modes
Old 5th of August 2012 (Sun)   #1
brantfordbandit
brantfordbandit's Avatar
Default sx-40 and chdk
Is it me or is the chdk very finickey to use.
www.markephotography.com
brantfordbandit is offline   Reply With Quote
Old 5th of August 2012 (Sun)   #2
imjason
Default Re: sx-40 and chdk
not the easiest thing to use. its not designed for ease of use or with a pretty UI. purely for added functionality.
Canon gear: Canonet QL17, SX230HS, S95, SD1200IS
Non-Canon gear: D600, D5000, D70, XG-2, U20
Flickr
imjason is offline   Reply With Quote
Old 5th of August 2012 (Sun)   #3
neimad19
neimad19's Avatar
It does take practice, but after a while it becomes easy. The worst is when you hand the camera to someone who doesn't know how to use CHDK and you haven't unlocked the SD card to bring the camera back to its normal interface.
SX40hs | T3i/600D | 18-55 IS | 55-250 IS | Sigma 90mm 2.8| 50mm 1.8|YN560exII
http://www.flickr.com/photos/neimad19/
neimad19 is offline   Reply With Quote
Old 6th of August 2012 (Mon)   #4
hnikesch
hnikesch's Avatar
I started several responses to dispute your statement but you are correct it is difficult to use. Lots to learn and lots of trial and error to feel comfortable with it. One thing I do is I set the reset overrides on power on so others using my camera don't get messed up. And I play with it a lot. If you are not using overrides and just additional display info it is just like normal with more information. I found the PDF manual is helpful and keep it on my tablet.
Hans
It is better to burn a roll of film than curse the darkness. Equip. Canon S100 w/CHDK, SD990 w/CHDK, SD900 w/CHDK, Pentax Kr & K2000 DSLR,Pentax Q Flickr:
hnikesch is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
CHDK on S3 is? de8212 Small Compact Digitals by Canon 3 30th of May 2011 (Mon) 17:11
s90 CHDK kirkt Small Compact Digitals by Canon 9 1st of May 2010 (Sat) 04:20
CHDK for G10? fishtek Canon G-series Digital Cameras 7 29th of January 2009 (Thu) 11:25
CHDK on S5 Clutz987 Small Compact Digitals by Canon 4 29th of September 2008 (Mon) 05:37
CHDK? ivar.overleir@monet.no Small Compact Digitals by Canon 1 16th of August 2007 (Thu) 08:33
