Thread started 08 Jan 2006 (Sunday) 16:42
What does 100% crop mean?
MALI
Jan 08, 2006 16:42 |  #1
I know what cropping is but I cannot quite get what a 100% crop means. I probably have done it several times but.... Anyone?
MALI
Canon 20D, 10-22, 24-70L,70-200L f/2.8 IS, 580 EX, RS-80N3, EP-EX15, BG-E2, E1.
RodBarker
Jan 08, 2006 16:50 |  #2
Its like you have a massive high res image and in PS use your rectangle tool to select a small portion , then copy paste that portion into a new document , and print or add to a website , it maybe be only an eye or such out of the high res but will end up 800x600 or something on a monitor , that piece you cropped out would be at 100% res or 100% crop .
Rod
rfreschner
ishka bibble
Joined Jan 2005
Location: Andover, CT...................... Go Red Sox!
Jan 08, 2006 17:45 |  #3
In the image editing software of your choice view your image at 100% - in PS either select View/Actual Pixels or double-click on the Zoom Tool. Then crop out a section of the image and "Save As" to another file.
Rick
"We both can't be wrong; I must be right"
Bob Welch
MALI
Jan 08, 2006 18:02 as a reply to  @ RodBarker's post |  #4
Rod
The size of that crop does not matter? Like, is there a 85% crop as opposed to 100% crop? Why 100%? Or in other words, what makes it 100% crop? Or still in other words, why do we call it 100% crop rather than just crop?
MALI
Buddy ­ Thomason
Joined Oct 2004
Jan 08, 2006 18:31 as a reply to  @ MALI's post |  #5
Because you view it, and crop it, at 100% magnification. The term 100% crop is short for a cropped portion of an image viewed at 100% of its actual size.
Knives Galore ... http://LooksXpensive.f​ototime.com (external link)
MALI
Jan 08, 2006 18:36 as a reply to  @ Buddy Thomason's post |  #6
So let me see if I get it right?
You are looking at a picture in Photoshop in Actual Size, which makes it 100%, and then you crop a part of it. This is called 100% crop, correct?
If on the other hand, you are looking at the same picture in Fit on Screen mode, and cropping a part of it, that is not 100% crop.
Did I get it right?
MALI
rfreschner
ishka bibble
Joined Jan 2005
Jan 08, 2006 18:54 as a reply to  @ MALI's post |  #7
MALI wrote:
Did I get it right?
Yes.
Rick
Bob Welch
MALI
Jan 08, 2006 18:59 as a reply to  @ rfreschner's post |  #8
rfreschner wrote:
Yes.
Phew, I got that one out of the way. :) Thanks, people.
Now I can stop wondering what the heck it is while people are talking about it. Let's move on...
MALI
SkipD
Joined Dec 2002
Jan 08, 2006 19:20 as a reply to  @ MALI's post |  #9
MALI wrote:
Did I get it right?
Not exactly.... It doesn't matter what size you have on your screen when you do the cropping. It could be the whole image. The key thing is that you do not change the resolution of the resulting crop by re-sizing prior to saving as a separate file. The resulting new file will have precisely the same pixels making up what's left of the image as that portion of the original image.
The whole purpose is so that folks on the forum (or whoever is viewing the crop) can see all of the detail in the original image without having to post the whole image (which can be huge and take a long time for folks to download).
Skip Douglas
Zepher
Joined Nov 2005
Jan 08, 2006 19:44 |  #10
I think it's also good when doing a test print of a large image, you just do a 100% crop of an area and then print that to see if it is going to look good.
Manny Desantos
Intel C2Q Q6600 3.06Ghz, 8GB Ram, 8.1TB, XFX HD5850, Windows 7 Ultimate 64bit, PS CS4 EXT (external link)
Canon 40D, EF 28-70L, 2x Canon XH-A1 HDV, Canon HV30 HDV
❶_______________
rfreschner
ishka bibble
Joined Jan 2005
Jan 08, 2006 20:15 as a reply to  @ Zepher's post |  #11
A much better, more detailed explanation Skip. I certainly left off the part about not resizing the image as I thought it was implied, but one should never assume that it will be apparent.
Rick
Bob Welch
jj1987
Jan 09, 2006 00:23 |  #12
basically, 100% crop would be (on your monitor) 72dpi at however big the image is.
a 100% crop of an image on print would be somewhat like a test strip you get from professional labs before printing large images.
jfrancho
Jan 09, 2006 07:31 as a reply to  @ jj1987's post |  #13
what would dpi have to do with it?
Robert_Lay
Jan 09, 2006 09:10 |  #14
I see a lot of confusion here about something that is very simple.
If the image is not resampled, then that image or any portion of that image is a 100% crop. So the important aspect of it is that during whatver operation you do to that image it must not be resampled.
All of that other stuff, such as magnification and re-sizing and what the dpi setting is, etc., is all irrelevant.
Did I get it right?
Bob
Quality of Light (external link), Photo Tool ver 2.0 (external link)
Canon Rebel XTi; EF-S 10-22mm f/3.5-f/5.6 USM; EF-S 18-55 mm f/3.5-f/5.6; EF 28-135mm f/3.5-5.6 IS USM; EF 50mm f/1.4 USM; Canon Powershot G5; Canon AE1(2); Leica R4s; Battery Grip BG-E3; Pentax Digital Spotmeter with Zone VI Mod & Calibration.
jfrancho
Jan 09, 2006 09:14 |  #15
Exactamundo, Bob!
10,577 views & 0 likes for this thread
Latest registered member is abrahamf
995 guests, 428 members online
