#1 |
Looking at the MPE-65 because I really do want to get into that whole different, unseen world. Is this a lens that I can carry around and stalk things with or does it need to be on a tripod with focusing rail or bellows?
I have the 100mm and the 50mm compact macro. Is there some way I can get more magnification from either of them? Would a bellows help? Magnifying lens? Extension tubes? How would these effect min focus distance?
40D, Digital Rebel 300D; EF-S 17-55 f/2.8 IS, EF 28-135 IS, EF 50mm f/2.5 Compact Macro, 85mm f/1.8, 28mm f/1.8, Speedlite 380 EX, Sekonic L758DR w/target, Manfrotto 3021 w/3030 pan-tilt head & quick release plate, POTN Strap |
| sponsored links |
#2 |
i don't own it but have been told yes - and no. No came from a friend who attended one of those Canon sponsored photo events in Hawaii, he asked the instructor about it and was told it's difficult to use outside a studio. I've been looking at the photos in the macro section here for awhile and if those people who use it are moving all those insects/plants into a studio they've been very busy. Based on what I see it here it is absolutely a lens you can stalk things with.
#3 |
it is my "walk around lens"! ha ha
definately, actually, it is probably the most versatile tool for higher mags on the field, I find that it is it's strenght. It is very solid built and you can go from 1:1 to 5:1 very easily. As Rick mentioned, many people here in the macro section use that lens in the field. I think this is the best testamony to that effect. You might want to rent one to try it out and see if it is your thing or not. Martin
6D & 50D EF 24-105 L, EF 100mm L IS, MP-E 65 Macro Twin Flash MT-24EX, 430 EX II & 270 EX |
| sponsored links |
#4 | |
#5 | |
#6 |
congrats on your purchase, it is a great lens, a lot of fun to use.
yes, I use it handheld, although, in winter, when I have nothing to do, I do use it with my automated macro rail. you might want to read in there: http://photography-on-the.net/forum/....php?t=1212971 I explain how I use it, in case it might be of interest. Of course we all have our own little techniques. Don't forget to share your pictures once you get your new toy! Martin
#7 | |
#8 |
no, I do not have the hood for the MP-E
#9 | |
As far as handholding the MP-E 65 goes, there are photographers like LordV or orionmystery that handhold with success a good deal of the time. LordV uses a bean pole in one hand partially holding the camera and partially holding the pole to steady thing. I have some success handholding if I am on my stomach and am able to brace my elbows on something, otherwise my hand holding is hit and miss with that lens. Naturally the higher your magnification the harder it is to steady things when using this lens.
7D 50D 100mm f 2.8 macro 180mm f 3.5 macro, MP-E-65 300mm f 2.8 500mm f4 Tokina 10-17mm fisheye 10-22mm 17-55mm 24-105mm 70-300mm 70-200 f 2.8 Mk II 100-400mm 1.4 TC 2X TC 580EX 430 EX II MT 24 EX |
#10 | |
#11 |
After I get my feet wet I'll try my extension tubes. If I decide to try a reversed lens I'll look for an old prime with a manual aperture setting. Actually I'll have my hands full for a while just learning the basics.
#12 | |
#13 |
This is what I use, I am not a very handy person, so I went for the already made thing
http://www.cognisys-inc.com/stacksho...0e885287aaThis works great and also Zerene has interface to interact with the rail. the specs would depend on how far in magnification you want to go (basically in how small increments it can go between shots, the higher the mag, the shallower the DOF, so you need something very precise, with an MP-E it would not be that much of an issue). I use it with 10x microscope objective and it is more than enough, I think it is precise enough to also work with a 20x, but do not wuote me on that. Martin
#14 | |
#15 |
I cant speak for the mpe but I use a reversed 28mm lens which makes a 2:1 magnification and when its stopped down it can be tricky to get shots. Because my lens is prime I have no need to focus so I keep it at infinity and slowly sway towards and away from my subject, snapping phtos as I pass through the hyperfocal point. I would imagine that it is the same way with the MPE. I can say that if you are using anything greater than 1:1 a flash is going to be mandatory so if you dont already have one figure out a way to squeeze one into the budget.
Wes ----------- Gear: canon t3i / 600d, 18-55mm kit, tokina 11-16mm, reversed: pentax-A 28mm, sigma APO 70-300, Sigma UC 70-210mm, Carl Zeiss 8x30b |
| Thread Tools | |
| Display Modes | |
