Thread started 22 Mar 2013 (Friday) 09:02
Video recording 'time' on 6d
anomie
Joined Apr 2003
Mar 22, 2013 09:02 |  #1
I have read that the 6d has a max recording time of 29 minutes but I'm confused about what exactly this means. If I have a 16gig SD card and I mount the camera on a tripod to shoot a 1 hour video event, will it create 2 clips, each 29 minutes or will it stop recording after 29 minutes and then I must be prompted to hit record again? I'd appreciate some clarification on this from other 6d owners who have used the video feature. Thank you!
Canon EOS 6D, 70D
Zooms: EF-S 10-22 f/3.5-4.5, EF-S 17-55 f/2.8, EF 24-105 f/4.0 L & EF 70-200 f/4 IS L
Primes: EF 50 f/1.4, EF 85 f/1.8, EF 100 f/2.8 macro, EF 135 f/2.0 L
Other: Flashpoint Zoom Li-on R2 TTL, Canon 430EX, Canon 30D
RHChan84
Joined Apr 2011
Mar 22, 2013 09:14 |  #2
Like all others Canon DSLR, it would record 29 minutes then stop. You would have to hot the record button again to start up recording.
Canon (60D Gripped | 18-135mm f3.5-5.6 IS | 40mm f2.8 | 50mm f1.8 | 70-200 F4L IS| 430 EXII)
Tamron (17-50 f2.8 VC)
Feedback
Facebook (external link)
rrblint
Gallery: 38 photos
Joined May 2012
Mar 22, 2013 10:51 as a reply to  @ RHChan84's post |  #3
It actually will stop about every 11 minutes(at 1080X1920 capture) when the file size reaches 4GB and must be restarted each time. Also if you restart too many times it will overheat and stop even sooner...Very annoying.
Mark
John ­ from ­ PA
Joined May 2003
Mar 22, 2013 16:21 |  #4
Go to http://photography-on-the.net …t=1284446&highl​ight=video and scroll down to my input, entry #9 by John from PA. It is applicable to your camera as well.
manfesto
Mar 22, 2013 19:01 |  #5
rrblint wrote in post #15743184 (external link)
Actually, from what I've read, the newer Canon HDSLRs, including the 6D, will automatically split the video clip into 4GB chunks to give you 29 minutes of continuous recording time split across multiple 4GB files.
After 29 minutes you'd need to hit record again, however. You'll find this is a common limitation of HDSLRs among almost all manufacturers. As I understand it, it's because the EU charges higher tariffs on "video" cameras, and they define a video camera as anything that can record more than 30 minutes continuously - manufacturers get around this with a 29 minute limit on a single clip.
anomie
Joined Apr 2003
Mar 23, 2013 06:17 as a reply to  @ manfesto's post |  #6
Thanks for the straight forward input all. Makes sense now. I could never find a clear answer. I understand the 29 minute limitation and it makes sense, I had just hoped that for the rare moment that I had to shoot video for over an hour (say on a tripod) that it would continue and split the clips. Actually, I occasionally borrow a Canon camcorder from work and it splits the clips into multiple clips but continuously records until you either run out of battery or space.
Canon EOS 6D, 70D
John ­ from ­ PA
Joined May 2003
Mar 23, 2013 08:45 |  #7
One possibility to extend beyond the 29 minute limit would be Magic Lantern software but I don't if it is yet available for the 6D.
Submariner
Joined May 2012
Mar 23, 2013 09:33 |  #8
I also thought it was a precaution against overheating.
Don't use it much on my 7D so can not confirm either way.
Canon EOS 5DS R, Canon EF 70-200 F2.8 L Mk II IS USM, Canon EF 70-300 F4-5.6 L IS USM, EF 40mm F2.8 STM , RC6 Remote. Canon STE-3 Radio Flash Controller, Canon 600 EX RT x4 , YN 560 MkII x2 ; Bowens GM500PRO x4 , Bowens Remote Control. Bowens Pulsar TX, RX Radio Transmitter and Reciever Cards. Bowens Constant 530 Streamlights 600w x 4 Sold EOS 5D Mk III, 7D, EF 50mm F1.8, 430 EX Mk II, Bowens GM500Rs x4
rrblint
Gallery: 38 photos
Joined May 2012
Mar 23, 2013 11:27 |  #9
manfesto wrote in post #15744828 (external link)
Didn't know that the 6D would continue to record multiple 4GB files...That's certainly an improvement, thanks for the heads-up.:)
Now if ML can extend the time we'll be good to go, except for the overheating issue.
Mark
John ­ from ­ PA
Joined May 2003
Mar 23, 2013 12:17 |  #10
Originally posted by manfestoAfter 29 minutes you'd need to hit record again, however.
You might not want to do that. As I stated in the previous thread the shutdown due to temperature can be a real drawback. At horse show last summer I was recording almost continuously and my 60D stopped based on sensor temperature. I had to wait several minutes before I could restart, missing several horses in the competition. In addition the repetitive clips were relatively short, and I kept coming up against the temperature limitation. I was able much later to again record a full 29 minute clip later on the same card.
manfesto
Mar 23, 2013 21:41 |  #11
John from PA wrote in post #15746877 (external link)
The likelihood of your camera overheating is dependent on ambient temperature and camera body.
I can definitely see if you were shooting horses outdoors in the high sun that your 60D would overheat eventually.
However, to offer a counter anecdote, with my 60D, I've shot race finishes at dusk and narrative material in air-conditioned spaces and garages for extended amounts of time, and I've never had my 60D overheat.
Also, here is an endurance test of a guy shooting over 8 hours on his 60D without overheating - http://vimeo.com/16574​594 (external link)
/*It's worth noting that the 60D has a reputation of being better about overheating than its generational compatriots the 5D2 and 7D, but I don't know how the 5D3 or 6D compare when it comes to overheating.*/
So depending on what the OP shoots, he or she may not have the same issues with overheating that you have had.
hennyphoto
Joined Mar 2015
May 01, 2015 13:30 |  #12
Perfect thread. Just what I was looking for.
Copper ­ NYC
Joined Sep 2011
May 02, 2015 20:28 |  #13
You hit right on the head with the tariff, if I'm not mistaken the limit is 29mins 59 seconds on dslrs.
40D Gripped, 50D, T2I Gripped, 5D Mark III Gripped, EF-S 18-55 IS, EF-S 55-250 IS
EF 28 f/2.8 IS, EF 40 2.8 STM, EF 50 f/1.4 USM,
EF 85 f/1.8 USM, EF 100 f/2.8 Macro USM, EF 24-105L f/4.0
EF 28-80 USM, the good one with metal mount and ring USM.
EF 28-80 USM V, EF 28-135 USM IS, EF 100-300 USM, EF 100-400L USM IS.
Rokinon 14 f/2.8
Carpe ­ Lux
Aug 20, 2015 18:39 as a reply to  @ Copper NYC's post |  #14
Ouch, just got burned doing video of a wedding.....I knew my 6D would record in 4GB blocks but forgot that is STOPPED at 29:59.....I got one 18:08 minute block & one 11:51 minute block before it turned off.
The tripod mounted 6D was positioned high up on the church balcony, next to the organist, to provide B-roll footage of the entrance & exit of the wedding party. It ran unattended, picked up the wedding party entrance just fine, missed the exit 45 minutes later, long after the maximum recording time. (I was on the main floor near the front). Now if I'd just asked the organist to reach over and........
Lucky for me I had two other cameras running, a GoPro for entire ceremony & a G7X for closeups sequences. This video was not paid work, it was "extra" for my relatives since they only hired a still photographer & didn't think they wanted a videographer as well.....of course, now that the wedding is over they're happy to watch videos of the rehearsal, the wedding itself & the reception.
There's still a place for camcorders & if I was doing this as a job I would have brought one & some wireless mics to capture decent audio.
32,350 views & 1 like for this thread
Latest registered member is mashy
684 guests, 392 members online
