Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Compact Digitals by Canon
Reply
Thread Tools Display Modes
Old 19th of June 2003 (Thu)   #1
halund
Default S50 Portrait MOde
I purchased a Canon S50 in order to take portraits with the background blurred. Guess what.. the background only slightly blurred..I called tech support and was told that the camera should be in macro mode.. This is not a good mode to shoot portaits. Any suggestions
halund is offline   Reply With Quote
Old 19th of June 2003 (Thu)   #2
Pewterpez
Default Re: S50 Portrait MOde
in the manual it suggests using telephoto on portraits to increase the blur on the background: 'The background gets increasingly indistinct the more you adjust the focal length toward telephoto"
so try stepping back and bust out the optical zoom...
but I also agree with the canon's support suggestion of using macro, because macro uses a small DOF and thus only the subject is in focus.
Pewterpez is offline   Reply With Quote
Old 19th of June 2003 (Thu)   #3
halund
Thanks for the info. I did use the telephoto since I do not like to get too close to the subject. I took some shots in macro mode and the background was still not blurred. According to the manual, the background is supposed to be blurred in portrait mode or else what is the purpose of this mode? I have a 35mm Canon EOS Elan and it does a great job of blurring the background in portrait mode. That is why I chose the S50 in the first place. I have a Ricoh RDC 7 digital camera which takes great pictures but did not have a portrait mode, that is why I spent the money on the S50 but right now it is not performing any better than my Ricoh
Old 19th of June 2003 (Thu)   #4
Guillermo Freige
Guillermo Freige's Avatar
You never will obtain a very blurred background with digicams (not as blurred of the 35mm one) because you are using a 7-21 lens, and the depth of field (DoF) is proportional to the focal length of the lens, so the DoF of a digicam is much larger than the 35mm one at the same coverture angle. This large DoF also affect the flash shots, and you also can see some "white dots" in the wide angle shots, product of the partially focused dust particles in the air, never present in a 35mm shots, unless you are using a 14mm lens or so.
So, try using the larger aperture (not very large in the S50 at 4.9 in tele mode, the G5 with its 3.0 tele has less DoF), and the subjet as close as possible, and the background in infinite is possible, to maximize the blur effect, when shooting in P or Av mode, or use the portrait mode (it chooses the widest aperture possible), but don't expect too much blur.
Guillermo
EOS 5D MkII, 40D and 20D owner.
EF 17-40L, 24-105L IS , 70-300 IS, 24 f2.8, 35 f2, 50 f2.5 Macro, 85 f1.8.
EF-s 18-55 IS. Sigma 12-24, Tamron 17-50 Di II
Guillermo Freige is offline   Reply With Quote
Old 19th of June 2003 (Thu)   #5
halund
Thanks, I will give it a try....maybe I will have to stick to my 35mm for outdoor portrait shots
Old 23rd of June 2003 (Mon)   #6
Pewterpez
Guillermo --
just a technicality: when you say a larger aperture, is that like f8.0? or f2.8 (which is physically bigger than the f8.0) it depends on relation to the number or the actual size
just curious.
Old 23rd of June 2003 (Mon)   #7
Guillermo Freige
I'm speaking of the "physical" aperture, not it's f number.
So, to me f2.8 is "larger" than f5.6
Guillermo
Old 24th of June 2003 (Tue)   #8
Pewterpez
ahh okay
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Worn mode dial S50 aftli Small Compact Digitals by Canon 4 12th of June 2007 (Tue) 09:47
Flash in portrait mode Borderfox Small Flash and Studio Lighting 1 29th of January 2007 (Mon) 19:54
Why shoot in portrait mode? jon1996 General Photography Talk 19 8th of January 2006 (Sun) 12:35
Powershot S50 Mode Dial Replacement jbakerii Small Compact Digitals by Canon 3 12th of February 2005 (Sat) 14:13
S50 gripe - The mode dial (Auto, P, C, Tv, Av...) Ardiem Small Compact Digitals by Canon 7 3rd of September 2003 (Wed) 14:39
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
