Thread started 27 Oct 2012 (Saturday) 10:10
Prev/next
How many pixels are there in 4 MB?
KeyserSoze1
Oct 27, 2012 10:10 |  #1
I couldn't find a calculator and the few ones I googled were contradictory to each other.
If these are the size of resolution
Focal Plane X-Resolution 2796.43591501028 dpi
Focal Plane Y-Resolution 2839.248434238 dpi
Have I exceeded the 4 MB requirement?
Canon 5DM III, 35 1.4 II 50 1.2L
Canon 6D/// RX1
Colorblinded
Colorblinded's Avatar
Oct 27, 2012 10:24 |  #2
We have no way of knowing from that information. If it were a three color 8 bit per pixel image and it had no compression or header information it could be just under 1.4 million pixels.
The dpi is meaningless without knowing how many inches large the image is (and outside of printing it's a pretty useless number).
That and the number of megabytes an image file takes up depends on more than just pixels. 4MP could be a very low resolution TIF file or a very high resolution JPG that's been heavily compressed. You need to look at the images pixel dimensions to determine pixel count and then at its file size to determine how many MB it requires to store.
http://www.colorblinde​dphoto.comexternal link
http://www.thecolorbli​ndphotographer.comexternal link
tzalman
Fatal attraction.
tzalman's Avatar
Gesher Haziv, Israel
Oct 27, 2012 11:17 |  #3
Dpi is actually ppi which is pixels per inch; so how many inches are we talking about? Where and how did you get those numbers? Citing dpi alone is like saying, "My car went 60 mph so how far did I travel?"
Elie / אלי
KeyserSoze1
Oct 27, 2012 11:19 as a reply to Colorblinded's post |  #4
For example. I uploaded 21 MP from a 5DmII raw file. Does this mean the file has 21 MB file as well?
Canon 6D/// RX1
KeyserSoze1
Oct 27, 2012 11:20 |  #5
tzalman wrote in post #15175431external link
Thanks. Well, I will be sending some online submissions and the rule is each image must not exceed a 4MB weight. How can I tell how many MB does my image have? I use a PSE9 for resizing.
Canon 6D/// RX1
KeyserSoze1
Oct 27, 2012 11:27 as a reply to KeyserSoze1's post |  #6
What information should I post to know how many MB a picture has?
Canon 6D/// RX1
mjkubba
mjkubba's Avatar
Joined Oct 2012
Chicagoland
Oct 27, 2012 11:39 |  #7
What I do is: resize by x% if it's under that xMB requirement then i'm done if it's not i'll resize it again by another x%.
Canon AE-1, Canon 60D, Fujifilm JX400
Canon 35-70mm, Canon 18-55mm IS, Nifty Fifty, Tamron 70-300 VC
http://folding.extreme​overclocking.com ...ge.php?un=mjkubba&t​=37726external link
tzalman
Fatal attraction.
tzalman's Avatar
Oct 27, 2012 12:01 |  #8
KeyserSoze1 wrote in post #15175432external link
No, an uncompressed 8 bit tif from a 5D2 is around 60 MB. I have never output a jpg from my 5D2 (only Raws) but I'd guess that a Fine jpg is around 10 MB and a Medium jpg might be down around 4 MB. But I'm not at home right now to try it.
Elie / אלי
sandpiper
sandpiper's Avatar
Merseyside, England
Oct 27, 2012 12:20 |  #9
Raw files are compressed, so will vary in how many Mb they contain, even at the same pixel dimensions. An image containing a large area of blue sky will use less Mb than an image containing mostly leafy foliage, which contains much more fine detail.
KeyserSoze1 wrote in post #15175461external link
Too many variables to make a simple calculation, regardless of what information you post. But you only need to look at your image, open the image properties and see the size in front of you. If it is too big, simply go back to the original and make a smaller version.
Colorblinded
Oct 27, 2012 14:19 |  #10
Just to point out, DPI and PPI are not the same thing. In this case if we're talking strictly about the digital file the PPI might have relevancy (although usually it's meaningless unless you are scanning something). DPI has to do with printing.
mjkubba
mjkubba's Avatar
Joined Oct 2012
Chicagoland
Oct 27, 2012 14:32 |  #11
Colorblinded wrote in post #15175935external link
just to clarify :
DPI = dots per inch which is used mostly to determine the printer print quality
PPI = pixel per inch which is used to state a screen resolution or a digital file resolution before printing.
http://en.wikipedia.or​g ...PI_in_digital_image​_filesexternal link
Rimmer
Rimmer's Avatar
Joined Nov 2010
Oct 27, 2012 15:33 |  #12
KeyserSoze1 wrote in post #15175437 (external link)
If you don't mind doing a little trial-and-error work, this is pretty easy.
Start by doing a Save As in PSE. That will give you a dialog box where you can adjust the amount of compression (Quality) and the box will tell you how big the image will be. If, at the quality level you want you can't get the file size low enough, then cancel out and back up. (See attached image for example, note that it says 942.7K.)
Then, go into Image > Resize > Image Size... and make the image smaller. How much smaller? I don't know -- make a guess, maybe cut the dimensions in half.
Now, try the Save As procedure again and see what you can get, trading off compression (Quality) with file size.
You'll soon get enough experience to be able to move through this procedure pretty quickly.
But... I assume you are submitting JPGs -- have you checked the size of the files that you already have? They may be OK already, and if not then just a bit of compression may help.
Final note: If you're starting out with a JPG, then when you do the Save As be sure to give the file a new name (maybe add a number or letter) so as not to overwrite your original.
Ace Rimmer -- "What a guy!"
"Smoke me a kipper, I'll be back for breakfast." ;)
tzalman
Fatal attraction.
tzalman's Avatar
Oct 27, 2012 17:32 |  #13
mjkubba wrote in post #15175959external link
just to clarify :
Nevertheless, throughout the industry the term dpi is commonly used even though another term would be more accurate - scanner software UI has scan resolution in dpi although it refers to spi, scans per inch; the EXIF standard uses dpi for both images (pixels per inch) and sensor resolution (sensels or photo sites per inch); monitor and TV resolution in ads or spec lists is given in dpi; and every art director, graphic designer or non-photographer client asks for dpi. They are all wrong, but trying to change them is quixotic tilting at windmills.
Elie / אלי
RDKirk
Adorama says I'm "packed."
RDKirk's Avatar
Joined May 2004
USA
Oct 27, 2012 17:51 as a reply to tzalman's post |  #14
Fortunately, they aren't on this forum, so we can wallow in technical correctness while here and ignore the windmills.
Colorblinded
Oct 27, 2012 19:29 |  #15
RDKirk wrote in post #15176451external link
I do my best to not perpetuate misuse of terms since they do still have functional differences. If and when those differences are no longer relevant then the differentiation in terminology will become meaningless. I'll just roll my eyes every time they're misused until that happens :lol:
Technically correct is the best kind of correct anyway!
16,197 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00286 for 4 database queries.
PAGE COMPLETED IN 0.04s
Latest registered member is ArtieP
961 guests, 502 members online
