#1 |
I'm interested in taking photos of local bands at venues with low light. I'm looking seriously at the 50mm 1.4 (and no, I'm not asking to debate the ins and outs of this lense). What I want to know is if this is the best route to go or is there a better lense for around the same price?
Canon 40D, Canon 70-200mm 2.8 L, Canon 50mm 1.4, Sigma 20mm 1.8 Lensbaby 3, Alien Bees strobes and accessories. http://www.pbase.com/phishhead_23 |
| sponsored links |
#2 |
User is banned from forums
It has nothing to do with the 50mm being a good lens or not, it is a great lens, but, what focal lenght(s) you need. The 85mm f/1.8 is close in price and also a very nice lens. We have no idea what camera you are using or where you are going to be shooting from in relation to the stage or what kind of shots you will be most interested in. let us know and I'm sure more suggestions will follow.
#3 |
Any fast prime would do the trick, but as jjonsalt said the correct lens will depend entirely on your distance from the stage. I shot a concert from the end of the stage with a 100mm f/2.0 and had pretty good luck with that one until the performers came down to my end. Then the 100mm focal length was a bit too long. The 85mm would have been better in that scenario.
| sponsored links |
#4 |
It really does depend on where you are in relation to the stage... fast zooms could be an option. Lenses like Canon's EF 24-70 f/2.8L and EF 70-200 f2.8L IS would probably serve you well. You could also go the Sigma route with the same zooms. If you're into primes, EF 50 f1.4, EF 85 f1.8 might serve you well, again depending on where you are. I haven't shot a concert yet, so my opinion is based on a whole lot of reading, and this forum. I hope this helps...
1D MKI + 1Ds MKI + 5D MKI Kit - EF17-35 f2.8L | EF24-70 f2.8 L | EF 100-400L IS | EF15 f2.8 | EF35L | EF50 f1.4 | EF85 f1.8 | EF135L | 580EX II | 580EX I | 270EX II | G12 My Zenfolio | PDX/Vancouver Photography Meetup Group |
#5 |
Light Bringer
NZIPP Qualified Professional wedding photographer.
Camera and Lens Reviews ~ Wellington Wedding Photographer Wellington Wedding Photographer (site2) ~ Wellington Wedding Photographer (site3) Read all my FAQs (wedding, printing, lighting, books, etc) |
#6 |
In my limited experience f/2.8 zooms are often not fast enough (with dark venues and moving performers). Thus a few fast primes would be my suggestion. I use 28/1.8, 50/1.4 and 85/1.8. Of them, the 50/1.4 would probably be the best starting point.
To illustrate the need for fastness, the following example I shot yesterday with 85/1.8 wide open at ISO 3200 and yet had to add another stop and a half in ACR: ![]()
Canon 35/1.4 | Canon 50/1.4 | Canon 135/2 | Canon 17-40/4 | Canon 24-105/4 | Canon 70-300/4.5-5.6 Canon 5D | Canon Speedlite 430EX | Manfrotto 055 ProB + 488RC2 | Kenko ext tubes & 1.4x TC |
#7 |
I'm using a Canon Rebel XT. Most of my photography will be very close to the stage (local bands in small venues). I want to make sure the 50mm 1.4 will give me enough light to work in dark, close conditions.
Also, do you normally use a tripod in these conditions or can you hand hold?
#8 |
I've only used a tripod for concert work once. It just doesn't work when you have performers moving around (like most do). Also unless you have an excellent location to place your tripod it will very quickly become a hazard that will likely get you in trouble with venue/security.
With the 350D I'd recommend f/1.8 or better because you don't have the luxury of going to ISO 3200 (as with the 20D) when the light is really bad. I would recommend a 50mm as a really good and inexpensive start. Also, there has been heaps of valuable discussion on lenses and techniques for concert photography - try the search function and you'll find a gold mine of useful info. Last edited by RockSlut : 8th of January 2006 (Sun) at 20:22. |
#9 |
Mr T. from the A team
The Canon 50mm f1.4 is a great lens for shooting gigs, although if you are really close to the stage it can be a bit close (given the 1.6 magnification on my 20D) I have just brought a Sigma 30mm f1.4 which is really nice for up close to the stage.
#10 | |
So if you're convinced by the IQ of the 50mm f/1.4, (and you should), just go for it! And post your results!...
François --- 40D + grip, 70-200 f/2.8L IS, 24-70 f/2.8L, 17-40 f/4L, 50 f/1.4, 580 EX II www.casualvision.com |
#11 |
It's easy to think that an f1.4 lens could shoot in complete darkness!
It certainly helps, but don't raise your expectations too high. With the light sucking ability, comes the shallow depth of field. Raising the ISO on a capable camera will sometimes be a better option (if it's not to the max already). Graham
. Lamb dressed as mutton. |
#12 |
Moderator
If the venue is real small, the 50 might be too long (specially on a 1.6 crop body)
I suggest you also give the 28/1.8 or sigma's 30/1.4 a thought. I use primes from 20 to 100mm for my work. On the 1D2 I don't use the 20mm as much as I used to on my 10D, but occasionally it still comes in handy. |
#13 | |
Dignity-Esteem-Compassion
Doc Klepper in the USA I am a photorealist, I like my photos with a touch of what was actually there. Polite C&C always welcome, Thanks. Gear List |
#14 |
Of course my experience was in gymnasiums and not at concerts, but low light issues I think are the same.
#15 |
Trying to take pictures at a concert in this town will get you tossed out on your butt! Taking cameras into the venue is taboo (unless you can prove you are from the press). Some kids try to sneak in with tiny Point and Shoots but the flashes going off alerts the security guys who swarm in like bees to honey.
Chris. Spratt Victoria, BC In the game of life, Mother Nature bats last. Happy ninth inning. |
| Thread Tools | |
| Display Modes | |
| Even better than an L-lense for concert photography! | dzstudios | Performing Arts | 16 | 21st of June 2007 (Thu) 00:59 |
| Low light concert :-) | RiverCottage | Performing Arts Talk | 15 | 5th of September 2006 (Tue) 07:47 |
| Best setting for low light concert photography with Pro1 | monkey_wrench | Canon G-series Digital Cameras | 5 | 30th of January 2006 (Mon) 15:53 |
| low light candid and concert lens | jesshen | Performing Arts Talk | 10 | 8th of October 2005 (Sat) 03:06 |
| Low-light photography at a concert: G5 user needs help | photowoman | Canon G-series Digital Cameras | 9 | 5th of February 2004 (Thu) 16:28 |
