| sponsored links |
Thread Tools | Display Modes |
#1 |
I'm going on a whale watch in the morning (in Boothbay Harbor, Maine).
I have with me: Canon Rebel T1i. Canon 5D Mark II. Canon S95. Canon 24-105 f4 L IS. Canon 70-200 f4 L IS. I'm inclined to just stick with the 5DII and 70-200, and use the S95 for wider-angle shots. I'll have the 24-105 in my pack in case I want to switch lenses. But I was thinking, how about using both bodies? 70-200 on the T1i, and 24-105 on the 5DII. If my thinking and calculations are correct, the T1i with 15MP in an APS-C (22.3mmx14.9mm sensor; 4.68um pixels) will give me more resolution for better cropping later. If I want a given whale at a given distance to appear the same size in the frame after cropping, I would have to divide the 5DII's 21.1MP full frame (6.39um pixels) by 1.6. That leaves me with 8.3MP (the 5DII's pixels are bigger). Am I calculating correctly? I'm expecting clear sunny conditions, so I should be fine at ISOs below 400, meaning better high ISO performance of the 5DII is not a factor to consider. Thoughts? |
| sponsored links |
#2 |
I'd take the Rebel and the 70-200, leave the 5d2 behind.
#3 |
agreed. Unless this is a private tour, the public tours can get a bit crowded and things happen. Also the salt spray can be helish on equipment.
image creating thingamajiggy, size and charge addition, Lens that doesnt move, wider lens that doesnt move but less deep like, an even wider lens that doesnt move and even less deep like, zoomy lens, Better zoomy lens, bigger zoomy lens, excellent bigish zoomy Lens, light maker, excellent zoomy Lens magnifier My Photo Blog: http://joetakesphotos.com/ |
| sponsored links |
| Thread Tools | |
| Display Modes | |
| Lens choice for watch photography | tats | Still Life, B/W & Experimental | 5 | 25th of May 2012 (Fri) 12:36 |
| Need some advice on body choice/lens choice | Stevowns | Canon EF and EF-S Lenses | 3 | 18th of November 2009 (Wed) 21:16 |
| Gloucester Whale Watch | Becca | Wildlife | 15 | 19th of August 2008 (Tue) 15:42 |
| Gloucester Whale Watch | wlaramie | Wildlife | 14 | 24th of August 2007 (Fri) 11:44 |
| New Hamsphire Whale Watch | Becca | Wildlife | 9 | 6th of October 2006 (Fri) 13:38 |
