Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 29th of December 2005 (Thu)   #1
20D_Newbie
Default 580EX Battery Question
Well the Big Brown truck just delivered my 580EX from BH Photo!!!
The manual says (4) AA alkaline batteries but is there any advantage to using something like the Photo Lithium series from Energizer? I have a portable DAT recorder that runs about an hour or so on alkaline that will run over 3 hours on the Photo Lithium AA batteries.
Any ideas?
Canon EOS 7D with BG-E7 battery grip, EOS 40D with BG-E2 battery grip, Canon 20D, Canon EF 70-200mm F2.8L IS, Canon EF 24-70mm F2.8L, EF 300mm F4L IS, EF 400mm F5.6L, EF-S 17-40mm F4.0L, Canon Speedlite 580EX
20D_Newbie is offline   Reply With Quote
Old 29th of December 2005 (Thu)   #2
Ronald S. Jr.
Prodigal "Brick" Layer
Ronald S. Jr.'s Avatar
Default Re: 580EX Battery Question
Well lithium definitely runs longer, but if you get some NimH you can recharge them, and they also last significantly longer than alkaline. Plus, you can recharge them in 15 minutes. Look for energizer 2500 mAh AA's. Silver, black, and lime green markings.
Lithium is just too expensive for disposables, imo.
Mac users swear by their computers. PC users swear at theirs.
Ronald S. Jr. is offline   Reply With Quote
Old 29th of December 2005 (Thu)   #3
Jon
Moderator
Cocker Spaniel Mod
Jon's Avatar
Never actually run a comparison between the alkaline and Li AAs in a flash, but the lithiums will give you faster flash recycle times. Flash battery consumption is more like digital camera consumption, and the higher peak current load is a significant advantage. Of course, rechargeable NiMH cells will also give you the faster recycle time,and cost significantly less than either of the disposables over the life of trhe flash.
Jon
EOS, Powershot and Domke - it doesn't get any better than this!
T90 and stuff | F-1n, New F-1, FTb and more stuff out on loan
Cocker Spaniels
DC Cherry Blossoms
Jon is offline   Reply With Quote
Old 29th of December 2005 (Thu)   #4
snibbetsj
Definitely agree. You can get NimH about $2.50 apiece and recharge 'em a bunch of times. I've got some I know I've charged at least 15 times and they still work like new. I fully expect to be able to recharge at least 100 times before they're dead.
Jeff Stebbins
snibbetsj is offline   Reply With Quote
Old 29th of December 2005 (Thu)   #5
20D_Newbie
I actually have some Panasonic 2100mAh Ni-MH batteries that I forgot about. I will give them a try.
Old 29th of December 2005 (Thu)   #6
Doom1701e
Doom1701e's Avatar
I just bought some of the Energizer rechargables mentioned earlier (2500 mAh) at Worst Buy for $14.99 or you can get the rapid charger and 4 batteries for $30 on sale right now. I have been using some Energizer rechargable 2100 mAh batteries for the last year in my 420EX and they have been great. Go for the rechargables, you will save alot of money in the long run.
Doom1701e is offline   Reply With Quote
Old 29th of December 2005 (Thu)   #7
snibbetsj
My local Wal-Mart has a 4-pack of Duracell 2300maH with a charger for $18.00. Add an eight pack of like Duracells for $9.98 and you'll be set for several hundred shots.
Jeff Stebbins
Old 29th of December 2005 (Thu)   #8
Ronald S. Jr.
Be aware, though. The "regular" charger takes several hours to charge. I use the 15-minute charger. I don't much care if it eventually kills the batteries (which is what some have said). When it does, I'll buy more.
Old 29th of December 2005 (Thu)   #9
netadmin22
I am not an expert but I had a bad experience with a 15 minute charger. It overheated the batteries and they leaked in my flash. BEWARE. Not all rechargeables can be used in a 15 minute charger. I disposed of the fast charger and now use a one hour charger.
netadmin22 is offline   Reply With Quote
Old 29th of December 2005 (Thu)   #10
20D_Newbie
I was a Sam's Club and saw a package of Energizers 2500mAh Ni-MH batteries. It was a slow charger, 8 AA and 4 AAA for $25. Seemed like a deal so I picked it up and they are charging now!!!
Old 29th of December 2005 (Thu)   #11
Ronald S. Jr.
Good job.
Old 29th of December 2005 (Thu)   #12
tim
Light Bringer
tim's Avatar
I hope you mean 2500mah Slow chargers are better for the batteries so good call there.
tim is offline   Reply With Quote
Old 29th of December 2005 (Thu)   #13
20D_Newbie
Oops!!!! I fixed it. It was a typo, they were 2500mAh.
Old 29th of December 2005 (Thu)   #14
Ronald S. Jr.
I just assumed..
Old 30th of December 2005 (Fri)   #15
malla1962
malla1962's Avatar
I use energizer 2500mah in my 580 and they seem to last forever.
malla1962 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
question about 580EX and battery grip slappy sam Accessories & Storage 7 25th of January 2007 (Thu) 17:09
580EX Battery Door Question zmaerdstyle Small Flash and Studio Lighting 17 20th of September 2006 (Wed) 20:29
What battery for 580EX? Glyyde Accessories & Storage 8 5th of June 2006 (Mon) 01:51
Canon Battery Pack question for 580EX geester Accessories & Storage 3 8th of May 2006 (Mon) 13:13
Poor Battery Life on Speedlite 580EX? or Some other problems? Battery Recommendation? EricKonieczny Accessories & Storage 4 12th of March 2005 (Sat) 19:20
