#1 |
I am setting up a home/portable studio, and am wondering if there are any standards on light positioning. like where to put them.. what distance from the subject they should be etc.. Also, should i get 500 or 1000 watts? or something in between?
any help would be appreciated. |
| sponsored links |
#2 |
Greetings-
Your question is too broad. There are several good books out, and several tutorials on-line. B&H photo's catalog has a good tutorial as well. It's pretty impossible to describe lighting on a verbal forum here...best of luck- Bob |
#3 | |
Apparently you've made a decision to go with hot lights. The most important "standard" with those is to try not to melt your subject |
| sponsored links |
#4 |
Actually i have decided to go with a 1,000 watt flash system.. I presume that will be more than enough power.. i will check out those tutorials.. thanks.
#5 |
Those are typically rated in wattseconds (joules). Then the next question is "actual" or "effective". But in any case the question of "enough" can only be answered knowing the subject, studio, and a bunch of other variables.
It will probably be fine. |
#6 |
1,000 Watts/Seconds.. i believe.. what exactly is a joule? that wasnt mentioned anywhere on the specs.. but i couldve missed it. Ive heard the term used alot.. I understand AC/DC watts/amps etc.. but joule, not sure how that plays into it..
The studio is a large room in my house.. but i wanted a mobile kit so that i can shoot anywhere. Hopefully churches eventually as i would like to get into wedding photography. |
#7 |
A watt is a joule per second. Flashes are normally rated in joules or wattseconds (watts * seconds) which is the same thing. Continuous lighting is normally measured in watts since it runs for an indefinite amount of time.
#8 | |
Also, watt-seconds are not the same as watts/second. There are many technical terms scattered around modern photography, and some photography classes teach them. ---Bob Gross--- |
#9 |
Ahhh wattage.. demystified. thanks for you help guys. Can anyone recommend any good books?
#10 |
Spinner, sounds like your like me...in the beginning of studio lighting and a possible new career. I ended up getting a Dyna-Lite 2 head 1000 set up...very portable.
For good information on what is available, definitions, and general set up try the catalog from B&H Photo. Read this message thread... http://photography-on-the.net/forum/...?t=11782#59125 |
#11 |
You sound like you really need to learn more before you go out and sink a lot of money into more equipment. I'd suggest picking up some books to learn the basics or take some classes at the local community college.
#12 |
Actually,
i have a decent understanding of what im doing, there are just a few things that i dont get. And personally.. i learn thru experience. Books will never replace actual experience. Although i did ask, for some good book references. |
#13 |
Rick "who is not suited for any one title" Denney
A good book really is your best resource. Kodak used to produce an excellent portraiture guide that talked about classic lighting methods using four lights. But I haven't seen it in years (heck, I haven't seen my copy in years).
Let me see if I can give you a quick run-down to get you started. You'll start with two lights. The brighter light is called the main light, and the dimmer light is the fill light. You may also use a light on the background, and another light to add specular highlights to hair, called, um, a background light and a hair light. But learn how to use two first. The subject will look at the camera usually with an angled face. If the main light is lighting the side of the face turned away from the camera, it's called short lighting, and it's good for people with round faces. If the main light is illuminating the side of the face turned toward the camera, it's called broad lighting and it's good for people with thin faces. I always set the main light so that a triangle of light appears below the eye on the side of the face it is not illuminating. This means that the shadow of the tip of the nose falls off the face, but still provides three-dimensional modeling. For rugged subjects (usually men), I suggest starting with a main light that is 1.5 or 2 stops brighter than the fill light. For delicate subjects (usually women), the ratio might be just one stop. Measure each separately with a flash meter (you can't live without a flash meter if you do studio lights--get one). Adjust brightness using the controls, if you have them, or by moving the light closer to make it brighter and farther to make it dimmer. The smaller the light source as it appears from the subject's position, the harder the shadow edges. Classical lighting suggests visible shadow lines for the main light, but not for the fill light, so I use a small (24") reflective umbrella for the main light and a large (the larger the better, mine is four feet) shoot-through umbrella for the fill light. When you are ready to spend real money, you'll buy the expensive soft-boxes, but for now umbrellas are cheap and they work fine. For the modern look with no shadows at all, you'll want big shoot-through umbrellas as close to the subject as possible to envelop the subject with light. The pros would use 6-foot softboxes. But learn classical lighting first, and make portraits of your friends using short lighting and broad lighting and the proper ratio of main light to fill light. When you can do that, you'll be able to tell how the pros get their effects by looking and their images, and (hint) by looking for the reflections of the lights in the eyes of their subjects. I have a beat-up old Speedotron Brown Line 1600-ws head and four lights that has served me well. It's a lot of light--you could do most things pretty easily with 1000 ws, especially if it's a monolight (mine spreads the power over all the lights, and in a four light setup the most I can get from the main light is 800--it's plenty). Rick "who still likes the Rembrandt lighting" Denney
The List |
#14 |
Thanks for the tips.. very usefull!
#15 |
Actually i just recieved my novatron kit, and thanks to UPS, its got a broken light, and the inside case molding is like trashed. The other two lights work, but now im very.. well.. angry.. I guess i will be working with two lights for now. Curious though. my kit came with 1 light that has no stop downs, and the other two do.. Whats up with that? i can see the need to stop light down, but why not give me that function on all of them?
huh.. thanks for the tips guys. |
| Thread Tools | |
| Display Modes | |
| My new home studio | Halliday | Small Flash and Studio Lighting | 6 | 26th of May 2007 (Sat) 11:27 |
| In home studio help | cmshaggy@telus.net | People | 2 | 21st of March 2007 (Wed) 13:02 |
| New home studio.. need help | John Mac | Small Flash and Studio Lighting | 0 | 10th of February 2007 (Sat) 08:11 |
| Home Studio: What for? | SYS | Small Flash and Studio Lighting | 9 | 21st of January 2007 (Sun) 11:20 |
| Need help with home studio!!! | pilot1962 | Small Flash and Studio Lighting | 4 | 2nd of November 2006 (Thu) 07:26 |
