Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Digital Video
Reply
Thread Tools Display Modes
Old 5th of August 2012 (Sun)   #1
MarkLinsangan
MarkLinsangan's Avatar
Default How do i achieve this effect?
Ran into this video. I've been trying to learn how to do this effect but it seems pretty hard to pull off. Since I'm not really into effects. I'm more in Cutting/Color Grading and Filming/Directing
0:31
http://youtu.be/I2u5n52CP-0?t=31s
If anyone can help and know how to do this or what this is called I'd appreciate the help!
Canon 5DMKII + Zeiss 50 T*1.7 | Roki 85 f/1.4 | Canon 35mm f/2
MarkLinsangan is offline   Reply With Quote
Old 6th of August 2012 (Mon)   #2
Silly Rabbit
Default Re: How do i achieve this effect?
Either use the trials plug-in if you have it
or
Copy the original clip, paste it above the existing one, drop the opacity to half, add earthquake or similar shake effect, enlarge the top clip slightly.
Silly Rabbit is offline   Reply With Quote
Old 6th of August 2012 (Mon)   #3
Brian_R
what silly rabbit said or look up some after effects tutorials if you have access to AE it can be done with not much difficulty. although i am new to AE myself so sorry i cant help more than that
Gear List Flickr Facebook
Brian_R is offline   Reply With Quote
Old 6th of August 2012 (Mon)   #4
MarkLinsangan
or
What's a "trials plug-in"? I do have after effects. CS6. I'll try your second recommendation
Thanks.
Please get back to me!
Old 6th of August 2012 (Mon)   #5
pkilla
pkilla's Avatar
If you got fcxp the trails effect is sick I used it in this video http://youtu.be/qkbvCLkBL speed up to 2:57 if you don't want to see the whole video!
T3i griped - rokinon 8mm/rokinon 35 1.4/rokinon 85mm 1.4/
sigma 17-50/nikon 50mm 1.2 ai-s/nikon 28mm ai-s 2.8/
helios 40-2/helios 44-2/mir 1b 37mm 2.8/supertak 135/
http://www.flickr.com/photos/pkilla617/
CHECK OUT MY BLOG PICS http://pkilla61.blogspot.com/
pkilla is offline   Reply With Quote
Old 7th of August 2012 (Tue)   #6
Silly Rabbit
Trails is just an effect that causes visual echoes (only way I can think to describe it). Most editing software has it but might be called something slightly different.
With it you wont get that exact result (but more of a bionic man thing going on), tbh you're better off going with the second suggestion as it gets the exact result you want.
It allows you to hold one shot steady which is important
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
How is possible to achieve this effect? AlexRT General Photography Talk 15 24th of February 2012 (Fri) 10:41
How to achieve this effect? kaydubs RAW, Post Processing and Printing 1 7th of January 2011 (Fri) 09:41
how to achieve this effect! Shannooners RAW, Post Processing and Printing 3 6th of November 2008 (Thu) 22:01
how can I achieve this effect? howbrightthechris People 13 12th of October 2007 (Fri) 15:41
How do ya achieve this effect?!? geofftelforduk People 4 18th of October 2006 (Wed) 19:20
