Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Weddings and Other Family Events Talk
Reply
Thread Tools Display Modes
Old 15th of August 2012 (Wed)   #1
Sogog
Sogog's Avatar
Default Considering F4...
Hey guys,
Saved up a little money over the summer and was thinking about purchasing some new lenses. I mainly shoot for the Greek Orthodox community where flash (in church) is generously used.
I was looking at the canon 17-40 F4 and 70-200 F4.
My current gear is as follows...
5D mark II
40D
17-55
28-135
50 1.8
580EX II
430EX
YN565
Later on, I could pick up a used prime or to for low light if needed.
What do you think? Let me know.
Thanks guys!!!
Sogog is offline   Reply With Quote
Old 15th of August 2012 (Wed)   #2
snakeman55
snakeman55's Avatar
Default Re: Considering F4...
It should be fine if you can use flash. I'd also consider 16-35 mki, you can get for under 1k. And a 135L or even just a 85 1.8 on your 40D.
-Adam
Wedding Photographers in Maryland
Gear
snakeman55 is offline   Reply With Quote
Old 15th of August 2012 (Wed)   #3
Red Tie Photography
Red Tie Photography's Avatar
I guess only you know how well it will work. To me, using a 70-200 f4 would certainly not work. However, I have the 24-105 f4 that works perfectly well for what I need it for (outdoor ceremonies and formals).
Red Tie Photography is offline   Reply With Quote
Old 15th of August 2012 (Wed)   #4
Sogog
Sogog's Avatar
Here's an idea...
How about just getting a 24mm I.4 lens. On crop it will give me 38mm and my 50mm 1.8 (or get a 1.4) will give me 85mm on crop.
4 lenses for the price of 2. Then, Adam, I could probably get the 135L.
Old 15th of August 2012 (Wed)   #5
Sogog
Sogog's Avatar
Any thoughts, ideas, and/or experiences regarding this issue?
Anyone?
Old 15th of August 2012 (Wed)   #6
Motor On
Motor On's Avatar
I have and use to death the 70-200 f4L non-IS, as long as your flashes are working you'll be good to go and still get some pretty decent bokeh with shallow DoF, it's an excellent portrait choice at the 200mm end. My basic cover all lens selection for the last few years has been the 18-55 f3.5-5.6 kit lens and the 70-200 f4, I'll be upgrading the kit lens next, hopefully this fall, to what will most likely be a 17-40 f4, unless I can find a deal on the 16-35 as mentioned earlier in the thread, as when it can be afforded if it's already L glass then I'm always for wider aperture being an option.
7D | 16-35 2.8L II | 50 1.4 | 85 1.8 | 135L 2.0 | 70-200 4L | Σ 300 2.8 EX DG | 580ex II | Σ 1.4x EX DG | 450D
Website |500px
Motor On is offline   Reply With Quote
Old 15th of August 2012 (Wed)   #7
Red Tie Photography
Originally Posted by Sogog View Post
Here's an idea...
To put it this way - if I had to use only 2 lenses, it would be my 35 and my 70-200. If you have a 24, 50 f1.4 (much better than the 1.8 in terms of reliability), 85 f1.8 and 135 I think you can do a solid job.
Old 16th of August 2012 (Thu)   #8
umphotography
umphotography's Avatar
I would strongly suggest F/2.8 glass for weddings even when flash is generously used as you suggest. For me its a no brainer. My flash is turned off during the ceremony.
I dont want to be a distraction to those that are there to witness the ceremony. Plus, even with the great high iso capabilities that i have with my cameras, its still a stop of light. Ive been in too many venues where ambient is F/2.8 @ 1/30 at 3200 iso. So with F/4(is) glass im up to 8000 or more to get a shutter speed to be able to hand hold so the F/2.8(is) glass is a must have for us.
If your talking a 1Dx in your bag where usable iso is 12800 and its realistic to be able to use it...different story. On my 5D3's, im good to 10,000 iso. We are often using fast primes and many times we are at F/2.5 at 1/125 at 3200 ISO with the 135 and 85.....they need shutter speed. Its almost impossible to Hand hold a 135L below 1/125 and not get motion blur.
So with your current gear, you need F/2.8 glass.
Mike
www.umphotography.com
Facebook
umphotography is offline   Reply With Quote
Old 16th of August 2012 (Thu)   #9
Red Tie Photography
Dont forget, f2.8 helps you focus faster as well. F4 will hunt a bit more.
Old 16th of August 2012 (Thu)   #10
Sogog
Sogog's Avatar
Really Brian? I didn't know. Is that only at f2.8 that it focuses faster on that lens?
Thx
Old 16th of August 2012 (Thu)   #11
Red Tie Photography
Thx
The wider the max f stop is on a lens, the more light it enables the lens to focus with. All lenses focus at their max aperture at the focal length you are (meaning if it is a variable aperture lens, it the max f stop is different at different focal lengths).
So, if you were using a f2.8 lens (even if you were shooting at f11), it is my understanding that the lens will focus with the aperture blades wide open (f2.8) and then close down when you take the photo. Therefore, a f2.8 lens will have 1 stop more light to help focus than a f4 lens will have.
Old 17th of August 2012 (Fri)   #12
dmward
Not only focus, but ETTL metering is more reliable with the faster lenses.
dmward is offline   Reply With Quote
Old 18th of August 2012 (Sat)   #13
joshhuntnm
I use the 24 - 105 and love it.
joshhuntnm is offline   Reply With Quote
Old 22nd of August 2012 (Wed)   #14
smorter
smorter's Avatar
Hate f/4
The difference between f/4 and f/2.8 will seldom cause you to get or miss a shot. You'll just end up with more noise = worse IQ
smorter is offline   Reply With Quote
Old 25th of August 2012 (Sat)   #15
davisphotos
I sold my 24-70 and bought a 17-40 a couple months ago, it was a great decision. I use the 17-40 mostly for formal portraits and at the reception, where I have off camera flashes, and I usually shoot at f4 or higher for some DOF in dancing shots. On the 5D Mark3, it focuses very quickly, and I rarely miss the extra stop.
davisphotos is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
