Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Compact Digitals by Canon
Reply
Thread Tools Display Modes
Old 13th of June 2003 (Fri)   #1
MeGotsACanon
Default The quickest shot?
Im trying to get rappid shooting on the A70. I found how to do it, but whats the optimus settings it should be on to get the quickest possible.
Im taking it out on a boat when wakeboarding. so it needs to have a quick shutter. Then needs to be the 2.2 sec shooting its meant to be capable of.
So my question: What mode, settings etc would u recomend for this?
MeGotsACanon is offline   Reply With Quote
Old 13th of June 2003 (Fri)   #2
PeterS45
Default Re: The quickest shot?
You're taking your cam on the wakeboard?? I would love to see the pictures ))))))
EOS 350D/Rebel XT, Sigma 18-125 & 55-200mm.
PeterS45 is offline   Reply With Quote
Old 13th of June 2003 (Fri)   #3
Pewterpez
he's taking the camera in the boat and taking pictures of the wakeboard
I'm not familiar with the A70, but I'd just leave it in auto mode, or if you must, play around with the shutter speeds until you get a small enough one that lets in enough light and keeps the blur away (remember that you'll be moving fast....or I'd hope you'd be :P )
Pewterpez is offline   Reply With Quote
Old 13th of June 2003 (Fri)   #4
MeGotsACanon
I wouldn't take it on the wakeboard, but i would take it on double skii's. I wouldn't fall off them and could get a pic of someone wakeboardn.
The main purpose is in the boat. I want to get the 2.2fps rappid shooting. Auto mote takes it time to decide what to do though. Therefore downgrading the fps.
I though the 1/2000 of a sec shutter would be the best but i dont know if it supports rappid shooting. Currently im on the quick speed. THe turn dial with the guy running. Thats the best i can do for now, but its not 2.2fps.
Old 13th of June 2003 (Fri)   #5
Pewterpez
hrm, according to the canon manual ( http://www.powershot.com/powershot2/...60A70_CUGe.pdf page 87) you "just" hit the FUNC button, scroll to the shooting mode, and then move left or right until you get into the continuous shooting mode and then press FUNC again to exit. Now, you must hold the shutter button at halfway to determine focus, and then hold on the shutter to snap images at the 2.2 p/s....
They also note that the flash slows this down....but you shouldn't need that due to the brightness of being outdoors...and also, it could be refocusing everytime you're shooting, so try using manual focus (?)
those are just my ideas..I have the canon s50 and it seems to shoot at the 1.5 p/s the box says it can.
Old 14th of June 2003 (Sat)   #6
MeGotsACanon
I found how to do quick shots in the manual. Thats where it told me that different modes will have different fps. Due to the amount of work they have to do and stuff.
At the moment i reckon i'm getting 1 a second.
Just trying to find the optimum one.
Old 14th of June 2003 (Sat)   #7
PeterS45
Try setting the resolution to Medium and the compression to Normal. Then use the Shutter Priority and set the speed to 1/125, set the manual focus to infinity and fire away. That should do the trick. My S45 can also be set to HS and that even gives me a lot more than 2 fps.
Old 14th of June 2003 (Sat)   #8
MeGotsACanon
I managed to get 2fps!!!!!
I took photos of a stopwatch. Sad i know but gives good results. The first 6 photos managed the 2fps. After that a single shot chuged down to 1 photo every 3 seconds and just got worse.
Im thinking short bursts are fine, but what if we want a realy long burst of photos?
Peter: Once i figure out how to change my settings like that i'll see what i can get.
Old 14th of June 2003 (Sat)   #9
PeterS45
The slowing down in performance is caused by the internal memory of your camera. After taking a pictures it has to be transferred from the internal memory to the flash card, and that's not fast enough. So once the memory is full the camera can only take the next picture when the first picture you took has been transferred to the CF.
By the way, try using the "Fast Shutter" (the icon with the running figure).
Old 14th of June 2003 (Sat)   #10
Pewterpez
MeGotsACanon - what do you mean by a long burst of pictures?? like 30 pictures over 15 seconds??
well, that's physcially impossible with your camera, and well frankly, impossible with most cameras except for the high end DSLR's that have enough memory to cache that many frames during shooting....
Old 14th of June 2003 (Sat)   #11
CyberDyneSystems
Admin - MOD OF STEEL...
CyberDyneSystems's Avatar
lol,.. even the 10D will only give you 9 frames a 3 fps before it slows down to about one pic per second or slower .
CyberDyneSystems is offline   Reply With Quote
Old 15th of June 2003 (Sun)   #12
MeGotsACanon
yeah thats what i got the 2fps on the runing guy.
Sucks about the limited picture taking. Would be good if you could beef up the mem like on a computer.
Old 15th of June 2003 (Sun)   #13
MeGotsACanon
Well i found a way to get a large burst of pictures.
Problem: they have to be 640 res and quality normal. I took them for 30 seconds without any problems. Just when i go wakeboarding i wont be able to print any clasisc face plants.
Old 15th of June 2003 (Sun)   #14
PeterS45
Yep, the only way to make sure the internal memory of your camera isn't filled up so soon is making smaller pics.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
quickest wedding ever!! tony fanning Weddings and Other Family Events 22 6th of July 2007 (Fri) 14:38
Quickest delivery ever Pat Canon EF and EF-S Lenses 11 5th of December 2006 (Tue) 16:40
Quickest Photo Session PhotoScout People 2 28th of July 2006 (Fri) 22:40
The quickest ceremony; EVER!!!! (well for me) rightaway Weddings and Other Family Events 12 4th of June 2006 (Sun) 14:33
PS Q: Quickest way to get the size of a selection? dphoto RAW, Post Processing and Printing 2 16th of December 2004 (Thu) 19:08
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
