#1 |
well here's a try with a 60D and a sigma 70-200 2.8 with a 2x sigma tele
settings: 1/80 f/5.6 iso 100 400mm (640mm) 1.6 crop factor critique welcome ![]()
BLOWNCOFOTO.COM Canon 1D MKIII l Canon 60D l Canon 70-200 2.8 L l Canon 300 2.8 L l Canon 28-135 "for now"
| sponsored links |
#2 |
pretty weak for that setup.
bump up the fstop to f/11, use a tripod, use a 2" delay, disable is and nr. also, crop the picture and try a different composition.
With the power of my mind, I make the end of this sentence disa SONY Alpha α230 + Samyang 85mm f/1.4 + samyang 8mm fisheye + 18-55mm SAM + Tamron 70-300mm + Kenko 25mm + Fancier WT3570 My Flickr, My Photo BLOG, My Fb page, My Deviant |
#3 |
ok tried a few more first one is f/11 the second is f/16 i think f/16 looks a bit better
maybe im missing foucs f/11 ![]() f/16 ![]()
| sponsored links |
#4 |
thats better, you got rid of that ca.
it could use some sharpness. try unsharp mask or some high pass/overlay technique.
#5 |
and last one for the evening
#6 |
Getting better, but i disagree with needing f/11 or narrower. You don't gain any DoF with narrow apertures of the moon, only advantages from the lens being a few-stops up from wide-open. Diffraction will start softening the shots, as well as driving shutter-speed down. I find around 1 stop down to be a happy medium, most of the time. While i'm no expert, i like to keep to no slower than 1/100 at ~400mm for best sharpness, all while using the lowest ISO possible.
Edit: you can also use LV @10x and MF, to be sure focus is at its best...and MLU. Last edited by 1Tanker : 7th of August 2012 (Tue) at 23:32. |
#7 |
The only thing wrong is that it's overexposed. Focus is fine.
Go f/8, ISO 100 and a faster shutter speed, something like 1/250 sec. |
#8 |
thanks for the info everyone will give it another try tonight
| Thread Tools | |
| Display Modes | |
| Last evening's moon | paxfish | Critique Corner | 7 | 11th of August 2011 (Thu) 08:40 |
| Evening moon and a surprise | Alfadog | Canon G-series Digital Cameras | 1 | 12th of July 2008 (Sat) 04:20 |
| This evening's moon - my first moonshot | mikey1967 | Nature & Landscapes | 13 | 22nd of January 2008 (Tue) 04:28 |
| Early evening moon | subtle_spectre | Nature & Landscapes | 1 | 5th of December 2006 (Tue) 02:27 |
| good evening moon, good morning sun | niewold | Nature & Landscapes | 10 | 22nd of September 2005 (Thu) 06:22 |
