Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Macro Talk
Reply
Thread Tools Display Modes
Old 9th of August 2012 (Thu)   #1
CyberManiaK
Default Ideas to make this ext.tubes work ??
Well regarding the thread of calypsob "extension tube problem" instead of hijacking his thread I open a new one..because my problem is not that bad and I think is not because the shape of the elements of the lens I'm using..
I'm using 2 sets of extension tubes on a 135mm lens
Well its giving me around .98 magnification, with a working distance of 28-30cm !! So I really want this to work..
When it doesnt glare, can get this..
Which in IMO are very sharp for a cheap combo..
If I put my DCR-250 on top I get around 3:1 mag with a working distance around 9-10cm
But when the flare appears is like this.
BTW: Right now I can't afford a real macro lens, so what do you think I need to add/do to my tubes to eliminate that glare..
Thanks.
Carlos Perez.
60D
CyberManiaK is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Not sure what to make of this. Ideas? (Mitch, you may want to look at this...) twoshadows Birds 3 12th of August 2010 (Thu) 20:39
Make the Gorillapod Focus stiffer?? any ideas RoryOD Accessories & Storage 5 11th of September 2009 (Fri) 13:47
Got me Kenko tubes, need to make them work with EFS lens yuriyo923 Canon EF and EF-S Lenses 3 21st of March 2009 (Sat) 16:09
Trying to think of ideas to make money with photography... OverSpun The Business of Photography 3 17th of October 2004 (Sun) 22:58
