#1 |
My LCD turns black for a second or so after I take a snap. Everything else works fine. Does anybody know the reason or have the same experience? Many thanks.
| sponsored links |
#2 |
Probably you have the LCD in the OFF setting. In this setting, it only display the review image after the picture is taken (usually 2 seconds) and then turn off, to save power, and you must use the viewfinder to frame the picture.
If you want to change the state to "always on" press the "Display" button to switch. If this doesn't work, probably you have a malfunction.
Guillermo EOS 5D MkII, 40D and 20D owner. EF 17-40L, 24-105L IS , 70-300 IS, 24 f2.8, 35 f2, 50 f2.5 Macro, 85 f1.8. EF-s 18-55 IS. Sigma 12-24, Tamron 17-50 Di II |
| Thread Tools | |
| Display Modes | |
| s230 lcd black when taking pictures | gepapaya | Small Compact Digitals by Canon | 2 | 28th of October 2005 (Fri) 14:24 |
| occasional black LCD/pictures with S230 | zkosty | Small Compact Digitals by Canon | 3 | 9th of December 2003 (Tue) 09:31 |
| G2 LCD Panel Turns Itself Off in 180 Position | LJBest | Canon G-series Digital Cameras | 6 | 2nd of July 2003 (Wed) 14:46 |
| black turns brown | Bezoarziege | Canon EOS Digital Cameras | 0 | 22nd of April 2003 (Tue) 09:41 |
| Picture turns out darker than it is on LCD | n9505605 | Canon G-series Digital Cameras | 7 | 9th of September 2001 (Sun) 07:13 |
