Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Compact Digitals by Canon
Reply
Thread Tools Display Modes
Old 15th of June 2003 (Sun)   #1
MeGotsACanon
Default Putting movies back using USB
I've got an A70 and trying to put movies back on using just USB. I don't have a card reader-writer.
Is it possible to put the movies back, i've only seen the "Upload images". Nothing to do with movies. But i figure if you can put pics back on to the camera you must be able to put movies back on somehow.
Any Ideas?
MeGotsACanon is offline   Reply With Quote
Old 17th of June 2003 (Tue)   #2
MeGotsACanon
Default Re: Putting movies back using USB
So i have a feeling that its impossible.
How about if i go buy a card reader-writer? Will i be able to do it then, even if the movie isnt edited, just taken off and put back on to save room on the compact flash.
Old 17th of June 2003 (Tue)   #3
stduc
As far as a card reader is concerned the CF card is just a disk drive. So you can copy/move/delete anything you like. If you intend to play the replaced movie on the camera then don't forget to save/replace the THM file with the AVI! If you forget the THM file then the camera doesn't 'see' the movie
stduc is offline   Reply With Quote
Old 17th of June 2003 (Tue)   #4
MeGotsACanon
I guess im gonna have to go get me a bard reader-writer then.
If i go cheap, will it be like a camera and u get what u pay for or like compact flash and just a brand name?
Old 17th of June 2003 (Tue)   #5
k7jmb
USB readers are pretty generic and usually the software that comes with them is unneeded junk, I got a Dazzle brand reader at Good Guys for 20 bucks.
k7jmb is offline   Reply With Quote
Old 17th of June 2003 (Tue)   #6
MeGotsACanon
What currency was that in, US or AUS?
And i asume u have no problems with ur reader, the cheapest ive found is $50 Aus.
Old 18th of June 2003 (Wed)   #7
k7jmb
US
Old 19th of June 2003 (Thu)   #8
MeGotsACanon
Dam, though id found a realy cheap one for a minute.
Any recomendations or things i should look for before buying one? I saw a 6 in one reader, takes 6 different types but doubled the price.
Old 19th of June 2003 (Thu)   #9
stduc
I got myself one of these
It a Scan USB 7 in 1 Card Reader (SM/MMC/SD/CF/Microdrive/Mstick) . It works very well and only cost me 11.69 GBP. I can even use a compact flash card and an SM card at the same time. I got it because I figured it would offer me some future proofing. The only problems I have with it are that in order for it so 'see' that the card has been removed and re-inserted you have to disconnect it after using 'eject' and then insert the card and then re-connect the USB. XP is not too fond of booting or shutting down either if the device is connected at the time. But having to insert the card and then the USB cable is no big deal.
You can get it from these guys Scan by following the link at the top of the page called 'Flash + Smart' and going to the bootom of the page. Where you get it from outside of the UK though I wouldn't know.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Playing Movies back on camera gustaia Small Compact Digitals by Canon 3 11th of January 2007 (Thu) 03:14
Putting SD450 LCD back on holmgren Small Compact Digitals by Canon 3 31st of August 2006 (Thu) 15:58
Uploading movies back into the camera? TomSelleck Small Compact Digitals by Canon 1 8th of December 2003 (Mon) 08:27
Putting movies back using USB MeGotsACanon RAW, Post Processing and Printing 3 19th of June 2003 (Thu) 16:25
USB Driver 3.61 is back rknol RAW, Post Processing and Printing 5 18th of April 2001 (Wed) 16:01
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
