Thread started 11 Sep 2012 (Tuesday) 07:12
5D MKII Battery life
ItsMike
Sep 11, 2012 07:12 |  #1
Just curious as to what others are getting..
I noticed that my battery life really stinks..
So far on this particular charge, I am at 250 shots with only 2 real short (20 sec or so) video clips.. Battery is at 45%..
Is this normal?
Gear
chrismarriott66
Gallery: 14 photos
Joined Jan 2012
Sep 11, 2012 08:16 |  #2
Do you use liveview a lot, because that sucks battery pretty quickly...?
Chris Marriott Photography (external link)| Facebook (external link)
Complete Gear | 1ds iii | 5d iii | 50d | EF 16-35 f2.8 L USM ii | EF 24-70 f2.8 L USM | Σ 70-200 f2.8 ii EX DG HSM | Σ 35mm f1.4 Art | EF 50mm f1.4 USM | EF 85mm f1.8 USM | EF 85mm f1.2 L USM ii | 600EX-RT | 580EX ii | 430EX ii | YN622Cs |
pwm2
"Sorry for being a noob"
Sep 11, 2012 08:28 |  #3
How old are the batteries. Alas, li-ion batteries ages a lot. Often 15-20% lost capacity every year. More loss if stored in an warm environment. Less if left half-charged in the fridge between use.
Nortelbert
Sep 11, 2012 09:42 |  #4
I usually get about 1100-1200 shots
5Dmaniac
Sep 11, 2012 10:11 |  #5
Battery lasts forever - at least 1200 shots. I do not use Liveview much though and don't shoot video at all.
amfoto1
Sep 11, 2012 11:01 |  #6
Video uses up a lot of power. The same with long exposures especially if NR is set (which requires a second shot of equal duration). Live View and Mirror Lockup use more power, too. Really anything during which the mirror is held up and/or the shutter held open will continuously draw power and run the battery down faster.
Playback of images on the rear LCD screen also uses a lot of power.
5DII doesn't have a built-in flash.... that's another heavy power consumer on cameras that have one.
Shorter exposures, metering, normal image processing/storage and IS don't use a lot of power.
The more recent model cameras wake up so quickly at the touch of a button (the 10D and earlier were sloooowwww), you can conserve a lot of power by setting set the camera to go into sleep mode after only a minute or two.... whatever the shortest possible. Also it will help to set it so that image playback isn't automatic... so that it's "on demand" only.
Consider a battery grip to double the number of batteries and/or get some spares. Fortunately, LP-E6 have come way down in price. The 5DII was the first camera to use the battery and when the model was new, OEM batts were all that was available, they were in really short supply, and commonly sold for twice what they do now (more than list price). There are decent, usable 3rd party batts now too, that cost even less than the OEM and give the same performance. Check the major online retailers such as Adorama, B&H, Sterlingtek.
5DII, 7DII(x2), 7D(x2) & other cameras. 10-22mm, Tokina 12-24/4, 20/2.8, TS 24/3.5L, 24-70/2.8L, 28/1.8, 28-135 IS (x2), TS 45/2.8, 50/1.4, Tamron 60/2.0, 70-200/4L IS, 70-200/2.8 IS, 85/1.8, Tamron 90/2.5 Macro, 100/2.8 USM, 100-400L II, 135/2L, 180/3.5L, 300/4L IS (x2), 300/2.8L IS, 500/4L IS, EF 1.4X II, EF 2X II. Flashes, studio strobes & various access. - FLICKR (external link) - EXPOSUREMANAGER (external link)
ItsMike
Sep 11, 2012 11:48 |  #7
Very limited use of Live View.. Really only to shoot a small clip (only 2 short 20sec. clips)
No IS
Battery is about 2 weeks old..
**Edit**
NR is off.. only about 5 Long exposure shots.. (15-30Sec each..)
Possibly take a ride to LCS to see if they can swap my battery..
Gear
Perfect_10
Joined Aug 2004
Sep 11, 2012 12:49 |  #8
ItsMike wrote in post #14976924 (external link)
.. .. Battery is about 2 weeks old..
Maybe the battery just needs a few full charge / discharge cycles before it reaches it's peak perfomance
My Gear List  :p
davidc502
Sep 11, 2012 12:51 |  #9
Look at the battery stats in the 5d2 menu.
1st stat is battery life
2nd stat is battery recycle or how well it will hold a charge. A new battery will show 3 bars. If the battery is only showing 1 bar then it probably needs to be replaced because it isn't holding a charge.
_
My Gear is ---> Here
pwm2
Sep 11, 2012 13:36 |  #10
It sounds like you get much less performance than what is expected from a new battery. But consider giving it a couple of cycles and see what happens.
I think I have managed closer to 3k shots with two new batteries in the grip. But with bracketing etc, not all have been with review on the display.
JohnB57
Sep 11, 2012 13:58 as a reply to  @ pwm2's post |  #11
Perfect_10 wrote in post #14977170 (external link)
Mine is three weeks old and the performance has improved significantly with subsequent charges. Live view and video wreck battery life, as many have mentioned. Great camera isn't it?
ItsMike
Sep 11, 2012 15:28 |  #12
I love this camera!!!
Just opened the box to my 70-300VC Tamron.. in the process of Importing into LR as I type...
Amazes me every time I hit the shutter...
Gear
bent ­ toe
Gallery: 106 photos
Best ofs: 5
Joined Jul 2012
Sep 11, 2012 15:32 |  #13
ItsMike wrote in post #14975918 (external link)
Is this normal?
Weird, my 60D has the same battery as yours (and 7D) LP-E6 i think.. or is it B?
Anyway.. around 2000 shots over the course of a week and it's still around 15-25% capacity.
You might have a mailfunction battery?
"High life on low budget"
bent photos (external link)Portfoliobox (external link)
X-Pro1 XF 35 f/1.4
ItsMike
Sep 11, 2012 16:15 |  #14
Going to wait and see what happens.. About
41%
310 Shots
3 green Bars...
Going to charge it soon, see what I get next time.. then head on over to LCS..
Gear
John ­ from ­ PA
Joined May 2003
Sep 11, 2012 19:10 |  #15
That was the case with a new battery I purchased this summer, prior to an Alaska cruise. The initial life was so short I really thought it defective. By the time the trip rolled around I had charged it perhaps three times and it seemed to be normal (500 shots at maybe 50%).
8,198 views & 0 likes for this thread
version 2.0 /
Latest registered member is Nidge
815 guests, 456 members online
