Thread started 04 Jan 2013 (Friday) 15:27
EOS Utility problems.
twinkle_2k86
Jan 04, 2013 15:27 |  #1
I having problems with EOS utility. I have the discs, but my CD drive dont work :(.
I have managed to download a copy of DDP version 1, and then updated from the canon site to the latest version (3.12.52.0) This all opens fine etc.
Trouble is i downloaded the latest version EOS utility from canon, and try and run it, but it wont run. I get a message to say,
Software cant find, EOS utlility, EOS viewer utility, File viewer utility and camera window DSLR. please in insert CD.
I have windows 7, and its a canon 40d im trying to connect up.
Any help please, as im now lost.
cheers :)
Jon Harris Photography.
Canon 40D ,Gripped x 2, 50mm 1.8 II, 28-70 II f3.5-4.5, Tamron 70-300 vc, Tamron 90mm macro
Sigma 150-600 OS Comp.
jacuff
Jan 04, 2013 15:29 |  #2
Get on another computer. Burn the CD to an ISO. Install a Virtual CD program like Daemon Tools (watch out for the loaded bloatware) and mount the ISO. So glad Windows 8 made ISO mounting native to the OS.
Gear, Feedback (eBay (external link)), Web (external link), Blog (external link), FB (external link), Twitter (external link)
TSchrief
Joined Aug 2012
Jan 04, 2013 17:18 |  #3
It would be easier to take the CD to a friends house and copy the CD to a blank, formatted, sufficiently large USB thumb drive. I do that all the time. My old laptop doesn't even have a CD drive. Its never been a problem.
twinkle_2k86
Jan 05, 2013 04:52 |  #4
TSchrief wrote in post #15445398 (external link)
Cheers, will give this a go first.
Lowner
"I'm the original idiot"
Jan 05, 2013 05:18 as a reply to  @ twinkle_2k86's post |  #5
Why not get the CD drive fixed?
Richard
jr#8
Jan 05, 2013 06:29 |  #6
Why doesnt canon have these files on there website. I Just installed a new HD in my Laptop and cant get the original software for a 20D. They have all the updates on the site
Astrophotography,Fishi​ng
Canon 20D,Canon 100mm-400mm "L" IS USM,50mm 1.4 USM, Tamron AF28-80mm Asph, Canon 50mm FD Backwards Macro
Canon Speedlite 430 EX ,Bogen Monopod
Stroboframe
twinkle_2k86
Jan 05, 2013 17:06 |  #7
Lowner wrote in post #15447193 (external link)
Have tried, its when I upgraded to windows 7, for some reason the cd drive won't work. When pluged in, the laptop stalls on start up everytime. If not pluged in it boots up perfect.
John ­ from ­ PA
Joined May 2003
Jan 05, 2013 22:25 |  #8
Start with PC off then remove the drive and boot the PC. Go into device manager, or whatever it may be called in Win7 and expand the tree to look at the hardware. Delete any reference to the drive. Once done plug the drive back in and you should get a message about "new hardware." Let Win7 try to find the driver for it but if it can't then point it to the drive manufacturers site.
MikeWa
Gallery: 89 photos
Joined Apr 2012
Jan 06, 2013 13:24 as a reply to  @ John from PA's post |  #9
Go here. http://usa.canon.com …eos_7d#DriversA​ndSoftware (external link)
Select 'drivers and software' enter your computer system and download the program to your computer. No disc needed.
Mike
Mike...G9; 7D; 7D Mark II; EF-S 10-22mm; EF-S 18-135mm IS STM; EF 28-300mm F3.5-5.6L; EF 70-300mm IS USM; EF 70-200mm F2.8L IS-II; EF 100-400mm f4.5-5.6L IS; EXT 1.4-II & 2.0-III; The more I learn the less I know.
John ­ from ­ PA
Joined May 2003
Jan 06, 2013 18:28 |  #10
Mike's, op has problems with a CD drive that doesn't' work. Canon is not likely to help with a drive (hardware) issue.
MikeWa
Gallery: 89 photos
Joined Apr 2012
Jan 06, 2013 19:04 |  #11
John from PA wrote in post #15453638 (external link)
I thought the OP said he was having a problem with the EOS utility. That he was unable to get it properly loaded into his computer due to a non operating CD drive. My post was on how to get the EOS utility. The drive is a another issue.
Mike
rrblint
Gallery: 38 photos
Joined May 2012
Jan 06, 2013 19:23 |  #12
MikeWa wrote in post #15452406 (external link)
Mike
The basic program for EOS Utilities is NOT available here, only the updates.
You cannot update(without using file management trickery) without having the basic program insalled.
Mark
jr#8
Jan 06, 2013 19:44 |  #13
twinkle_2k86 wrote in post #15449237 (external link)
How old is the PC? Did it come with Vista on it?
If you install Virtual Machine you might be able to put the CD back on. Sound something like the problem I had when installing a new HD It could'nt use the CD
Stroboframe
twinkle_2k86
Jan 08, 2013 05:29 |  #14
jr#8 wrote in post #15453964 (external link)
Yer, it was a Vista machine. Its a HP laptop. Had it upgraded to windows 7, but lost my CD drive and built in Webcam. I have searched google to try and find a fix for both, but it seems it was quite common when upgrading.
May just buy an external CD drive at some point.
mikeinctown
Joined May 2012
Jan 08, 2013 08:11 |  #15
Sounds like you need to make a trip to eBay for a cheap used drive. If that doesn't work then you most likely have a bad MoBo or will need to wipe the system and start with a clean install. itherw ay, if this is your primary computer i would fix the problem before you screw yourself over.
Canon EOS 1D X | Canon EF 24-105mm f/4L IS USM EF 70-200mm f/2.8L IS II USM | Sigma 150-600mm F5-6.3 DG OS HSM | Contemporary
3,059 views & 0 likes for this thread
Latest registered member is thisisntme
746 guests, 394 members online
