Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > RAW, Post Processing and Printing
Reply
Thread Tools Display Modes
Old 16th of November 2001 (Fri)   #1
bussty
Default At last an amazing slide show program!!!
My long search is finally over. For years I have been searching for a slide show program that will let you do the following:-
1. Have high quality fades and dissolves plus other transition effects
2. Be able to sync precisely to a soundtrack so you change slides at important points in the soundtrack. This synchronization not changing when run on different machines.
3. Be able to generate single exe slide shows or screensavers
4. Be able to add high quality text and animations
Well I have found software that will do all the above plus:-
5. Allow you to include perfect scrolling panoramas in your show.
6. Have as many images on the screen at one time as you want.
7. Output to a video file if you wish
The software is Called GlobFX Presenter and is available from http://www.globfx.com
The program is pretty much like Adobe Premier but based on single images as opposed to video so is much easier to work with. And the interface is clear and simple. BUT just be patient with it, when I first downloaded it I thought the quality of the show was awful but a quick email to GlobFX pointed out that I might have out of date graphics drivers. A quick download off the net and I was away and have never looked back. You do need one of the later accelerated graphics cards mine is about three years old and it works fine.
I do not work or get paid by these people but am just so elated at this product. If you are into computer slide shows you must check this out. I used to have my heart set on Pictures2exe but GlobFX is better.
Regards
Andrew Busst
Queenstown, New Zealand
bussty is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
slide show help charyl2215 Weddings and Other Family Events 2 19th of May 2007 (Sat) 16:46
Slide Show totalbeginner Wildlife 1 11th of February 2007 (Sun) 09:42
Slide Show woffles People 5 6th of December 2006 (Wed) 14:06
How to display photos on Web site (slide show program) ShutteringFocus The POTN Lounge 2 7th of January 2005 (Fri) 07:58
Best program to create the highest quality slide show on DVD RAV RAW, Post Processing and Printing 5 27th of February 2004 (Fri) 04:05
