Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > People
Reply
Thread Tools Display Modes
Old 5th of January 2006 (Thu)   #1
hopkins
Default shadows???
how do you get rid of the shadow halo around the subject on vertical shots? i pulled her away from the background but this did not help. also i can't seem to make my pictures small enough to post. i save for web and change the size. what am i doing wrong?
hopkins is offline   Reply With Quote
Old 5th of January 2006 (Thu)   #2
Titus213
Titus213's Avatar
Default Re: shadows???
I normally size the picture to 800 on the long side and then save for the web. When you save for the web you have to reduce the quality of the image until it gets under the 100K max here.
Dave
Perspiring photographer.
Titus213 is offline   Reply With Quote
Old 5th of January 2006 (Thu)   #3
The22oz
I think some people use diffusers to soften the light coming from the flash. I'v seen some examples of this in place and seems to work real well. I'm not sure if thats helpfull or not, but I hope it was.
The22oz is offline   Reply With Quote
Old 5th of January 2006 (Thu)   #4
hopkins
thanks for walking me through uploading my picture- it finally worked. here is an example of the shadow i'm having trouble with.
Old 5th of January 2006 (Thu)   #5
ootsk
you can try to lessen the shadow by balancing the flash with the ambient light. This would help some, but to get rid of the halo completely you probably need a flash bracket that keeps the flash directly above the lens, even in portrait mode. Or two off-camera flashes.
ootsk is offline   Reply With Quote
Old 5th of January 2006 (Thu)   #6
Kevin
Moderator
Kevin's Avatar
Location: Hotel California, Second Floor, Third Door On The Right, next to the big rock
If you are using the on-board flash, or an external flash but straight on the you will need to move your subject away from the BG at least the distance the subject is tall. That means that if your subject is 5 ft tall then you will need to be a minimum of 5 ft. from any reflective BG. As long as the shadow can hit the floor or out of the frame before it reflects then you are far enough away.
Kevin is offline   Reply With Quote
Old 5th of January 2006 (Thu)   #7
Titus213
Titus213's Avatar
What camera are you using? And what flash? If the flash is the built-in unit then you have a whole different set of problems as opposed to the hot-shoe mounted flash units. But the basic problem you are experiencing is too harsh a light directly at the subject. I use either a Lightsphere II or a Lumiquest ProMax bounce unit with my 550EX flash.
Cute baby!
Dave
Old 5th of January 2006 (Thu)   #8
hopkins
I am using the built in flash to my digital rebel. I just bought excaliber 3200. Is it possible to get rid of the shadow using what I have?
Old 6th of January 2006 (Fri)   #9
JohnnyG
Worthless twinkle toes fairy
JohnnyG's Avatar
Well, while you experts make excellent suggestions on the shadow, I have to say I love the shot of the baby!!!
Canon EOS 5D Mark II, 100-400IS L, 24-105 L[color=black][font=&quot] IS, 50mm f/1.4, Canon 430EX/580EX II, Kenko 1.5X, Epson R1900, Manfrotto 679B Monopod, 3021BPRO tripod, 808RC4 Head, 486RC2 Ballhead
JohnnyG is offline   Reply With Quote
Old 6th of January 2006 (Fri)   #10
goatee
"nice but dim"
goatee's Avatar
That's a lovely shot!
The reason that you get hard shadows with flash, is if the light is all concentrated pointing in the same direction, and there is a big difference in the brightness of the illuminated area, and the ambient light levels.
There are two main techniques for diffusing the light - the first is to use something in front of the flash to spread the light source. For the built in flash, there is only one option - that's the 9.99 Lumiquest soft screen. I haven't used one, so don't know how effective it is, but it should definitely show an improvement.
The second technique which isn't possible with the built in flash, is to bounce the light - most commonly off a ceiling, so the whole of the ceiling becomes the light source - you'll often see photographers with a flash pointing up, with a white index card attached - this bounces some of the light forward, whilst most of the light comes from above.
The last technique you could use, is to raise all the ambient light levels - e.g. taking shots in bright daylight - though you can still have the problem of shadows in daylight!
Hope that gives you some insight into things you can do to alleviate shadows - basically, with the built in flash, a diffuser (lumiquest soft screen), and raising ambient light levels are your main options.
D300, 50mm f/1.8, 18-70mm f/3.5-4.5, 70-300mm f/3.5-5.6 VR, SB800
flickr
goatee is offline   Reply With Quote
Old 6th of January 2006 (Fri)   #11
OL9245
OL9245's Avatar
Lumiquest sells a diffusor specially desinged for built-in flashes. Never used it. Certainly dos some job at least on the lightings. Perhaps not enough for the shadows.
Hope this helps,
Cheers, Olivier
Gear list. Photoshop tips and tricks I've learned here at POTN.
English is not my native language. Once and then, I can make funny sentences
learn more about my avatar
OL9245 is offline   Reply With Quote
Old 6th of January 2006 (Fri)   #12
kawter2
kawter2's Avatar
I'm lost.. it seems that your logic would be correct if you were shuuting the subject at a 45 degree angle. but i dont see how having someone 6ft away from a wall will get rid of shadow cast
Wedding Blog
Eric J. Weddings
kawter2 is offline   Reply With Quote
Old 6th of January 2006 (Fri)   #13
hopkins
thanks for all the imput. I will play around with it some more. Is there anything I can do to help the shadows using the excalibur and my internal flash?
Old 6th of January 2006 (Fri)   #14
Titus213
Titus213's Avatar
I'm not familiar with the Excalibur 3200 system but it would appear that you can definitely mitigate the shadows with it. You will need to figure out how to trip the unit with your camera. I would suggest a Wein Safe-sync as a good $50 investment that will protect your camera and give you a PC attachment capability for the Digital Rebel. You will NOT be able to successfully trip the Excalibur with the on-board flash IMO. Hopefully you have an umbrella, diffuser, stands, etc with the Excalibur system. That will let you move and modify the light to accomplish what I think you want.
Dave
Old 6th of January 2006 (Fri)   #15
hopkins
yes i do have an umbrella and stand but not a sync cord yet- that's my next investment. my camera flash does trigger the slave on the excalibur though.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Shadows alexknudsen Still Life, B/W & Experimental 3 8th of July 2007 (Sun) 19:20
shadows Photolistic Small Flash and Studio Lighting 1 25th of November 2006 (Sat) 09:53
In shadows freddycr People 9 17th of February 2006 (Fri) 06:41
Shadows yb98 Critique Corner 2 5th of July 2004 (Mon) 16:04
