Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 29th of December 2005 (Thu)   #1
cbonj
Default Product photography
Any suggestions how to set up lighting for product photography are greatly appriciated.
I plan to buy and set up the lighting equipment, but am not sure what I should get. I thought to get 4 Alzo HMI lights with soft boxes and some large reflectors. The products are reflective (made from aluminum), or painted to simulate metalic look. They are about 40 inches long, 10 inches wide and 5 inches tall and seat on a table. I have a canon rebel XT.
cbonj is offline   Reply With Quote
Old 30th of December 2005 (Fri)   #2
mjordan
mjordan's Avatar
Default Re: Product photography
With medal and glass, you are going to find reflections are a problem, even with softboxes unless you add some additional diffusion material between the lights and your products. This is where a light tent of some kind comes in handy. If you make a frame or use a large white interior or painted cardboard box that you have cut off two sides and the top and drapped white material over it and get your lights close very close, you will reduce some of the reflections.
There are several threads on here that talk about light tents. Do a search for light tent and see what comes up. Or do a google.com search for light tent. It will give you some ideas.
Mike
Hillsboro, OR
Canon 1DMKII and lots of "L"
http://www.sitnprettyphoto.com
mjordan is offline   Reply With Quote
Old 30th of December 2005 (Fri)   #3
tim
Light Bringer
tim's Avatar
The book "Light: science and magic" is great for tricky things like metals, glass, paintings, etc.
tim is offline   Reply With Quote
Old 30th of December 2005 (Fri)   #4
PhotosGuy
Moderator
PhotosGuy's Avatar
Did you look at the "Sticky"s above your post?
www.FrankCizek.com
PhotosGuy is online now   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
My first try at product photography. f50fan Still Life, B/W & Experimental 7 27th of July 2007 (Fri) 00:44
Product photography @TOMMY@ Canon EF and EF-S Lenses 9 26th of October 2006 (Thu) 13:15
Product Photography PhotographerExtraordinair General Photography Talk 11 28th of August 2006 (Mon) 09:39
First go at Product photography philosophizer Still Life, B/W & Experimental 6 7th of June 2006 (Wed) 14:25
