Thread started 21 Oct 2012 (Sunday) 06:39
7D Focus :-) Why did this happen?
Arte ­ Automobilistica
Oct 21, 2012 06:39 |  #1
Hi
After reading far too much on the 7D's AF "problems" (yes I did read the manual etc etc...) I took it for a test yesterday using, among others, 50mm (w/o filter) and centre single AF point expansion. In the photo the AF point (centre) was just above the green sticker and the f/stop was 5.6.
Why is only specifically the interior of the car in focus?
NelPhotos.co.uk (external link)
Work: 7D + Sigma 100-300 4
Play: Kiss X4 + 15-85 IS + 10-22 + 50 1.8 II + Vivitar 1 70-210 3.5
EOS-M + 18-55 + FD 50 1.4 + FD 135 2.8 + Tamron 35-80 1A
G9, SX280 HS + CHDK, Casio EX-FH 100, Toshiba L505-144 & iPad 2
mridley
Oct 21, 2012 06:44 |  #2
Arte Automobilistica wrote in post #15149237 (external link)
Hi
After reading far too much on the 7D's AF "problems" (yes I did read the manual etc etc...) I took it for a test yesterday using, among others, 50mm (w/o filter) and centre single AF point expansion. In the photo the AF point (centre) was between the number and the green sticker and the f/stop was 5.6.
Why is the interior of the car in focus?
Post the picture, you will get a better response then..
Lowner
"I'm the original idiot"
Oct 21, 2012 06:45 |  #3
Can we see the picture?
Richard
SMP_Homer
Oct 21, 2012 08:13 |  #4
if the F point was above the green sticker - that's just a white area - AF sensor may have had issue locking to something for focus
helps to focus on something the sensor can use... like the stripe that runs front to back on the side, or the '37' on the door
5D3 x2 / 5D2 / 1D IV / 6D
Sig85 /35L/100L/135L/16-35L II/70-200L II/100-400L
B400 x2 / B800 x2 / ABR800 / VML x2
600EX x5
TT5 x8 /
PW TT1 / AC3 x3 / AC9 x4
alquimista
Gallery: 82 photos
Oct 21, 2012 08:18 |  #5
SMP_Homer wrote in post #15149394 (external link)
agree, I had that issue before
la costura de Dios
http://www.flickr.com/​photos/andresmoline/ (external link)
TheBigDog
Gallery: 31 photos
Oct 21, 2012 08:19 |  #6
i think it's more motion blur than lack of focus, panning skills can take some time to perfect.
Next time up the ISO a bit and open up the lens a little to go quicker on the shutter speed and you should see better results.
Chris
http://www.cegphotogra​phy.com/ (external link)
Flickr (external link) * Facebook (external link)
Nikon D5 * D810 * 24-70 f/2.8 * Sigma 50mm f/1.4 Art * 105mm f/2.8 * 70-200 f/2.8 * 80-400mm * Sigma Sport 150-600mm
BigAl007
Gallery: 515 photos
Oct 21, 2012 09:19 |  #7
Looking at the image it looks as if the front end of the car has some vertical movement upwards, with the car rotating about a point somewhere near the back axle. This causes some motion blur to be visible at the extremities but but the closer you get to the axis of rotation the less movement the is so the less it "shows" in the image.
You can see a similar effect on this Red Bull Sbach 300. The aircraft can roll at 540 degrees a second, so even though the shutter speed was 1/160 you can see quite a bit of rotation blur in the wing tips. In the second one you can see that the axis of rotation is not always where you might expect it to be, as in this one the axis is actually about 4 feet out on the port wing, and not parallel to the fuselage. This second shot was take at only 1/100th.
Alan
My Flickr (external link)
ebiggs
Gallery: 24 photos
Joined Oct 2012
Oct 21, 2012 09:25 as a reply to  @ BigAl007's post |  #8
I agree:) with this assesment.
G1x, EOS 1Dx, EOS 1D Mk IV, ef 8-15mm f4L,
ef 16-35mm f2.8L II, ef 24-70mm f2.8L II, ef 70-200mm f/2.8L IS II,
Sigma 150-600mm f5-6.3 DG OS HSM Sport
*** PS 6, ACR 9.3, Lightroom 6.5 ***
DC ­ Fan
Oct 21, 2012 10:06 |  #9
Hi
Because that's what happens sometimes when a slow shutter speed is used to generate blur that gives the illusion of motion in a still image of a moving subject.
From the vantage of a fixed point, the different parts of a moving object will appear to move at a different speed. That will mean different degrees of blur for each portion of the passing object. The parallax effect (external link) that defines the panning illusion is unpredictable when a human is operating the camera. There is nothing wrong or unusual in the sample image, and there is nothing wrong with the camera or the lens.
Oct 21, 2012 10:49 |  #10
Well that was where I was aiming :) but the car moving in 3 dimensions made it rather difficult.
TheBigDog wrote in post #15149408 (external link)
i think it's more motion blur than lack of focus, panning skills can take some time to perfect. Next time up the ISO a bit and open up the lens a little to go quicker on the shutter speed and you should see better results.
I tried to keep ISO as low as possible to limit noise. I used 5.6 as I wanted to use the cameras "enhanced" AF points and wanted to see motion in the wheels hence the lowish shutter speed
DC Fan wrote in post #15149710 (external link)
Would a higher shutterspeed put more of the car in focus or would it rely totally on a different position?
DC ­ Fan
Oct 21, 2012 11:29 |  #11
Arte Automobilistica wrote in post #15149835 (external link)
Focus and motion blur are entirely different factors. A higher shutter speed would minimize motion blur, but it would not change focus. In this case, everything depends on what you really want from the picture. If you want every portion of the car perfectly sharp, the best way to accomplish that is to use a fast shutter speed. However, using a slow shutter speed means portions of the image will be blurred,and the blur creates the illusion of motion. The slower the shutter speed, the greater the motion blur and the less predictable that blur will be. A high shutter speed means a sharp subject that looks as if it's standing still. Example:
Focal Length: 300.0mm
Aperture: f/5.6
Exposure Time: 0.0016 s (1/640)
ISO equiv: 320
Exposure Bias: none
Metering Mode: Matrix
Exposure: shutter priority (semi-auto)
White Balance: Auto
Flash Fired: No (enforced)
Orientation: Normal
Color Space: sRGB
It takes experience and skill to consistently generate images that balance motion blur and a sharp subject. Example:
Focal Length: 183.0mm
Aperture: f/29.0
Exposure Time: 0.020 s (1/50)
ISO equiv: 100
Exposure Bias: none
Metering Mode: Partial
White Balance: Auto
Orientation: Normal
Color Space: sRGB
FrayAdjacent
Joined Aug 2012
Oct 21, 2012 11:48 |  #12
Looks like it caught focus on the rear driver's side roll cage, which is a bit far from the front passenger fender.
Fray: a usually disorderly or protracted fight, struggle, or dispute
Adjacent: not distant, immediately preceding or following
Canon 7D gripped | Canon EF-S 17-55mm f/2.8 IS USM | Canon 70-200mm f/4 L | Sigma 18-250mm f/3.5-6.3 DC HSM Macro | Canon 50mm f1/8 II
amfoto1
Oct 21, 2012 12:34 |  #13
It is not a focus issue... It's a motion blur issue... probably mostly subject movement, but might also be some camera shake blur happening .
50mm lens... you must have been pretty close. 1/160 was slow enough to produce a lot of subject motion blur. That's fine, if it's what you want. Panning rapidly with a 50mm lens, 1/160 might not be enough to fully deal with camera movement blur either.
Another thing... The shutter moves vertically, two curtains with a space or "slot" between that, along with the actual speed the shutter moves determine the "shutter speed". The higher the speed, the narrower the "slot", as well as the faster the movement of the shutter itself. But this means that different parts of an image are exposed at slightly different times. This was more apparent with older style shutters that moved horizontally. Motion blur would be different when the subject was moving left to right than it was moving right to left. But, even with modern, electronically controlled, vertically travelling shutters (based upon the venerable Copal Square invented in the late 1950s), there's still some effect with really fast moving subjects.
Add to that another variable... yourself. As you pan you probably don't do so exactly the same plane as the subject, nor at the exact same speed or even precisely the same direction. You probably "wobble" a little during the pan. You can minimize, but not eliminate this entirely with a monopod or a tripod (such as with a gimbal head and the panning axis left loose).
Whenever you "drag the shutter" (i.e. use a slow shutter speed deliberately to produce subject motion blur), there are a lot of variables and there are bound to be more shots lost to too much or too little blur. As best you can, experiment with different speeds and apertures and techniques. But differences in subject speeds, focal length (distance from the subject and the subject's distance from the background) are always going to happen. You never really "perfect" panning, per se, though you certainly can get better at it with practice and by refining your techniques. But even then there will always be some chance and luck involved. So take lots and lots of shots and simply plan to throw away more than you usually do, don't expect a high keeper rate.
IMAGE: http://farm4.staticflickr.com/3603/5755946589_fe72928ea0_z.jpg
For the above, the car wasn't going as fast as in your shot (autocross, so probably no more than 40 to 50 mph)... but also I was using a smaller aperture (f16), a slower shutter speed (1/60) and a longer focal length (200mm) so was standing considerably farther away. The lens I used is stabilized, too (IS was left on, but in mode 2 which only corrects for vertical movement).
5DII, 7DII(x2), 7D(x2) & other cameras. 10-22mm, Tokina 12-24/4, 20/2.8, TS 24/3.5L, 24-70/2.8L, 28/1.8, 28-135 IS (x2), TS 45/2.8, 50/1.4, Tamron 60/2.0, 70-200/4L IS, 70-200/2.8 IS, 85/1.8, Tamron 90/2.5 Macro, 100/2.8 USM, 100-400L II, 135/2L, 180/3.5L, 300/4L IS (x2), 300/2.8L IS, 500/4L IS, EF 1.4X II, EF 2X II. Flashes, studio strobes & various access. - FLICKR (external link) - EXPOSUREMANAGER (external link)
Daship
Oct 21, 2012 12:58 |  #14
If it is a nifty 50 it is a slow to focus lens also. I would say lens, and skill is what mucked the shot not the 7D.
apersson850
Oct 21, 2012 16:50 |  #15
amfoto1 wrote in post #15150163 (external link)
...as well as the faster the movement of the shutter itself.
Excellent post, but the shutter blinds move with the same speed at all shutter speeds. Only the time between the first and second blind changes.
Anders
3,229 views & 0 likes for this thread
version 2.0 /
Latest registered member is Cliodiver
605 guests, 294 members online
