Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EOS Digital Cameras
Reply
Thread Tools Display Modes
Old 25th of June 2003 (Wed)   #1
Highland
Default Highest image quality/ Multiple image printing
I am looking for insight on how to handle images out of the camera for the best quality prints. RAW images appear to produce better quality prints than JPEG’s. Yet RAW images cannot be printed directly they must be saved as TIFF’s. Can anyone out there share a practical way of capturing, reviewing, and printing these best quality images that doesn’t take forever. (If this solution utilized the provided software that obviously would be even better.)
Also is there a way in Photoshop Elements 2.0 to print out multiple images on a single sheet of paper (from different files)?
Thanks,
Don
Highland is offline   Reply With Quote
Old 25th of June 2003 (Wed)   #2
justme_dc
Default Re: Highest image quality/ Multiple image printing
Highland wrote:Also is there a way in Photoshop Elements 2.0 to print out multiple images on a single sheet of paper (from different files)?
In the file menu under print layouts you can use either the contact sheet or picture package. Otherwise you can just use layers...
justme_dc is offline   Reply With Quote
Old 25th of June 2003 (Wed)   #3
Highland
Default Re: Re: Highest image quality/ Multiple image printing
I've tried this but it seems only to work with one picture. e.g. -> 2 5X7 but of the same image only, not of different images.
Old 26th of June 2003 (Thu)   #4
khenn
Default Re: Re: Re: Highest image quality/ Multiple image printing
I use PS7, but I'm guessing Elements is the same. When you go to picture package, and select the size of pictures you want, you can click one of the preview images on the right and it will pop up a "Select an Image File" window where you can choose a different image.
So, in your example you would choose (2) 5x7
for your layout, and then it will display a sample with 2 5x7's on it. Click on the bottom one and choose a different image. Hope this helps.
Personally, I don't like using this method, because if you choose for example (4) 4x5's and then choose four different images, the next time you come into the picture package creator, PS will reload the last package you were on, so the more different images you have, the sloooooooooooower it loads. I now prefer to create my own actions that will generate what I need. It may take a little bit to get it set up, but it's worth it in the end.
khenn is offline   Reply With Quote
Old 26th of June 2003 (Thu)   #5
Highland
Thanks for the feedback - I will try what you have suggested.
Do you find PS gives you best shot at highest resolution printed pix?
Don
Old 26th of June 2003 (Thu)   #6
khenn
The higher the better. Plus, if you have high resolution, you can crop the image and still get good prints. The higher the resolution, the more data you have to work with.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Sharpening for multiple image sizes? StewartR RAW, Post Processing and Printing 14 20th of September 2006 (Wed) 07:39
multiple image bndaidbob People 15 23rd of May 2006 (Tue) 18:58
How to get the highest quality, resized image? Crypto RAW, Post Processing and Printing 1 25th of October 2005 (Tue) 23:31
75-300mm IS USM poor image quality? (LARGE IMAGE!!) CanonLaw Canon EF and EF-S Lenses 16 11th of October 2005 (Tue) 21:36
Zoombrowser: Multiple image editing S/W choice peterf RAW, Post Processing and Printing 0 11th of November 2001 (Sun) 13:01
