Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Weddings and Other Family Events Talk
Reply
Thread Tools Display Modes
Old 8th of August 2012 (Wed)   #1
mdaddyrabbit
mdaddyrabbit's Avatar
Default Photographing Bride
I have been ask to shoot another wedding but the last one I didn't feel I got the coloring right with the brides dress. What is the easiest way to make sure I am getting the color right on the dress?
Website
CANON
mdaddyrabbit is offline   Reply With Quote
Old 8th of August 2012 (Wed)   #2
Pixil Studio
Pixil Studio's Avatar
Default Re: Photographing Bride
eye dropper on the dress?
Pixil Studio is offline   Reply With Quote
Old 8th of August 2012 (Wed)   #3
dmward
Best way to ensure proper color management is to photograph a color (white balance) reference.
There are color checker options like X-Rite Pass Port. Another less formal approach is something like a paper towel.
Just tell the bride you are doing a test shot and have her hold the reference object.
Then use Lightroom eye dropper to get the proper color temp/tint. If the dress is close, or the groom's shirt etc., then use one of those and make the minor adjustment in LR to color temp/tint.
dmward is offline   Reply With Quote
Old 8th of August 2012 (Wed)   #4
Chet
BrokenMember
Chet's Avatar
Set custom wb with a 18% gray card. Will very with lighting used. Also shoot in RAW.
xti • 100mm f/2.8 • 50mm f/1.4 • EF 28-135mm f/3.5-5.6 IS • EF 75-300mm f/4-5.6 • EF-S 18-55mm f/3.5-5.6
Chet is offline   Reply With Quote
Old 9th of August 2012 (Thu)   #5
mdaddyrabbit
So basically take a photo of the gray card in the light I will be photographing the wedding in and set that as custom WB?
Website
CANON
Old 9th of August 2012 (Thu)   #6
gadgeteer
Shoot in RAW and adjust WB in PP.
gadgeteer is offline   Reply With Quote
Old 9th of August 2012 (Thu)   #7
JohnThomas
JohnThomas's Avatar
The gray card method might work for the ceremony or shots outside, but it also might drive you crazy when it comes time for the reception. Reception lighting constantly changes.
If you shoot in RAW white balance shouldn't be a problem - provided you are familiar with processing the files in ACR or LR.
You can call me JT
5D mkIII | 5D mkII |50D | 50 1.8 II | 85 1.8 | 17-55 2.8 | 16-35 2.8L | 24-70 2.8L | 70-200 2.8L | (3) 600EX-RT | (3) 580EX II
JohnThomas is offline   Reply With Quote
Old 9th of August 2012 (Thu)   #8
mdaddyrabbit
I always shoot Manual and RAW format. I also process with ACR and I also have lightroom. What would you say is the easiest way to achieved proper white balance?
Website
CANON
Old 9th of August 2012 (Thu)   #9
Red Tie Photography
Red Tie Photography's Avatar
Can you post an example to what you are getting? The answer usually is starting with good light. Without good light or mixed light on the bride, it can get difficult.
Red Tie Photography is offline   Reply With Quote
Old 9th of August 2012 (Thu)   #10
mdaddyrabbit
Yes, I will post something in the next hour.
Website
CANON
Old 9th of August 2012 (Thu)   #11
JohnThomas
JohnThomas's Avatar
I'm not sure what will work best for you, but I use Auto WB on the camera. When I import the files into LR I compare the "As Shot" setting to the "Automatic" setting and then decide where I want it to fall. Every photographer has their own style - some like a little warmer looking photo and some like them a little cooler.
You can call me JT
Old 9th of August 2012 (Thu)   #12
mdaddyrabbit
Here is a link to the raw file LINK
Website
CANON
Old 9th of August 2012 (Thu)   #13
Christopher Steven b
Christopher Steven b's Avatar
Dresses and cloth in general are sometimes challenging to use as a neutral subject for the eye-dropper because the texture often creates micro-shadows that tinge them usually blue-ish. In other words, sometimes the right color balance for the scene is one such that the dress or white-collared shirt, is very slightly bluish.
My approach is to shoot in RAW, eyedrop a neutral area that is co-planar with the part of the subject receiving the main light, and then adjust slightly in the direction that makes the subject's face look best. Again, if that means the dress is ever so slightly bluish, so be it. If it's dramatically blue, I pull down the blue saturation slider in LR.
christopher steven b. - Ottawa Wedding Photographer
Ottawa Wedding Photography Site | Ottawa Wedding Photographer Blog
Christopher Steven b is offline   Reply With Quote
Old 10th of August 2012 (Fri)   #14
Phil V
That file white balances off the brides dress fine with the eyedropper, it's about half a stop underexposed though, so not much work to get it OK.
From a non-calibrated laptop.
Phil V is offline   Reply With Quote
Old 10th of August 2012 (Fri)   #15
brokensocial
We just shoot in AWB. Dresses look different in all kinds of light; as long as we like the way the people look, we're happy.
[mike and frida] photography - we shoot stuff.
chicago wedding photography | chicago wedding photography blog
brokensocial is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
bride bigcountry Weddings and Other Family Events 5 2nd of June 2011 (Thu) 18:21
Newmindspace People Photographing People Photographing People Event Seaport C+C? Photobyshirley People 5 20th of September 2009 (Sun) 17:38
Bride on the Run rachelle14 Weddings and Other Family Events 4 14th of November 2008 (Fri) 13:38
The Bride whiskaz People 16 12th of October 2007 (Fri) 09:43
Bride not looking achristian Weddings and Other Family Events 11 28th of May 2007 (Mon) 10:47
