Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Compact Digitals by Canon
Reply
Thread Tools Display Modes
Old 13th of June 2003 (Fri)   #1
deaconblue
Default Sideways Move
Is there a way of rotating a move by 90 degrees? I tilted the camera and found out the hard way that that feature only works with stills.
deaconblue is offline   Reply With Quote
Old 13th of June 2003 (Fri)   #2
MeGotsACanon
Default Re: Sideways Move
I think the movies on cams are very limiting. I noticed you can't zoom when shooting or replaying. But eventualy they will get better.
All i can suggest is to modify it on the computer and then put the video back on the cam.
MeGotsACanon is offline   Reply With Quote
Old 14th of June 2003 (Sat)   #3
JohnnyE
Default Re: Re: Sideways Move
I thought you couldn't put the videos back on the cam. Isn't that the case?
JohnnyE is offline   Reply With Quote
Old 15th of June 2003 (Sun)   #4
MeGotsACanon
I've heard alot of people having trouble putting them back on.
Apparently its possible but i haven't tried it as yet. If someone can, please let us know.
Old 16th of June 2003 (Mon)   #5
stduc
Having just got an A70 to replace an ailing A20 I'm currently in "test/play/suck it & see" mode!
So I tried a portrait video - and tried to rotate it. So far the only solution I can offer you is tiresome, clumsy and far from perfect - but for the record - this is what I found worked (sorta)
I used videowrks to convert the movie to an uncompressed AVI.
I used Jasc animation pro to rotate the frames - but this (a) lost the sound and (b) changed the movie from 30 seconds to 31 and 7/15ths of a second! [this is because animation shop can't set frame durations to fractions of a millisecond!)
So - I then used cooledit to extract the sound from the original avi file and stretch it to the correct length (you can do some clever stuff in cooledit!)
Finally I used videoworks to import the sound to the uncompressed rotated move and re-compress it from the 1Gb file to 2 Megs!
So I now have a movie that plays - but the sound is still a bit out of sync. It also looks weird being in portrait mode so I shan't be doing it again (The above also took me an hour or so as well!!!)
What I would like to be able to do though, is edit a movie and put it back on the camera so it plays. (See my post for details)
Best of luck. - And if anyone has a better way please be sure to tell us all.
stduc is offline   Reply With Quote
Old 16th of June 2003 (Mon)   #6
warrenpass
There's got to be a better way of rotating movies?
warrenpass is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Slowly Sideways (UK) Robuk Motorsports 9 29th of June 2007 (Fri) 17:54
Get it sideways rally g_robins Motorsports 6 18th of April 2007 (Wed) 06:48
Upsidedown and sideways. Birdmanc Birds 5 9th of April 2007 (Mon) 18:45
Sideways 3rd turn Motorsports 2 17th of October 2006 (Tue) 20:41
Sittin' sideways... AirBrontosaurus Macro 4 22nd of May 2006 (Mon) 08:53
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
