Thread started 06 Aug 2012 (Monday) 18:25
Prev/next
Luma Labs Cinch - Need a measurement if anybody can help?
Laramie
Still livin' the cowboylife
Laramie's Avatar
Inland Empire, California
Aug 06, 2012 18:25 |  #1
I sent an email to the company, but if anybody here already has one, I might get a quicker response.
I'm trying to figure out the size difference between the "regular" and the "big".
So for anybody who has either one, can you measure the total length of the strap "end to end" at the full extended position? Trying to compare it to my Optech Super Classic and how low the camera will hang when slung across my chest.
Much appreciated.
5DIII | 40D | 17-40 f4L | Tamron 28-75 2.8 | 50 1.4 | 70-200 2.8L | Oly Zuiko 50 macro | Tamron 1.4x
DarthVader
DarthVader's Avatar
Death Star
Aug 06, 2012 18:31 |  #2
How tall are you ?. Weight ? Chubby ? Thin ? :).
Nikon/Fuji.
Gear is important but skills are very important :)
DarthVader
DarthVader's Avatar
Death Star
Aug 06, 2012 18:37 |  #3
There is some info here http://luma-labs.com/products/cinc​hexternal link. Scroll down almost at the end of the page.
Easy Sizing and Fit
We know that photographers come in all shapes and sizes and we want everyone to be able to use a Cinch. So we make Cinch in three sizes. Most people will be comfortable with a Regular cinch. If you're on the small or big side, then you should get the small or big Cinch.
Put another way, if you wear an adult M, L, or XL shirt (either male or female), our regular Cinch will do the job just fine. If you’re smaller than that, you should probably get a Small Cinch. If you wear XL or larger shirts, then get a Big Cinch. But don’t stress out too much about your choice. We've given the sizes a considerable amount of overlap so picking the right size is easy to do.
Once you have it in hand, fitting Cinch is easy. Just put your Cinch over your shoulder, loosen the pull tab adjuster and the use the rear metal adjuster until your camera is positioned just right. If needed, you can also tighten or loosen the 10mm webbing that connects to your camera to adjust things to perfection. Once set up, the front pull tab adjuster gives you just the right amount of on-the-fly adjustments to keep up with any day of photography.
Nikon/Fuji.
Laramie
Laramie's Avatar
Aug 06, 2012 18:52 |  #4
DarthVader wrote in post #14823007external link
6'3" 230. Not fat, but do that a thick chest/torso area.
I recently ordered the Optech Super Classic (bino) because it was much longer than the Canon or Optech POTN straps. I like to keep the strap long and slung across my chest about 95% of the time, but where the Luma Labs can "cinch" up shorter, it seemed like an ideal fit. I just wanted to make sure at the long end, it was roughly the same lenght as the Optech Super Classic (bino model).
diableri
diableri's Avatar
Joined Jul 2012
Central CA
Aug 06, 2012 20:16 |  #5
I got mine this morning.
The Big is 55" completely stretched out and unhooked to the camera so I'd allow a couple inches for that. I'm just a bit under 6' and have a pretty big chest (like a size 60 chest and 19" biceps, yeah yeah, I look a bit like a dwarf from the hobbit). If I order another one, I'm going to ask for just a bit more er... length. A friend's 5d3 with a moderate sized lens (I didn't look but it wasn't small) sits just a bit too high for me but it wasn't a deal breaker. It does have some nice flex and stretch to it without feeling weak or flimsy at all.
If I wasn't built freakishly, it would be fine (and the build quality is pretty outstanding). It looks like a great product.
Laramie
Laramie's Avatar
Aug 06, 2012 20:24 |  #6
Appreciate the measurement DIABLERI. That is what I needed.
diableri
diableri's Avatar
Joined Jul 2012
Central CA
Aug 06, 2012 20:26 |  #7
Laramie wrote in post #14823424external link
No trouble at all, it's a great looking and feeling product. Great stitching and materials. Looks tough and feels comfortable. Can't wait to put it to use. Hope you find a solution that works for ya.
tancanon58
tancanon58's Avatar
southern california
Aug 06, 2012 20:31 |  #8
I think you will need a large size but you have to make sure the camera should be at your waist area and when it is pulled up it should be between your lower right chest to your right flank area.
Bodies: 5D MkIII/ Oly ED-M5/ G10
Lenses: Tamron SP 24-70 2.8 Di VC /and some Panny and Oly lenses.
Flash: Canon600EX RT.
Laramie
Laramie's Avatar
Aug 06, 2012 21:50 |  #9
tancanon58 wrote in post #14823450external link
I think you're right. The Super Classic goes from 22"-67". Obviously some of that is taken up when put through the slip-lock but I think the "big" will be what I'm looking for.
diableri wrote in post #14823434external link
Just to be clear, you have the "big" model and not the "regular" correct?
diableri
diableri's Avatar
Joined Jul 2012
Central CA
Aug 06, 2012 22:02 |  #10
Laramie wrote in post #14823777external link
Correct, it's the largest size they make "off the shelf" or "Big". I actually got a response back from Luma (which I would bet you will as well in a few more days) before I ordered because I have a lot of trouble getting suit jackets and tux jackets etc due to my weird upper body size. This works and I would bet that my width more than makes up for your height. In fact, I'd guess you're the build they make this size for.
1,674 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00136 for 4 database queries.
PAGE COMPLETED IN 0.02s
Latest registered member is fredD37
521 guests, 408 members online
